Old 12-06-2005, 11:13 AM   #1
Chevy_Man
Tightwad
Chevy_Man's Avatar
Truck work shops
Hey who has a work shop that was built at home so they could work on there old trucks? Sure would like to see some pics. I am planning on building me one real soon and was looking for ideas and how yall have them set up.
Eric
Chevy_Man is offline   Reply With Quote
Old 12-06-2005, 02:50 PM   #2
lilred67
lilred67's Avatar
Re: Truck work shops
i don't have any pictures to post but i have a 30x40 shop with 12' walls.it has 1-10x12 & 1-10x10 rollup doors and walk through door.it was money well spent.if you build one,spend the extra money on insulation.this shop i built is insulated but my first shop was not and it really makes a difference.
lilred67 is offline   Reply With Quote
Old 12-06-2005, 03:43 PM   #3
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Well, mine wasn't built by me, it was built by my father, his brothers and my grandfather, and I bought my grandfathers house just so I could have the garage. They ran a bus line in my area. If I remember correctly it is 42' x 28' or something close to that. I have several improvements I want to make to it but it is a nice start. Here are the pics:
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-06-2005, 03:45 PM   #4
glock35ipsc
Next project: 1970 K10
glock35ipsc's Avatar
30' x 40' "second" home. I got a furnace, I got A/C, and I got a fridge (ie: BEER!), what else do I need? Oh yeah, I got some tools too.....
SW corner:
SE corner:
NE corner:
NW corner:
Bob
1970 Chevy K10 LWB "Goldie" 350/TH350 next project!!
1981 Chevy C10 LWB 355/TH350 - My son's truck
LS SWAP FORUM! Tons of LS swap info here!
PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET!
CLICK HERE FOR THE FAQ INDEX by KRUE
glock35ipsc is offline   Reply With Quote
Old 12-06-2005, 04:11 PM   #5
coolair
Check this site out - a lot of good info. - www.garagejunkies.net
coolair is offline   Reply With Quote
Old 12-06-2005, 06:02 PM   #6
smbrouss70
smbrouss70's Avatar
Man, ya'll are making me jealous! (as my truck sits under the carport on jack stands and the wife complains about it)
Hey Glock, is your 30'x40' big enough for 2 projects at once? I want to make sure that when I build one, it will be big enough
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 12-07-2005, 09:05 PM   #7
faribran
build it as big as u can afford... never enuff room
faribran is offline   Reply With Quote
Old 12-07-2005, 10:31 PM   #8
glock35ipsc
Normally, yeah. I had the 70 4x4 on one side and an 81 dually on the other and still had plenty of room all the way around. But it is cluttered now. I need to either add on or get a shed to move some shelved into to store parts, and shop tools that don't get used alot like the english wheel and stuff.
Right now I have the 68's cab in there, and my wifes Harley is torn down while I paint it. I also park my truck in there at night now that the temps are well below 0. When is gets this cold, I leave the heater on with the thermostst all the way down, so it stays about 40 in there. It was -16 F when I left for work this morning
Like someone said before, it is never big enough.
Bob
Old 12-08-2005, 11:40 AM   #9
hgs_notes
GEARHEAD
hgs_notes's Avatar
Mine was built by the previous owner who owned one of those truck campers that was pretty tall. So I have 11' cielings, one 10' door and one 7' door. Unfortunately the foot print is only 22' wide by 26' long. Its what I got and I'm making the most of it. Sorage is always a concern, I dont have much space around the sides with the trucks inside. So I'm using my overhead space as much as possible. I built a loft area above the shorter garage door. I'm building shelves along the walls about 7 or 8' up with support from the rafters. Bicycles hanging from the cieling using a pully system I got at the hardware store. I have a small table saw and radial arm saw. I'm building a shelf to mount the arm saw that will hinge on the side of the table saw. Then the whole deal will hang from the cieling like the bikes. I have a pull down stairs in the cieling for easy attic access. My work benches are mounted on a shelf that is the same hieght as the block foundation so I can move them back against the wall and also because I like to have the work surface higher than normal, less leaning, easier on the back and shoulders, plus more storage underneath. I have the walls insulated, the cieling will get done probably next year. The plastic on the cieling keeps the heat down and actually makes it look better than the open rafters. I use a portable propane heater that will warm it on our colder days (below zero) up to about 50F, which is comfortable with a sweatshirt. When the cieling is insulated, I'm sure it will be warmer, plus I just replaced the 10' door with a new insulated one. The other door is still the original POS.
If I were to build my own, it would be at least three cars wide and about 36' to 40' long, normal cieling hieght but a full attic space over the car area and open to the rafters in the shop area. Access to the attic by stairs. Hot water floor heating and electrical outlets everywhere.
It's the best I've ever had and it's what I'll likely have for the next decade or so. Beats the snot out of working in the back yard under a tree, which I've had to do in the past.
hgs_notes is offline   Reply With Quote
Old 12-08-2005, 11:41 AM   #10
Yukon Jack
Yukon Jack's Avatar
Here is my 40x60 shop
and here is a pic of the mess inside
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-08-2005, 11:58 AM   #11
Bill72BB
Thats the Hillbilly way
Bill72BB's Avatar
Not mine , this would take up half my lot , but I like the looks of this one .( Got this off one of the Metal building site's )
Anyone got one of these ?
BILL
Torrance Calif 90504
Member DUF Club
Member Old Farts Club
72 3/4ton Custom Camper BB402/400 trans Dynomax Cerama-coat headers , Hei distributor ,Edelbrock 1411 air,ps,pb,leafsprings ,98 chevy 60/40 seat,S10 shoulder belts
tilt,3.54 Dana 60 rear. 16" Eagle wheels with LT265/75 16 tires,Gaylord Lid,H4 headlights with 100W relay conversion.
