10-29-2020, 09:47 AM | #1 |
flexplate or starter ?
I have a 2 wheel 80 chev truck, stock 350/350 and got the flexplate noise when I started it up the other day ,no warning signs just all of a sudden. Does it in all gears. Doesn,t make any sounds with power disconnected and cranking engine over. I crawled underneath while running with inspection cover removed and noise is there and everything seems to run true. No loose bolts ,can,t see any visible cracks but that doesn,t mean there not there. I did see on the starter this ring can slide back and forth on the nose cone and I don,t think it,s suppose to do this. Here is a pic of a nose cone and a short video I found with the same noise I have. https://www.youtube.com/watch?v=DPk7CGEOqwk
10-29-2020, 01:58 PM | #2 |
Re: flexplate or starter ?
Pull the dust cover off and take a look. Sounds like it is cracked or loose
10-29-2020, 03:00 PM | #3 |
Moderator
The ring on the starter shaft being loose is not usually a problem...
Assuming you have the convertor cover off and the noise is still there... 1/ Check all convertor bolts are tight....if they are all tight and the noise remains... 2/ Its either a cracked or loose flex plate....either way, trans or engine will have to come out.... To check ....turn off engine, grab flywheel with a gloved hand and pull it in the direction of rotation, then push it back the other way...if it moves either way the trans or engine will have to come out...you may even hear a knock... If it needs to come out its the perfect time to replace all freeze plugs in the engine.
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox Last edited by AussieinNC; 10-29-2020 at 03:06 PM. |
10-29-2020, 04:00 PM | #4 |
My guess would be the flex plate, maybe it's cracked or loose. If it was the starter you would hear it when trying to start with no power.
10-29-2020, 04:40 PM | #5 |
Did all that is mention everything was fine. Just trying to eliminate the easy stuff. Engine was rebuilt about 5 yrs. ago with summer driven only. I know everything is possible but is not a old tired motor. Looks like a easy swap thou, have seen it done with the tranny in and just slid back a couple inches. I know about using longer tranny bolts to slide it out. Got all winter if need be but I need some drywall .
11-04-2020, 02:24 PM | #6 |
I fought a clicking noise when under torque, never at idle.
It was the internal shim on the new starter. It was a high torque mini Starter. It took care of it. The plunger was to close to flex plate. The sim moved It back enough not to hit, but still engage. |
