Old 04-03-2019, 11:53 PM   #476
mongocanfly
mongocanfly's Avatar
Re: 57 GMC, frame swap, 4wd, 454 big block, 4 speed
A buddy of mine just had the exact issue with poly mounts....
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
Old 04-03-2019, 11:59 PM   #477
joedoh
joedoh's Avatar
Originally Posted by Old57 View Post
Yes, it is a nice change to have the good weather lately.
I posted earlier about having a drive line vibration at 60-70 mph... I rechecked my pinion angle, and ended up changing it 2 degrees. That helped some, but I still had pretty heavy vibrations on the highway. I checked my drive line again, but it was set just right so I was trying to figure out why I still had the vibration. I decided to get a new rear shaft made with a double cardon joint and a custom flange on the transfer case from High Angle Driveline. When I called and talked to them, and explained what I wanted to get, he asked why I needed to do all of that for my application. After I told him about the vibes, he asked a lot of questions about how the truck was set up, and said it was all correct and shouldn't be having this issue. Then he asked if I had new motor and transmission mounts, and I told him everything was brand new. He asked what mounts I have, and I told him they were Prothane polyurethane mounts... he said that right there was my vibration problem. I changed out the motor mounts for new USA made factory rubber mounts, and now it doesn't have the vibrations. So if anyone is chasing weird vibrations while using polyurethane mounts, try changing them to rubber mounts.
thats outstanding, you sure seem to get the right guys on the phone! shop owner turning down a pretty expensive sale (double cardon? prob ~$800 at least) sure seems improbable!
Old 04-04-2019, 10:11 AM   #478
Old57
I knew the poly mounts would be stiffer and I would feel the engine running a little more, but I had no idea that it would cause that big of a vibration going down the highway. I guess at that speed and rpm, it was where there was some harmonic vibes with everything I have working together, and they transferred it into the frame and I could really feel it. I know now not to use poly mounts.
Yes, the new shaft with the double joint and large tube was going to cost over 900 bucks. I was sure glad he told me to change the mounts first, and see what that does.
My 57 GMC build
Old57 is offline   Reply With Quote
Old 06-02-2019, 11:01 PM   #479
Old57
I haven't checked in on the forum for a while. Over the weekend, I removed the dual 73 K20 poly transfer case mounts and the cross member. I got a new rubber single mount, made an adapter out of 1/2" aluminum plate on the mill to adapt the mount to the tail housing of the NV4500 transmission, then cut up the cross member and made it fit the new mount and location. Now it is a lot smoother with the good rubber motor and transmission mounts instead of the hard poly mounts. I also changed out the shortened seat frame of the 88-98 bench seat for a stock one to raise the seat up 2". It makes it a lot more comfortable for my leg position on the pedals. I drove it a while today. I took the wife to breakfast, stopped by Walmart to get a couple things, then picked up some mulch for her flower garden. With the seat change and the rubber mounts getting rid of the vibrations, it's pretty pleasant to drive now. I'm almost ready to change the oil for the first part of the engine break in. Also, it got pretty warm and humid today, and the cooling system didn't have any trouble keeping the big block right on the thermostat. I don't have AC, and the vent windows really work great for air flow in the cab.
My 57 GMC build
Old 06-03-2019, 06:15 PM   #480
mongocanfly
Looking good!...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 06-04-2019, 10:39 PM   #481
71'tahoe
71'tahoe's Avatar
Wow! What an amazing ans inspiring build! It took me 2 days of on and off reading to go through this whole thread! Thanks for all the information. I will be looking into the Kugel Komponents pedal set up as well as the New Port Engineering wiper kit for my 58' truck.
I have been wanting to start another project with a 56' cab I have and build a 4x4 but use a utility bed so I can have a service truck for my my farm/transportation business'.
A couple questions for you. Where did you purchase the Aviation primer? Is it more durable than automotive primer? I've been painting for several years and have never thought of aviation primers.
71'tahoe is offline   Reply With Quote
Old 06-05-2019, 10:20 AM   #482
Old57
Thanks! The Kugel pedal assembly worked out great and I'm glad I used it. It has great brakes with the 8" dual power booster, and the pedal swing ratios feel just right. The place that I had do the media blasting on everything is who sprayed the aircraft primer. They have contracts with local aircraft companies, so they use it regularly. It is very strong and durable, chemicals won't mess it up, etc. One thing to keep in mind though, is that it has a respiratory hazard when sanding/body working it. Make sure to use a filter mask when doing anything with it. I had them spray it on my bare metal to protect it until I can get it body worked and painted.
My 57 GMC build
Old 08-25-2019, 11:36 AM   #483
Old57
Been quite a while since I posted an update. The truck has been doing good, and I've been driving it when I have a chance. I took it to get some steel the other day, and to fill up the 32 gallon suburban tank. It's too bad the big block doesn't run on thumbs up and hell yeahs, because it gets a lot of those haha.
