02-23-2015, 12:36 PM | #1 |
Pitman are question
I purchased a drop pitman arm from Skyjacker CA50 (I think). it did not come with the cross bolt. Is this a special bolt and nut? if so I cannot seem to find it. does anyone have any information about it? A picture? place to get a replacement?
My truck has manual steering and not sure the bolt is the same and since I am replacing the steering box and pitman arm I would like to get a new cross bolt.
1956 Chevy Bel Air 2 door 1956 Chevy 210 4 Door 1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD 1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E 1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD* GO GO!!! |
02-24-2015, 11:04 AM | #2 |
Re: Pitman are question
I am not sure if its a special bolt other than a fine thread grade 8 with locking nut. Make sure its tight ! I changed my steering box out a little over a year ago and it managed to loosen.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
02-24-2015, 12:48 PM | #3 |
I thought maybe they were a special bolt. Does anyone have a picture of one so I can see it and maybe get the dimensions?
02-28-2015, 03:10 AM | #4 |
anyone?
02-28-2015, 03:24 AM | #5 |
Take the arm and go to a hardware store and find a fine thread grade 8 bolt the proper length, then make sure the nut and loc washer you find are also grade 8 as well, the bolts, nuts and washers are gold anodised in color.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
02-28-2015, 03:45 AM | #6 |
Ok I will get a fine thread grade 8 bolt and post size when I get it. Thanks I just wanted to make sure it was not a special bolt.
11-08-2019, 12:02 AM | #7 |
Roto Reuter thats the name...
What did you ever do about this pitman arm cross bolt? I'm in the same position and need a new bolt for my Skyjacker CA50 pitman arm.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
11-08-2019, 12:15 AM | #8 |
If I remember right it was a 3-1/2” x 1/2” bolt. Fine thread. But I am not positive. I will check tomorrow.
11-08-2019, 08:30 AM | #9 |
Does GM not list this bolt anymore? I know when I replaced the pitman arm on my Jimmy I couldn’t find one year appropriate and bought a ‘91 Suburban arm that worked just fine. Can’t remember if if came with a new bolt?
But it is a minimum thread bolt so the shank runs in the groove of sector shaft so I would do my best to get an original, or a long shank bolt you could shorten the threads on to match.
11-08-2019, 09:27 AM | #10 | |
11-10-2019, 11:21 PM | #11 |
Here is the picture.
I used anodized 1/2” x 3-1/2” grade 8 with a nyloc nut.
11-11-2019, 12:29 AM | #12 |
Thanks for the info. I'll see what I can come up with.
11-21-2019, 12:20 AM | #13 |
You should be fine with a replacement. The bolt holds it on the shaft where it’s slotted and there isn’t much vertical torque on the shaft. Once tightened it’s two fold with no movement. Grade 8 will do the job. That’s a strong bolt, especially when it’s that thick. Probably overkill but who cares when it’s barely pricier than a grade 5.
Kirk 72 Blazer CST 4wd highlander 66 Nova |
11-21-2019, 05:06 PM | #14 |
I ended up with two options. I bought a GR8 bolt at tractor supply. and I bought the one from LMC. It's actually a 9/16" fine thread. The one from LMC is also GR8. I ended up using the LMC one. The tractor supply bolt was a bit longer. They only had 3" or 3-1/2" long. The LMC one worked out good and had a good lock nut with it too.
11-21-2019, 07:11 PM | #15 | |
