01-20-2013, 11:57 PM | #1 |
Porterbuilt front tubular replacement crossmember
Maybe I'm an idiot, but I bought the Porterbuilt tubular front replacement crossmember and now after I got the factory rivets out of the frame I noticed that the crossmember has the holes drilled evenly on both ends. The frame has holes that are wider at the top and narrower at the bottom so the holes don't match up. I'm confused!
01-21-2013, 12:11 AM | #2 |
Re: Porterbuilt front tubular replacement crossmember
Did you buy just the front crossmember? Or a kit? I ask this because when I bought mine, they came as a kit with my body drop setup. There are front and rear crossmembers in the kit. The front one in my kit had the offset holes to match the existing frame. Maybe you have them backwards or Nate accidentally sent you the wrong one?
--------------------------------------------------------------- Jason. 68’ GMC shortbox https://67-72chevytrucks.com/vboard/...d.php?t=794201 72' 2WD Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=425385 67' LongBox C-10 http://67-72chevytrucks.com/vboard/s...d.php?t=691845 InstaGram ybnorml67 |
01-21-2013, 12:14 AM | #3 |
No I already have the rear one bolted up I think he sent me the wrong one!
Posted via Mobile Device |
01-21-2013, 12:16 AM | #4 |
Mine has the offset holes also.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-21-2013, 12:45 AM | #5 |
I know I'm a newbie but you would have thought that I would have checked to see if I had the bar upside down! Problem solved "I got to slow down sometimes"! Lol
Thanks anyways guys! |
01-21-2013, 02:32 AM | #6 |
It'll Buff Out!
we have all been there. glad you got it right side up!
"Instructions are just another mans opinion" Become a Supporting Member http://67-72chevytrucks.com/vboard/payments.php Man Card Rules http://67-72chevytrucks.com/vboard/s...d.php?t=634550 72 Chevy Cheyenne Super 400 LWB |