One issue that I had been dealing with, is that there was a miss when running. It had a little bit of a rough idle, and I can feel a little roughness when I rev it up to steady rpm. Everything was new, and I adjusted the carb and ignition several times, but it still had a little miss. The HEI distributor was one of the new no-name brands from Summit, and the plug wires were new from Autozone. I got a factory GM HEI distributor from a friend of mine, put in a Pertronix HEI upgrade kit (coil, module, cap, rotor, advance weights, and vacuum advance pod), and a set of Taylor plug wires. After that, it runs really smooth! I can reach in the cab and turn the key, and it immediately fires up and idles perfect.
My 57 GMC build
Old 08-25-2019, 08:57 PM   #484
joedoh
joedoh's Avatar
gorgeous!
Old 08-26-2019, 10:40 AM   #485
rgunlock
rgunlock's Avatar
It's a great feeling to knock out one of those nagging, non-obvious problems. Gives you a whole new faith in your truck. Nice job!
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 08-26-2019, 11:25 AM   #486
mongocanfly
Smiles and thumbs up are satisfying results for your hard work....
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-27-2019, 07:18 PM   #487
Purcell69
That's great that you got it fixed. Little things like that annoy the hell out of me. It's been 30 years since I had an annoying miss that I couldn't solve with a tune up. My old Power Wagon had one that I couldn't figure out for the life of me. It sat parked for six months while I was deployed to Japan and during that time, I kept troubleshooting the symptoms in my mind. When I got home, I was certain I had a burnt exhaust valve. Sure enough, when I pulled the heads, there was a pie cut in one valve.
A set of rebuilt heads later and I was back on the road. Glad yours was a proper tune up with quality parts.
-Joe
My '57 "Ram-rolet" not a NAPCO build: http://67-72chevytrucks.com/vboard/s...d.php?t=589917
Purcell69 is offline   Reply With Quote
Old 08-27-2019, 10:06 PM   #488
Old57
Thanks guys! I'm hoping to get a little more driving accomplished now that we're getting a little cooler weather. 100 degree days with humidity doesn't feel too good without AC!
My 57 GMC build
Old 08-28-2019, 11:28 PM   #489
mongocanfly
hows the extreme bedliner holding up? are you satisfied with it?
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 08-28-2019, 11:37 PM   #490
Old57
It's holding up great, and still looks just like it did when I sprayed it on. I'd definitely use it again. I've hauled stuff in the bed too, and it still looks new.
My 57 GMC build
Old 08-29-2019, 05:36 AM   #491
mongocanfly
good to know....ive got some raptor I'm gonna do my wheel wells with...may use extreme in the bed
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-14-2020, 12:46 PM   #492
Old57
Man, time has went by fast. I haven't posted in forever, and haven't even been on the laptop. Just had a chance to check in and catch up on some posts. About all I've done different to the truck is install a set of Comp roller rockers. Here's a few pics from a Sunday drive.
My 57 GMC build
Old 10-15-2020, 01:22 PM   #493
Second Series
Second Series's Avatar
That's a good looking truck, and inspiration for my build. Thanks for sharing.
'47 Panel to '88 K2500 Frame Swap
Mechanical Speedometer Drive Solution
1947.2 1 ton Chevy Panel
1955.2 Chevy 6700 Bus/RV
1990 Chevy K1500
Second Series is offline   Reply With Quote
Old 10-15-2020, 02:00 PM   #494
Old57
Thanks, I appreciate it!
My 57 GMC build
Old 10-15-2020, 02:31 PM   #495
rgunlock
rgunlock's Avatar
Glad to see you are getting use out of the truck. It's looking good!
Rick
Old 10-15-2020, 09:27 PM   #496
Old57
Thanks! I'm hoping to replace the rear fenders and get it scuffed/painted in all 1 color of a satin green over the winter. The nice body work and paint job will have to wait a while.
I got a Nathan Airchime K3 though... in case a squirrel or something runs out in front of me I'm mounting it under the bed with a tank and compressor. The picture of it shows my size 15 boot for a size reference.
My 57 GMC build
Old 10-15-2020, 10:17 PM   #497
mongocanfly
Haha...them things oughta blow the hair off a squirrel..!!
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 10-16-2020, 09:24 AM   #498
Old57
Haha, it should get the job done!
My 57 GMC build
Old 10-19-2020, 12:03 PM   #499
Old57
I made a mount for the "squirrel" horns and installed them under the bed. I'll get a 5 gallon tank and compressor from one of the air ride supply places sometime and hook it up. I took the truck out cruising on some back roads for a while over the weekend. Something about driving an old truck on dirt roads just feels right.
My 57 GMC build
Old 10-22-2020, 01:49 PM   #500
youngrodder
youngrodder's Avatar
Such an awesome looking truck....Love everything about it.
Marc
…………...........__________
.................. ((__|__||___\____
..;.;;.:;:;.,;..;((_(O))____ (_(O))
1948 Chevy Truck - Finished SOLD!!
1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021
http://67-72chevytrucks.com/vboard/s...d.php?t=605484
1994 4x4 Blazer - "Field Find"
https://67-72chevytrucks.com/vboard/...ferrerid=30857
youngrodder is offline   Reply With Quote
