09-03-2015, 11:30 AM | #1 |
Rack & Pinion Advice
Some people go with it and some don't..I need to know if there are any reasons why not to go with a power Rack & Pinion if you're having to install all new stuff concerning the steering anyway. I've gotta get a new steering column, new power gear box (or rack & pinion)..all new suspension and etc.
Thanks.. |
09-03-2015, 09:24 PM | #2 |
Re: Rack & Pinion Advice
...aw..come on folks..Rack & pinion eliminates the steering box right? And I'm not too sure what a good ratio is..say if you have a 14:1 gear ratio, what is turning 14 turns while the steering wheel is turning 1 complete turn..hate to sound like a dummy but I can't figure out the best or shortest turning ratios..
I want a ratio so I don't have to turn a 14"-15" steering wheel as many times.. Sorry if I not making good since! |
09-04-2015, 08:38 AM | #3 |
Just to give you a little feedback and hopefully answer part of your question. A steering ratio is the number of degrees the wheel turns per 360 degrees of the steering wheel. The higher the ratio the less the wheel will turn per 360 rotation of the steering wheel. A 14:1 steering ratio will turn the wheels approximately 25.7 degrees per each 360 of the wheel (360/25.7 = 14:1). A 12:1 will turn the wheel 30 degrees per 360 degrees of the steering wheel. There are a few companies that make kits for rack and pinions like No Limit but they are pricey (about $1000).
Brandon Instagram: DRVFSTR Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691 |
09-04-2015, 09:10 AM | #4 |
This is an area I researched to death last year. My steering box leaked and had it in my head I had to have rack and pinion. Its definitely not an inexpensive option and can result in your project to take a major turn . I looked at the Unisteer kit, NoLimit's, Porterbuilt dropmembers, and NoLimit's wide ride. I even did a cost analysis to help make up my mind I decided on the PB Level 1 Dropmember.
Basically what it boils down is what you are wanting to accomplish and how much you are willing to spend. I'm going for an old truck with modern suspension. It all started with wanting R&P and new control arms, which led to spending a little more for the DM, etc. Now its better brakes and shocks. Had I replaced my steering box I could be close to driving my truck by now
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
09-04-2015, 09:31 AM | #5 | |
09-04-2015, 11:50 AM | #6 | |
I really appreciate your reply..Thanks! |
09-04-2015, 12:09 PM | #7 | |
09-04-2015, 12:20 PM | #8 |
A higher ratio requires less effort to turn. Lower ratio is a faster response.
09-04-2015, 12:58 PM | #9 |
I know that's right!
09-04-2015, 01:06 PM | #10 |
A steering box system in good repair is fine for most things. If all your stuff needs replaced you will still likely be cheaper to just replace it then dig in deep and swap in a steering rack system.
IMO, for average joe the only reason to swap in a steering rack is because you want to, not because a steering box is inadequate for even performance street driving. |
09-04-2015, 01:33 PM | #11 |
09-04-2015, 09:12 PM | #12 | |
Not many ideas in my build. Just a display of my lack of ability to make decisions. Progress should pick up shortly.
