08-03-2009, 05:44 PM | #1 |
Phone's ringin Dude.
Re: Bagged 05 Suburban
I pitty the fool with only two headlights!! 2003 SILVERADO SS--THE NEW GIRL 1972 GMC--THE OLD GIRL |
08-13-2009, 11:11 AM | #2 |
To center the rearend the panhard bar needed lengthened 1/4".
Cut the bar Lengthened 1/4" and tac welded for fitment. Installed the bar and raised the rearend to ride height and measured. The rearend was centered within a 1/32 so pulled the bar back out and started making the plates to weld over the 1/4 gap. Bending the front plate Making a pattern for the back plate Transferring the pattern to flat stock Pictures didn't turn out but they show the plates welding to the bar Front plate Back plate |
08-13-2009, 11:17 AM | #3 |
Also started making the mounts for the air tanks, compressors, and valves. The plan is to install the air management system between the frame rails where the spare tire was.
Showing the panhard bar and one of the mounts clamped for fitting Starting to look like something Tac'd together for fitting. Everything checked out so tomorrow I'll remove the tanks and finish welding |
