Old 05-29-2020, 11:04 AM   #1
Afirehawk1
Factory Tach and MSD AL6 connection
There is a grey wire that goes to the Tach i think
I read this but little confusing
Any thoughts where to connect when running a factory tach
Afirehawk1 is offline   Reply With Quote
Old 05-29-2020, 03:50 PM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: Factory Tach and MSD AL6 connection
To a tach filter, then to the tach input wire?
Old 05-29-2020, 04:42 PM   #3
Afirehawk1
Greek to me
Says trigger wire
Im better at following a wire diagram
Old 05-29-2020, 05:41 PM   #4
Afirehawk1
Originally Posted by Afirehawk1 View Post
Greek to me
Says trigger wire
Also what is best location for these 2 wire from the MSD box
Again i have a factory tach in place
Old 05-30-2020, 08:32 AM   #5
The Rocknrod
Moderator
So looking at an online wire diagram (correct part number?). Looks like the red is a power lead and the gray is a tach feed. However there is a red ignition feed.
So my guess would be that the two wires bundled together would be ignition and tach.
(The reason I said tach filter is the pulses may not work for the older model tachs. Try it without the filter first then).
If your going points here is the diagram, not sure of your part number though:
Old 05-30-2020, 10:39 AM   #6
Afirehawk1
Ok so i found this on page 5 of 24 in the instructions.
2 large wires red and black appear to be power feeds.
I think i figured that out
The small red and grey are the 12v ignition and the Tach trigger wire.
Its the grey trigger wire.
Where exactly does this connect to??
Old 05-30-2020, 10:54 AM   #7
The Rocknrod
Moderator
I would think the Tach trigger is what sends the tachometer the pulses that make it read how many RPM there is.
Dont confuse that with a Crank Trigger.
Old 05-30-2020, 12:09 PM   #8
Afirehawk1
I understand
But Where does it physically connect?
Old 05-30-2020, 05:47 PM   #9
jayoldschool
Moderator
There are typically four connections on a tach:
- power
- ground
- illumination
- signal
Connect grey to signal.
jayoldschool is offline   Reply With Quote
Old 05-30-2020, 06:46 PM   #10
Afirehawk1
- power
- ground
- illumination
- signal
Oh now i see it
Much appreciated!