" If I knew I was going to live this long I would have taken better care of myself "
Marriage changes passion...suddenly you're in bed with a relative. A GUY'S PRAYER....
Lord, I pray for a nympho with huge boobs who owns a liquor store and likes to fish and hunt and has a Harley .Amen ,
Bill72BB is offline   Reply With Quote
Old 12-08-2005, 12:52 PM   #12
paintpyro
paintpyro's Avatar
I hear ya Bill. 2 car garage just doesnt seem to cut after seein these.
70 shortbed stepside
"Schleprock"
350 w/TH400
rallys and BFGs
-We can rebuild it, we have the technology-lower,shinier,faster
paintpyro is offline   Reply With Quote
Old 12-06-2005, 07:12 PM   #13
chevyboy55
chevyboy55's Avatar
glock35ipsc
I have lived in houses smaller than that & DANGED sure dirtier. A/C in your shop?
Man I as so jelous.
chevyboy55 is offline   Reply With Quote
Old 12-06-2005, 07:18 PM   #14
glock35ipsc
Originally Posted by chevyboy55
A/C in your shop?
I just had to!! I was at Sears shortly after I got it done, and they were clearing out their last-years models of those big 220VAC A/C units for 75% OFF!!!!!
For that price (about $150), I had no choice but to buy one
BTW - It's not that clean now!!!
Bob
Old 12-06-2005, 07:27 PM   #15
Joesjunk
Joesjunk's Avatar
Here is my detached shop, no room for work there!! I actually work in my basment garage, It is 24x40 and has a concrete ceiling with garages above it! ( I cant find a pic of it yet)
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 12-06-2005, 07:33 PM   #16
Mine is 24x30 with a 15x18 overhand/carport on the front side. I have a 10' rollup and walkin door on the front and aohter 10' rollup on the side. This was my graduation present (32 years of college ) from me and my wife to me. These are just some shots I had on the computer and obviously not fro the same time.
Old 12-06-2005, 09:27 PM   #17
70c10swb
no brain no headache
70c10swb's Avatar
mines pathetic compared to the ones above. This is when i first put it up
1996 GMC Sierra z71
1970 SWB 2wd (project)
70c10swb is offline   Reply With Quote
Old 12-06-2005, 09:39 PM   #18
mrein3
mrein3's Avatar
Here's mine.
25x35 with a 6' overhang all along the south side. When I bought the house (I bought the shop, the wife bought the house) I thought that overhang was stupid. However I store a lot of crap under there that doesn't need to be inside but does better without rain and snow falling on it.
If I built it I would have made it 16 to 24 feet longer. Right now I can store my two Chevelles in there and work on the truck in the middle. During fishing season when the boat is on the trailer alot I park the truck in the attached garage and park the daily driver outside.
Some day I may enclose the overhang and extend the floor over there. However that outside storage is growing on me.
It has no heat. Yet.
BTW that is an old picture, taken right after we moved in. All the boxes are gone and the Triton is in storage for the winter at the farm across the road.
'70 cab, '71 chassis, 383, TH350, NP205.
'71 Malibu convertible
'72 Malibu hard top
Center City, MN
mrein3 is offline   Reply With Quote
Old 12-06-2005, 09:33 PM   #19
nwmod39
nwmod39's Avatar
hey glock;
is that an engine stand with a transmission adapter to hold it?
thats a sweet deal if thats what it is.
nwmod39 is offline   Reply With Quote
Old 12-06-2005, 09:39 PM   #20
glock35ipsc
Originally Posted by nwmod39
hey glock;
No special adapter. The arms were already set for a Chevy engine, I just bolted the tranny right onto it. Slid it out onto the tailgate, bolted the thingy onto it, and slid the stand on.
Bob
Old 12-06-2005, 10:14 PM   #21
Chevy_Man
Tightwad
Chevy_Man's Avatar
Hey guys keep them coming , love all the shop pics, I am thinking of going with a 30x40 x12 with two 10x10 roll up doors at each in wall and a walk through door on one side. Just need a few ideas on how some out there looked with truck work in process and how much room was left.
Eric
Old 12-06-2005, 11:30 PM   #22
Joesjunk
Joesjunk's Avatar
Here is where I work. I had the house designed with this garage in the basement. It is 24x40 and I can put 4 trucks in there. It has a concrete ceiling and I have garages above it. There isn't alot of extra room (with 4 trucks in there), but it works for me.
Old 12-06-2005, 11:41 PM   #23
DucksChevy
DucksChevy's Avatar
My garage is more or less storage for tools and parts. Truck won't fit in there, the Camaro will fit but I can't walk around it.
Garage is only about 14'x22' but I have a concrete slab that I work on right next to the garage which is about 20'x20'
DucksChevy is offline   Reply With Quote
Old 12-07-2005, 12:38 AM   #24
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
I built one in Texas that I had to leave. 24X36 with 2 10 foot doors and 2 walk in doors. It was too short. With a 6 inch wall your real size is 23X35. When I do it again it will be a minimum 30X40. Oh and go as high as you can on the walls and ceiling.
Just my thoughts.
low'n slow is offline   Reply With Quote
Old 12-07-2005, 01:27 AM   #25
longhorn71
longhorn71's Avatar
I got a late start on my this year.The cold and snow has stopped work on it until next year but it will be 60x60 with a 15'ceiling.I got the ground work done and the poles cemented into the ground before the snow hit
longhorn71 is offline   Reply With Quote
