06-17-2020, 03:30 PM | #1 |
Cam Change
I'm considering changing out the cam in my new GM SP350/357 crate motor. I'm not really liking the idle and would like to smooth it out. I've narrowed it down to the cam in the Ramjet 350/HT383 crate engines #14097395. Really would like not to loose too much if any at all for normal driving.
Terry 1970 Custom Camper/C20 , GM Crate 350/7004R, Dana 60, factory AC |
06-17-2020, 03:45 PM | #2 |
Moderator
Re: Cam Change
Is the SP350/357 radical cam like? or what?
06-17-2020, 05:13 PM | #3 | |
Re: Cam Change
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
06-17-2020, 07:00 PM | #4 |
Re: Cam Change
Its not a big cam in that motor. What intake, carb, convertor and timing are you running?
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
06-17-2020, 07:57 PM | #5 |
Re: Cam Change
The cam currently in the motor is 215/223 at .050 with .473/.473 lift (1.5 rockers) and 108 LSA. This makes it not idle quite so smooth. It has lots of power especially from 2K up. I'm running 10 initial with 22 advance, ported vac advance and a Holley 670 carb. All of this was setup by Westech on a chassis dyno. Running a 2004R with stock torque converter. The idle is not real bad but vacuum is about 11 inches in drive 14 in neutral and you can actually see the vacuum bounce around with the bumpy idle. Would really like a smoother idle. Didn't know this was the case when I bought the motor.
06-17-2020, 08:08 PM | #6 | |
Moderator
Re: Cam Change
Family and country before all others... 2006 Chevy Silverado (Daily Driver) 2012 Chevy Equinox |
06-17-2020, 10:04 PM | #7 | |
Re: Cam Change
This is straight from the paperwork that came with my motor: Set spark timing at 32o before top dead center (BTDC) at 4000 RPM with the vacuum advance line to the distributor disconnected and plugged. This setting will produce 32o of total advance at wide open throttle (WOT). The HEI vacuum advance canister should remain disconnected. This engine is designed to operate using only the internal centrifugal advance to achieve the correct timing curve.
06-17-2020, 11:40 PM | #8 |
Re: Cam Change
Whats the base timing at idle? That is not a big cam at all and should have no vacuum issues. I have 250 duration cam in my truck and still have vacuum brakes that work. It sounds like you need a recurve of the distributer. I would hook the vac gauge back up and twist it to you get a good vac reading then limit the advance to the 32 degrees you want overall. Once the curve is set you can play with the vac advance if you like. I dont have it hooked up on my truck and milage is horrible. 7.5mpg on a good tank! I am willing to bet that it will run better with vacuum advance when the curve is set up correctly and gain a little mpg as well. I would not listen to GM here unless it is a track only vehicle. They are not always correct.
06-18-2020, 07:19 AM | #9 |
Re: Cam Change
I can't imagine running a street engine without vacuum advance. I guess the "experts" know best.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
06-18-2020, 11:07 AM | #10 | |
Re: Cam Change
06-19-2020, 09:14 AM | #11 |
Re: Cam Change
You are correct about lobe separation but it is not a huge affect. My cam idles like crap and is a tuning nightmare but was designed for circle track. Its in the 250s for duration on a 106 separation angle solid cam. Idle is below 1000 rpm and will still run the factory power brake system on my 72 k20. I have no choke and first start at a low idle speed is the only time I have an issue. I typed this out to illustrate that you should not be having vac issues like you say. I have done everything possible to make the system not work. You are on the right track now. Good luck.
06-19-2020, 10:13 AM | #12 |
Moderator
Re: Cam Change
Well I'm keeping my eyes peeled on this thread cause that engine is my engine of choice for my 64. Keep us posted please.
06-19-2020, 12:16 PM | #13 |
Re: Cam Change
One thing I forgot that may be at fault here. Reset your valve lash to double check you don't have a valve not seated all the way. An overly tight valve will cause the vacuum gauge to bounce and low vacuum.
06-19-2020, 04:54 PM | #14 |
Re: Cam Change
I'm LS engine guy and the LS cam guys would say a LSA of 108 is going to give you choppier idle. I would all suggestions above to see if it will make it livable as is. If not look at a cam with similar duration and lift but maybe 110-112 LSA.
06-19-2020, 08:04 PM | #15 |
Re: Cam Change
To be clear, the idle is not real bad, just have gotten use to modern cars where you don't even feel the engine idle. Never stalls, just a little bumpy.
