Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1969 - 1972 Blazers and Jimmys Message Board > 1969 - 1972 Blazers and Jimmys Projects and Builds
Old 06-26-2015, 10:57 AM   #2551
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
WIN_20150626_105028 by James Jaros, on Flickr
Test, now I can upload
Semper Fi...Uncle Sam, you da man
All parts offered to help are free, unless otherwise noted
Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training
SAFETY FIRST
AS usual, off topic
They say your mind goes second, can't remember the first
Jim
jaros44sr is offline   Reply With Quote
Old 06-26-2015, 12:05 PM   #2552
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
https://www.flickr.com/photos/973911.../shares/X997aN
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2015, 02:12 PM   #2553
71jimmy
71jimmy's Avatar
Re: PO has me PO'd
Question regarding your Bilstein install. I just installed a set on my Jimmy. I installed them with the black boots facing down since the Bilstein sticker would be upside down otherwise. No install info came with the shocks. I had my previous shocks mounted like yours with the boot up. I've seen shocks installed either way so don't know if their is a right or wrong. Do you know of any advantage/disadvantage to either way of installing them?
'71 Jimmy, 350, SM465, NP205, 2in Tuff Country lift, 33s on rallies, TBI, softtop and hardtop
"If life was fair you'd be able to afford one of each and a garage large enough to house them all."
71jimmy is offline   Reply With Quote
Old 06-26-2015, 02:28 PM   #2554
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Good question, dunno, but I will call Bilstein come Monday. Just think they look better with the boot up
SAFETY FIRST
AS usual, off topic
Jim
Old 06-26-2015, 02:38 PM   #2555
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ok, just talked to Bilstein, you re right, shock should be installed with correct orientation to the sticker. Guess I have to change mine and ty for bringing it to my attention
SAFETY FIRST
AS usual, off topic
Jim
Old 06-27-2015, 10:08 AM   #2556
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Pic
WIN_20150626_114951 by James Jaros, on Flickr
SAFETY FIRST
AS usual, off topic
Jim
Old 06-27-2015, 01:54 PM   #2557
swamp rat
swamp rat's Avatar
Re: PO has me PO'd
are the Bilsteins gas charged? My Fox shocks are and they mount with the body up.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 06-28-2015, 08:29 AM   #2558
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just went and looked, shocks are mounted correct with sticker readable in the down position, boot up.
May have run into another problem, as one of the brake drums seems to have a crack running all the way around it
SAFETY FIRST
AS usual, off topic
Jim
Old 06-30-2015, 11:01 AM   #2559
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Just gotta say rock autos return policy is second to none... called them with complaint, they emailed a shipping label, dropped the part off at FedEx, new part is on the way. They paid postage both ways, what a company, will buy from them again
SAFETY FIRST
AS usual, off topic
Jim
Old 06-30-2015, 11:06 AM   #2560
richard2717
Equal opportunity joke ofender
richard2717's Avatar
Re: PO has me PO'd
Did you notice the crack before you painted it? That probably would not make me happy if I saw it afterwards
Members I have met.
Dually Jams, OlBlue60, ScottH, Tommyboy24, Dujobo, Warbucket, 2003 Silverado, Notsolo, my90k5, 6t727t2, Special-K ,Jack_71C10, tabarcus,72blazer_mud_bogger,pwdcougar,RSavage,EricSean,1Rippen6,invicta455,tennaragtop71,arks, Kendal,Bennett68C10, Perpendicular, Chainsawman, McGeesCustomMinis,ShortbedClayton,longblue72,6768chevylover,Tim71,Travisarmenta,Ol' Drippy,fleetmitch,georgieb51,Dave,bcnya2,Dadsburb
https://paypal.me/6772GMtruckparts
Most women like the strong, silent type… Fortunately for me, my wife prefers the out-of-shape, mouthy type.
