Old 06-01-2020, 06:00 PM   #26
Re: 1983 garage build
Originally Posted by Warrens69GMC View Post
Nice! I have been looking for a I6/SB with air
I was looking at 2 different ones with I6s, a 76 step and my 81 step. I opted for the 81 because it had factory air and better shape/paint.
1981 GMC High Sierra SWB Stepside
Board Vendors
It's scary when you start making the same noises as your coffee maker.
Old 06-01-2020, 09:48 PM   #27
moregrip
moregrip's Avatar
Originally Posted by rodstored-72 View Post
more grip,
Nice job. I am waiting on my kit from summit & then will begin the drop proceedure. I will use the above info on my purches as well. Thank you for the tips!
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 06-01-2020, 09:54 PM   #28
moregrip
moregrip's Avatar
Lenox blade cut though the frame like Butta!!
Need to wack a few more rivets off, but we're close!
Old 06-04-2020, 10:21 AM   #29
Rich84
Rich84's Avatar
Cool build..I picked up a not so pretty 6 banger long bed with air. Thinking about cutting her down to size, but space is a problem...Too many trucks.
Rich84 is offline   Reply With Quote
Old 06-04-2020, 10:34 AM   #30
moregrip
moregrip's Avatar
thank you! I'm not a huge fan of a longbed on a lowered truck but they look right at home on a raised truck. I'm kinda in the same boat, 2 project trucks in a 3 car garage doesn't leave much room. Ideally I would only have one truck in the garage/shop at a time!
Edit: Interested to see what you do with your project!
Old 06-05-2020, 02:53 PM   #31
moregrip
moregrip's Avatar
removed 8 more rivets; thought I had it licked....realized I still have two more to go!
Old 06-05-2020, 03:18 PM   #32
tinydb84
tinydb84's Avatar
I used to fight with rivets forever! If you don't have to worry about the top piece I have found a large impact hammer will sheer the heads off and push them through is seconds.
When I need to save the part though I am still pretty quick with using a step drill for most of it then a flap disk to take the rest of it off and it falls out.
How do you like that kit? Brooks make some nice stuff.
David
Instagram: myfabguy
Old 06-05-2020, 05:28 PM   #33
moregrip
moregrip's Avatar
Thanks for the tips! So far so good, the kit seems to work rather well; just finished the drivers side; heading over to the passenger side in a few
Old 06-05-2020, 05:29 PM   #34
moregrip
moregrip's Avatar
lots of metal shavings later, drivers side mostly done!
Old 06-06-2020, 08:45 PM   #35
moregrip
moregrip's Avatar
made my own drill jig using the rear frame rails; worked out pretty good if I do say so myself/also used the "Tapfree" cutting fluid for all drilling; seemed to help quite a bit...drill bits lasted the entire project.
Old 06-06-2020, 08:50 PM   #36
moregrip
moregrip's Avatar
inner plates and welding will happen a little further down the road, however, this keeps it in a roller status for now.
Old 06-07-2020, 04:20 AM   #37
wixthedog
Active Member
wixthedog's Avatar
You're doing good work! I use a torch on the old rivits, if its near the gas tank I use an air chisel.
Mike
1976 C10 RCLB - 350 - SM465 4 Spd - 4.5"/6" Drop
Obligatory Build Thread HERE!
1979 C20 RCLB - 350 - TH350 Auto
wixthedog is online now   Reply With Quote
Old 06-07-2020, 07:04 PM   #38
moregrip
moregrip's Avatar
Thank you! I've never been accused of moving quickly when it comes to these types of projects
Copyright ©2000 - 2020, vBulletin Solutions Inc.
