Old 10-13-2020, 11:38 AM   #1
msg
Air cap for L31 - which type?
Putting a list together of parts I need on this new L31 and the breather cap came up. I was looking for a push in style cap that was black and Im seeing options that have open looking filters and some with just a cap and some with a PCV stem. Is there a best way to go or are they all the same more/less?
https://www.proformparts.com/product...ameter-no-logo
I also wondered about the open filter type and how they may get gummed up and whether or not its a a replacement of the whole thing or can you replace the paper filter?
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 10-13-2020, 11:59 AM   #2
geezer#99
geezer#99's Avatar
Re: Air cap for L31 - which type?
What aircleaner you using?
Old 10-13-2020, 12:29 PM   #3
msg
I have this proform on a quadrajet
https://www.summitracing.com/parts/pro-141-906
Old 10-13-2020, 12:43 PM   #4
geezer#99
geezer#99's Avatar
Reason I asked was to see if your air cleaner has a barb on the bottom to hook a breather hose to.
If not just pic a normal breather that fits your grommet that matches the look of your air cleaner.
The open element style can look grungy after awhile.
Old 10-13-2020, 01:56 PM   #5
msg
Thanks Geezer, there are some parts that look like I could hook a hose up if I wanted. Does this help the engine run better?
Old 10-13-2020, 03:33 PM   #6
geezer#99
geezer#99's Avatar
That’s the hook up for a breather hose.
I’ve used them before with a couple of plastic 90 degree elbows and some 5/8 inch hose. Run to the grommet in the valve cover.
You can use just a breather if you want.
All you’re looking for is filtered air into your motor to combine with the fumes and out the other cover with the pcv valve.