richard2717 is offline   Reply With Quote
Old 06-30-2015, 12:18 PM   #2561
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Richard, no not until after I painted it, lost about 40.00 worth of high temp. paint on it
lesson learned, inspect parts
SAFETY FIRST
AS usual, off topic
Jim
Old 07-05-2015, 08:30 AM   #2562
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Ok, second part arrived, still cracked, they want to refund my money, but I still need a drum. So, I will try a AC Delco part this time and the heck with Raybestys
SAFETY FIRST
AS usual, off topic
Jim
Old 07-08-2015, 09:52 AM   #2563
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
First attempt to mount dual handbrakes
WIN_20150708_094308 by [url=https://www.flickr.com/photos/97391199@N06/
SAFETY FIRST
AS usual, off topic
Jim
Old 07-08-2015, 10:06 AM   #2564
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
WIN_20150708_100246 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 07-09-2015, 12:49 PM   #2565
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Rather then risk ruining my good console bottom, pulled a POS one off the shelf and cut into that, glad I did, because my cuts were a bit excessive. I may have to use the 73 and up bracket on the front of the console to elevate it a bit
WIN_20150709_124437 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 07-23-2015, 11:37 AM   #2566
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Third time was a charm on the brake drum, but went with AC Delco this time, still Chinese but better quality
Anyway, did some more work to the dual handbrakes, adjuster screw installed, now to figure out what length to make cables
WIN_20150723_101746 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 07-24-2015, 12:40 AM   #2567
mcmlxix
Collector of Projects
mcmlxix's Avatar
Re: PO has me PO'd
...maybe I missed it... but what's the reasoning behind dual hand brakes?
Rich
1972 K5 Blazer CST Click HERE
Old 07-24-2015, 08:20 AM   #2568
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Rich, let me see if I can explain, if you re in the woods wheeling, and if you need to avoid a tree or rock you can make a tighter turn by putting truck into 2wd front axle, lock up one rear brake and turn to that side. Truck pivots on rear axle
SAFETY FIRST
AS usual, off topic
Jim
Old 07-24-2015, 08:33 AM   #2569
mcmlxix
mcmlxix's Avatar
Re: PO has me PO'd
Cutting brakes. Got it. Isn't it usually done with hydraulics and not mechanical? I'm the furthest thing from an engineer but isn't that putting a lot of stress on that mechanical linkage?
Rich
Old 07-24-2015, 10:36 AM   #2570
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
In pa. We aren t allowed to cut brake lines or splice. VT Blazer did his with solenoids and its easier. My two sons are mech. eng. So I ll run it by them to give you an answer
Sorry to hear about your setback with the flood, hope it all works out for you
SAFETY FIRST
AS usual, off topic
Jim
Old 07-24-2015, 11:26 AM   #2571
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Finished up one cable shroud, need some extension springs to take up slack
WIN_20150724_111427 by [url=https://www.flickr.com/photos/97391199@N06/]
SAFETY FIRST
AS usual, off topic
Jim
Old 07-24-2015, 01:44 PM   #2572
71jimmy
71jimmy's Avatar
Re: PO has me PO'd
Thanks for making that call, I just wasn't sure which way was correct mounting, most shocks I've seen (and had previously installed) I mounted like you did.
Swamp Rat had posted "are the Bilsteins gas charged? My Fox shocks are and they mount with the body up."
Yes, "5100 Series shocks use Bilstein's mono-tube high gas pressure design for consistent fade-free performance & long life."
Soooooooooooo, I've learned something new. It's a gas thing!
Thanks everyone
Old 07-25-2015, 09:17 AM   #2573
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
Thanks everyone
You re welcome, I was concerned after you said something, so I had to find out for myself. You guys keep me on my toes
SAFETY FIRST
AS usual, off topic
Jim
Old 07-26-2015, 07:58 PM   #2574
AJs72K5
AJs72K5's Avatar
Re: PO has me PO'd
I cut the boots off of mine. Looks better and ensures junk doesn't get trapped in the boot, eating up the shaft. Keep up the progress Jim.
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 07-26-2015, 08:27 PM   #2575
jaros44sr
jaros44sr's Avatar
Re: PO has me PO'd
interesting AJ, never thought of getting rid of the boots, thought they helped with keeping crap out. I ll take one off and see what they look like
Progress is slow at best
SAFETY FIRST
AS usual, off topic
Jim
