07-04-2020, 01:17 PM | #1 |
Walbro 450 with factory EFI hanger PSA
I posted this in the sloppy mechanics private FB group, but I wanted to put this here as a PSA.
My turbo LS C10 has a Walbro 450 in a factory 88 EFI blazer tank. The pump is on the stock hanger and 25a fuse, 12ga wire/relay to the sending unit. I lost all fuel pressure the other day. Turns out the pump is fine, but the factory bulkhead connector nearly caught on fire. I was thinking about redoing the tank setup anyway, but just a PSA that the Walbro pump (or any moderate/big HP pump) may draw more amperage than ANY factory wiring can handle.
-- Josh Instagram: @americanmusc1e OLD SKOOL-- 1970 C10. 454/Th400/3.07 posi Build Thread FARM TRUCK----1949 Chevrolet 3800 Power Wagon Hauler Build Thread 1999 4wd OBS Tahoe - daily. DM me if you can't see photos i posted |
07-04-2020, 10:21 PM | #2 |
60-66 Nut
Re: Walbro 450 with factory EFI hanger PSA
That could have been bad.......
07-04-2020, 10:31 PM | #3 |
Yeah I'm not a fan of sketchy wiring heating up inside my fuel tank. That's why I posted. To hopefully save someone else from burning their truck down.
07-05-2020, 12:51 AM | #4 | |
BMW & ASE Master Certified
It's as simple as not knowing. Not knowing what the capacity of that terminal can handle which is 14a and the current draw of a 450 which can be found easily. Which is why I made these hats, fits stock tanks, proper terminal rated for 30a A closer shot of the roll over valve.. cheap mild steel ball got replaced
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress |
07-06-2020, 05:14 PM | #5 | |
07-07-2020, 02:20 AM | #6 |
High amperage draw with the aftermarket pumps is only one reason I chose to use a factory PWM pump for my LS swap.
Richard 1972 K10 Custom Deluxe SWB Fleetside My build https://67-72chevytrucks.com/vboard/...d.php?t=800746 |
07-07-2020, 10:02 PM | #7 | |
That's just fine until you have 80lb injectors to feed
07-10-2020, 03:35 AM | #8 |
I do not have a race car. The guy at Vaporworx has said that the CTS-V pumps will handle 80 lb injectors with his controller and dual pumps will do over 1000 hp.
07-10-2020, 01:34 PM | #9 | |
A quick google search says the factory CTS-V uses dual bosch pumps with around a 20A draw at 60PSI. According to 87chevy that is still more than my factory 80's blazer wiring bulkhead will do. Although it's less than the 25+ continuous amps of the Walbro 450. What kind of tank are you using?
07-11-2020, 02:21 AM | #10 | |
