10-19-2020, 09:22 PM | #1 |
Trans cooler?
I have a 383 with a Th400. I also have a Champion aluminum radiator with trans cooler.
I will not be towing in this 1969 short bed 1500GMC. Do I need to also add an external trans cooler in addition to the radiator trans cooler? I've searched a lot of threads on this site and I'm still confused. Thanks |
10-19-2020, 09:36 PM | #2 |
Re: Trans cooler?
No.
It’ll be fine. |
10-19-2020, 09:37 PM | #3 | |
Moderator
Re: Trans cooler?
If you have the space to place an aftermarket trans cooler so it has sufficient air flow, I usually install one.... How its plumbed is always a matter of personal preference... Unless requested by an owner, I always install the aftermarket cooler as a stand alone cooler, totally bypassing the radiator cooler....why? Doing so eliminates the possibility of coolant making its way into the trans by a faulty cooler setup inside a radiator tank. (I also cap off where the original cooler line fittings are in the radiator tank) I can see you are in Austin TX...so extreme cold wont be an issue.... In colder climates sometimes a customer will want the radiator cooler retained in the system,,,,but they are always warned of possible issues. Hope this helps...
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
10-19-2020, 11:59 PM | #4 |
Re: Trans cooler?
Thanks for the replies.
I want to keep it simple and inexpensive. It's just a cruiser so I'll try first with just the radiator trans cooler. |
