03-30-2019, 07:35 PM | #1 |
nv3500
Getting ready to start ordering some parts for my 68 c10 and will probably be using a nv3500 trans. My question is will a nv3500 have any clearance issues with a low hump floor pan or will i need a high hump. Thanks.
03-30-2019, 08:32 PM | #2 |
Re: nv3500
You will want a high hump. Buy the steel one not the fiberglass one. Any particular reason you're set on an NV3500? I only ask cause i've seen two of them grenade and both the guys who did it said they shoulda just put a tko 500 or 600 in and been done with it.
http://67-72chevytrucks.com/vboard/s...d.php?t=212959 http://67-72chevytrucks.com/vboard/s...=212959&page=2 |
03-30-2019, 09:04 PM | #3 |
Re: nv3500
Thanks. I looked at the tko 500 but wow. 2500.00. My 350 is about 300 hp give or take. I don't plan to burn much rubber and never gonna see 5000 rpm. Have read a lot of post and some like them some don't.
04-03-2019, 04:04 AM | #4 |
Re: nv3500
They are not a bad transmission and will hold up to some abuse. They were a used behind the TBI 350s in 2 and 4wd from the factory so that is around 240HP. It was also an option behind a 4.8 LS motor for a year or two. Either be a little easy on it or keep the tires narrow and it should live a long life. This is the same basic transmission used as the last 5spd in jeeps before the 6spd came in.
04-03-2019, 12:39 PM | #5 |
The Older Generation
Re: nv3500
Don't know if you looked at this thread or not., Maybe you don't need to with what you are doing, but there is a lot of info on manual transmissions in it. http://67-72chevytrucks.com/vboard/s...d.php?t=438224 LockDoc
04-03-2019, 04:51 PM | #6 |
Re: nv3500
Mine is about to go in the next couple of weeks, we are trying to keep the low hump and trim/plate as needed so I will let you know how it goes. I don't like the looks of a high hump so I am trying to keep it as low as possible. My motor is also 1/2" higher than stock so this will work against me.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
04-03-2019, 07:13 PM | #7 |
Re: nv3500
Good info guys,Thanks. Cebra let me know how it goes for you.