I have already readjusted all the valves 1/4 turn from 0 lash per the documents. Yesterday I pulled all the plugs check them and reset the gap to a specified .040. They actually looked pretty good with a few thousand mile now. Light brown on on side of the porcelain insulator. Adjusted the timing to 12 BTDC and adjusted the idle and idle mixture a bit. Also made sure I had no vacuum leaks at the carb base and hoses. Very little change. I have about 15 inches at idle in park which is about 800 rpm. In drive 625 rpm and 10-11 inches of vacuum. If you have a manual trans or maybe a looser torque converter it might be a bit bitter. Still looking at all options.
06-19-2020, 08:47 PM | #16 |
Re: Cam Change
It would be interesting to see what would a looser? converter would do. I run a 3000 stall converter in my 68 LS C10. It's somewhat tight and some what expensive converter (about $450-500) that drives like a stocker until you lean on it. I like Yank and Circle billet converters. There are others out there that just as good. A stock 200R converter has a stall speed of maybe 1800 rpm?
06-19-2020, 09:54 PM | #17 | |
Re: Cam Change
06-19-2020, 10:16 PM | #18 |
Re: Cam Change
I higher stall should have more slip thus less creep. A big part of this is torque at low rpm. The more torque the quicker the convertor will work. This means a 3k stall may come in at 2600 on one motor or 3200 on another. I am a stick guy but that is my understanding.
For fun run your motor up to about 18 or 20 degrees of timing and see if there is any more vacuum to be had. I. Eleven that you are about maxed out and will only find 1 or 2 more inches of vacuum. If you are lucky. A 112 or 114 grind will probably net about the same gain. Honestly as small as that can is you need to see the valve timing and compare the valve overlap and intensity of the lobe. This will tell you if a cam change will really do anything for you. A valve barely off its seat will have less lump than one that flies open a few degrees later since the valve is further off its seat. Dont forget that getting that wide separation angle will make a longer power curve but less power overall and probably weaker off of a turn. LS cam timing is nothing like a factory sbc. They did some crazy things with lift, lobe angles and duration that would have blown cam grinders minds just a couple years before they hit the market. They really optimized the better flowing heads of the LS for a production motor. They also make their low end grunt a little higher up the rpm band. |
06-20-2020, 04:31 PM | #19 |
Re: Cam Change
Yeah the cam I have in my 68 LS swap is 220I/226E with 590 lift and LSA 114. Has a bit of a chop at idle. With the 3000 stall converter it has a bit of creep at idle. Runs the power brakes just fine.
I think it would be worth the time to call Yank or Circle and see what they recommend. If you haven't driven something with a good stall converter I think you be impressed how the converter allows the engine to rev a bit more to get more into the power band of the engine. They create a bit more heat so run a good trans cooler. And as said above with lock up it won't slip going down the highway. |
06-20-2020, 11:08 PM | #20 |
Re: Cam Change
a higher stall converter may be something to look into. Actually easier to change the tq than the cam, at least for me.
I do have an update, bumped the timing up 2 to 12, and messed with the idle mixture screws. Thought I had it at best lean idle, then put it in drive and wow it was really bad idle. I had it at 625 in drive. Started turning the idle screws out to richen the mixture and it smoothed out quit a bit. In park you can hardly hear a lope. In drive it is still not real smooth but not bad and a consistent lope now not what it was before. It also brought the idle speed up and I had to lower it a bit. Going to drive it a bit and see. Defiantly better throttle response. Now I know what the guy that did the dyne run was tasing about. He mentioned it like it a bit richer than normal. I'm probably now have the idle mixture screws close to what he had them adjusted to. If I remember he had them out about 4 turns out, I have them at 3 1/2 now. Wishing now I had forgone the deluxe model and bought my own intake, distributor and a Holley Sniper EFI unit.
06-21-2020, 12:10 AM | #21 |
Re: Cam Change
Now for fun hook up the vac advance and see if that helps the idle in gear. Just make sure its on manifold vacuum. It may need a advance limiter being that the heads don't need as much overall timing.
06-21-2020, 12:23 AM | #22 | |
Re: Cam Change
http://www.crankshaftcoalition.com/w...EI_distributor |
06-21-2020, 05:05 PM | #23 |
Re: Cam Change
Back in the day I was a line tech a Chev dealer ship. We were taught to use a vacuum gauge to adjust the idle mixture screws. Back the screws out and then turn one until the vacuum drops and then turn it out 1/4 turn or so. Then do the same thing with the other screw. Go back and forth to achieve the best vacuum. You can do do the same thing by ear. Just turn in the screws until it stumbles a bit, then back them out a bit going back and forth a needed.
06-21-2020, 05:34 PM | #24 |
Moderator
Re: Cam Change
I wonder if the PCV has anything to do with it? Maybe this would help? - http://67-72chevytrucks.com/vboard/s...d.php?t=787630
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 06-21-2020 at 05:54 PM. |
