10-31-2019, 01:25 PM | #1 |
Steering components
Looking for some info on what you guys have done for the steering linkage on a pancaked front crossmember. Need to gain clearance on the cross member. I’m thinking about flipping the center bar 180 degrees so that the offsets face inboard instead of facing the front of the truck.
11-01-2019, 10:56 AM | #2 | |
Re: Steering components
One side of the U-bolts requires trimming it shorter. The process also requires modifying the reinforcement plate that goes under the nut (it gets cut off/shorter in length) so that there is still 100% thread engagement of the U-bolt thread on the side that's trimmed shorter. I also buzz a little off the edges of the x-member anywhere the linkage comes close so there's no chance of contact as the steering travels it's arc. I've run the stock steering shafts vs. a u-joint/shaft bearing set-up. To do so requires using 63-72 or HD 73-87 upper arms (because of the smaller OD of the a-arm shaft bushings) & notching the driver upper a-arm for the needed clearance when air'd out on a bagged suspension. Flipping the linkage causes other issues from what I've read on here. Usually it's from guys that are having issues getting an alignment. They're researching possible causes & the inadvertent flip of the drag link is usually the cause.
11-01-2019, 02:19 PM | #3 |
Thanks for the reply. I must have pan caked my cross member over 1-1/2 because the joints were butted up against the xmember. So from your response there is some parts I can swap out to gain clearance. I was going to modify the cross member but it doesn’t seem like it would work
11-01-2019, 02:47 PM | #4 | |
11-01-2019, 02:54 PM | #5 |
Thanks I’m at work I’ll snap a pick when I get home
11-04-2019, 06:22 PM | #6 |
I notched my frame 1.5" to raise the crossmember and used No Limit's rack and pinion kit. No steering clearance issues that way and it gets rid of the (usually) sloppy steering box.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
11-04-2019, 07:54 PM | #7 |
Thanks I want to run power rack just can’t afford the pulley set to move my alternator up to give me the clearance for the steering shaft. I think I’m just going to cut a inch out of the pivot and idler arm and weld it up until I buy the accessory kit I want. Going to check out no limit see how there kits look like.
11-09-2019, 01:49 AM | #8 |
I ended up ordering the no limit rack called said I can run it with the current belt drive set up 2010 Camaro ls3
11-19-2019, 10:03 AM | #9 | |
Have you plumbed the rack yet wondering what part numbers you used |
11-20-2019, 02:11 PM | #10 |
I haven't got that far with the project yet.
Tags |
pancaked crossmember |
