Old 11-09-2011, 11:02 PM   #51
fixit-p
fixit-p's Avatar
Re: Driveline Vibration
If your measurements are accurate.
trans- down 2*, front shaft down 3*, back shaft 0*, pinion up 4*.
Then the operating angle of the first U-Joint is good @ 1* the pinion should be parallel with the first drive-line (3* up) which would make the operating angles of U-Joints 2 & 3 equal at 3*. Alternately you can lower the first drive line down to 4* which would cancel out the pinion angle but make the operating angle of U-Joint # 1 @ 2* and U-Joints 3 & 4 @ 4*. At 4* operating angle you can start to see the life of the U-Joint be compromised but you shouldn't see any vibration because of pinion angle.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
Old 11-10-2011, 11:00 AM   #52
Dunenutt
Newbee
Dunenutt's Avatar
Originally Posted by Street Smart View Post
^^^^^^^^^^^^^ great pic! and info.
Its hard to get an accurate place to measure the trans angle, nothing looks parallel to the output shaft. So i figured where the bellhousing mounts to the block should be perpendicular, safe to assume?
Use the crankshaft pulley for the trans angle. it is the most accurate.
Dunenutt is offline   Reply With Quote
Old 11-10-2011, 02:18 PM   #53
Street Smart
Street Smart's Avatar
That would be good but i have a mechanical fan and shroud, kinda hard to get in there.
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile*
1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig.
http://67-72chevytrucks.com/gallery/...=74049&cat=500
Street Smart is offline   Reply With Quote
Old 05-04-2012, 08:48 PM   #54
suttoncurt
suttoncurt's Avatar
Any updates on this subject - My truck is static dropped 5 1/2'' front and 7'' rear and I have a vibration around 60 -70 mph ?
suttoncurt is offline   Reply With Quote
Old 05-04-2012, 10:05 PM   #55
Street Smart
I still have the vibration in my Suburban. I tried different angle shims at the rear, didn`t help. My next move is to either cut the floor and raise the back of the tranny, or getting a driveshaft made with a C.V. joint to eliminate one of the angles.
Keep me posted if you figure something out.
Old 05-05-2012, 11:37 AM   #56
suttoncurt
suttoncurt's Avatar
Hmm... Man this can be a hard thing to figure out . I'm getting ready to go on the HRPT so I have until June to play with diff angle's . I'll report my findings here . Thanks for the reply man
