Old 11-24-2020, 07:46 PM   #1
jabborabbo
jabborabbo's Avatar
‘67 drum brake springs...replace ‘em?
‘67 GMC with drums front and rear - I’m doing a complete (except for the master cylinder) rebuild - shoes, hoses, and cylinders. I don’t know if the springs have ever been replaced - they have a very thin coat of smooth rust on them - the truck was kept in a garage all it’s life (except of course when it was being driven). Should I replace all the springs?
Thanks in advance for all replies!
"It is hard to search for a black cat in a dark room, particularly if it is not there. Especially if this cat is smart, brave, and polite." Sergei Shoigu, Russian Minister of Defense
jabborabbo is offline   Reply With Quote
Old 11-24-2020, 08:37 PM   #2
kwmech
Re: ‘67 drum brake springs...replace ‘em?
Every time.... if money will allow
Old 11-24-2020, 09:12 PM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: ‘67 drum brake springs...replace ‘em?
I would. Considering they could be over 50 years old.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 11-24-2020, 09:18 PM   #4
geezer#99
geezer#99's Avatar
Napa used to sell a complete spring and hardware kit for drum brakes.
geezer#99 is online now   Reply With Quote
Old 11-24-2020, 09:19 PM   #5
MaximusD
MaximusD's Avatar
Hi all, I am doing the same replacement, what about changing the drums?, I assume they should be changed, but thought I would check with you all. Thanks
MaximusD is offline   Reply With Quote
Old 11-24-2020, 10:15 PM   #6
geezer#99
geezer#99's Avatar
Should be able to find a machine shop that can resurface them if needed. They should be marked with a minimum thickness.
I’ve found replacement drums that don’t have the adjustment hole in them and you need to install a slot and plug in the backing plate.
Best to keep stock ones.
Old 11-24-2020, 10:36 PM   #7
MaximusD
MaximusD's Avatar
Great, thanks for info!
Old 11-25-2020, 12:17 PM   #8
weim55
I no longer replace brake hardware on older drum brake (40s-70s) vehicles unless I can get my hands on NOS factory or aftermarket parts. Hardware kits (return springs) in the current auto parts chain have repeatable failure in my experience. Clean and inspect the originals carefully, they are almost always OK. You can't beat that old USA quality.......
Just my two cents of experience.......
Steve weim55 Colorado
weim55 is offline   Reply With Quote
Old 11-25-2020, 12:25 PM   #9
weim55
Best to retain those old quality drums if possible, especially if they are OEM. If you do have them remachined beware of the hack running the brake lathe at the auto parts store. Often they do not mount the drum squarely on the machine and then remove many times more material than necc. to refinish. Find that quality shop in town that knows the old stuff and does it right.....
Old 11-25-2020, 12:25 PM   #10
dagnabbitt
dagnabbitt's Avatar
I have to agree. If you are going with new parts from China at the very least don't throw away the originals, you might be putting them back on.
DAVE
Edmonton, Alberta
1959 Apache
1967 K20
1968 C20
1970 C10
1972 GMC 2500
1981 C10
Old 11-25-2020, 01:13 PM   #11
racerop
racerop's Avatar
Originally Posted by dagnabbitt View Post
i have to agree. If you are going with new parts from china at the very least don't throw away the originals, you might be putting them back on.
x2
racerop is offline   Reply With Quote
