07-11-2020, 08:19 PM | #1 |
laying low
Accessory brackets
I bought all the engine bracketry off a 75 Blazer with 350 engine to mount the ac compressor and power steering pump. Or so I thought. Apparently I am missing another piece that bolts to the back of the pump. Here are a couple pics of what I have installed. Can any one tell me what’s missing and maybe send me a pic of the piece? I’d much appreciate it.
07-11-2020, 09:11 PM | #2 |
Re: Accessory brackets
it looks like you need the other piece of the bracket.
its the one here behind the pump |
07-11-2020, 10:38 PM | #3 |
laying low
That looks like one sold by the header maker. With stock manifolds I will need a stock bracket. Thank you Tx.
Anyone else have a pic of the stock piece?
07-12-2020, 11:09 AM | #4 |
I think I found it
07-12-2020, 12:38 PM | #5 |
laying low
That one is for non a/c. I am finding there were a half dozen or more different brackets from factory depending on application and yr models.
I believe for the 75-85 year engines I need this bigger bracket for my power steering and a/c setup. This was gone from the engine I got the other brackets from. I am now narrowing down the yr model and image to look for that bracket. I think another visit to the jy is in order now that I have a better idea of what I am looking for. Thanks for the help.
07-16-2020, 11:09 PM | #6 | |
Which one are you attempting to achieve? I've attached the diagram for an A6 installation and brackets from the GM factory manual. If you need to accommodate a different compressor you need to consult the correct year manual which are available here in PDF form after searching.
1980 K10 Suburban Silverado, original 350 w/Qjet swapped to 406sb, TH350C swapped to TH400/205 |
07-17-2020, 04:28 PM | #7 | |
Alex. |
