11-05-2011, 01:53 AM | #1 |
Upkeep of the intake
I have a non-polished aluminum performer intake. When I bought it there was a nice satin finish on the new aluminum casting. was not long before it started to look pretty bad and just a dingy old gray aluminum look.
I am wondering what product or process keeps the bumpy aluminum casting looking new? I have toyed around with powder coating it but am still on the fence. I have seen it done and it looks good but the raw satin cast looks good too. The day I installed it After about 1000 miles this is what it looked like
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 Last edited by Mike Bradbury; 11-05-2011 at 01:58 AM. |
11-05-2011, 06:41 AM | #2 |
Watch out for your cornhole !
Re: Upkeep of the intake
You've got to know what I'd recommend, powdercoat. I did this one for a member here. It's a silver basecoat with clear topcoat. That seals the pores and smooths the casting out so you can wipe any spills or leaks off.
11-05-2011, 08:53 AM | #3 |
Paint or powdercoat are about your only options to keep it looking good. The rough cast finish allows dirt and grime to build up in the porous pits, and also stains the aluminum, so it's very hard to clean properly without media blasting.
Here's a pic of mine painted with Duplicolor Cast Coat Iron. Here's a shot with Duplicolor Cast Coat Aluminum.
11-05-2011, 09:08 AM | #4 |
PROJECT 7DEUCE
I'm pretty sure mine will get powder coated when the motor comes out for detail.... Speaking of detail who's blue motor is that???? Check out those spark plug wire holders..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-05-2011, 10:33 AM | #5 |
Newbee
I shot mine with this, right out of the box...
http://www.por15.com/PELUCID/productinfo/PELG/ I dont have many miles on it, but it looks great. |
11-05-2011, 12:21 PM | #6 |
mine has been on for 5 years and i clean it with simple green. Edelbrock does sell a cleaner to restore the finish
Fuzzy |
11-05-2011, 05:39 PM | #7 |
I've used Berrymans carburetor cleaner with good results. Usually just spray over the intake when I'm cleaning the outside of the carb.
Keith |
11-08-2011, 06:41 AM | #8 |
There is one option you all are forgetting about and that is having it polished. Polishing it will benefit the motor the most, it causes the heat to radiate from it rather than soaking it up.
11-12-2011, 12:21 PM | #9 |
I say get it powder coated by Kevin. He does top notch work. That intake sure does look nice and is easy to clean up
1972 SWB Medium Olive South Houston Instagram: Antbish84 |
11-13-2011, 10:36 PM | #10 |
Grandpa in the rustmobile...
Mines sorta stained but some carb cleaner and a rag makes it look good
brake cleaner does even better, but watch the painted areas! mmmm powdercoat, matt your motor looks great
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
