Old 10-20-2020, 10:35 AM   #26
msg
Re: Water pump for an L31?
Then the vintage air kit arrived and as Geezer predicted I do need to remove one of the plugs from the intake and go buy some 5/8 barbs now.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-20-2020, 10:38 AM   #27
msg
And it looks like I also need to buy a different water pump since this one that I just painted and installed only has 1 heater hose port.
Old 10-28-2020, 11:20 AM   #28
biketopia
Nope you just don't need the hose you just installed, install the vintage air to either side of the pump and intake and you should be good.
71 c-10 Long Bed, under the knife for a No Limit Engineering Wide Ride Chassis Pack and coil over static drop.
07 Silverado Classic 2wd
95 Camaro 427SBC/TH350
biketopia is offline   Reply With Quote
