Old 03-15-2019, 12:02 PM   #1
wilkin250r
wilkin250r's Avatar
Pros and Cons of fuel return line...
So my street-ready restoration project is nearing some final details. It's a 72, but I don't think the tank is original because it was my understanding that 72 had a vent line on the top of the tank, and mine certainly does not.
However, it DOES have a return line that is currently just hanging out in the engine bay, and pukes fuel if you fill the tank up all the way. I assume it was originally hooked to a fuel pump with a return line, but that fuel pump left eons ago with the old engine. Current fuel pump has no provisions for a return.
I've heard of people hooking up the return line to a "T" fitting with a small orifice, and this logic makes sense. I can certainly see this eliminating vapor lock at the carb. Am I more likely to get vapor lock from tank to pump, or pump to carb?
So my options would be to just plug the line, replace the fuel pump with one designed for a return line, or hook it up near the carb with a "T" fitting.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
Old 03-15-2019, 03:06 PM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Pros and Cons of fuel return line...
I eliminated the return line on my 1972 GMC C15 and capped it off at the tank. I left the EEC hooked up and use it as a vent along the passenger side frame rail. I also switched to a vented fuel cap, just in case.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 03-15-2019, 06:56 PM   #3
Steeveedee
Who Changed This?
Steeveedee's Avatar
Vapor lock occurs in the suction line from the tank to the pump. If it were mine, I'd use the recirc line style fuel pump. I have a small booster electric fuel pump to pressurize the fuel pump suction line to reduce vapor lock, since my truck does not have a recirc line.
~Steven
Simi Valley, CA
Old 03-15-2019, 06:59 PM   #4
rjs53
I would keep it. You could cap it off and make a vent out of it like gasoline said. If you ever decided to do an grade in the future and needed more fuel you'll already have a return line.
2003 Dodge 2500
1969 C10
2014 Camaro SS/RS/1LE
rjs53 is offline   Reply With Quote
Old 03-20-2019, 10:20 PM   #5
El Dorado Jim
x2 get a fuel pump that has the return line, it will keep from getting vaporlock, I did this on my son's truck
El Dorado Jim is offline   Reply With Quote
Old 03-21-2019, 01:58 AM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I'm restoring mine without the return line, which is 71 prior. Takes a different gas cap than 72 too. It didn't have a return when I first got the truck, and never locked up. If it vapor locks I guess I'll need new from the sender to the carb.......Fun.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 03-21-2019, 10:55 AM   #7
68 P.O.S.
On my 72 I installed an Edelbrock fuel pump that doesn't have a return line. All I had to do was cap off the return line and add a vented gas cap.
72 C10 lwb fleetside -stock 350/350 combo
68 P.O.S. is offline   Reply With Quote
Old 03-21-2019, 01:26 PM   #8
71CHEVYSHORTBED402
I wonder how many of "us" don't have a return line and experienced vapor lock?
Tony
Old 03-21-2019, 03:31 PM   #9
68 P.O.S.
Not it
Old 03-21-2019, 05:09 PM   #10
Steeveedee
Who Changed This?
Steeveedee's Avatar
My '70 does not have a recirc line, and if it gets hot enough it will vapor lock. Running the electric fuel pump to pressurize the fuel to the pump helps. It was hot out, but I wasn't even using the AC. It's why I'm nailing every opportunity for cooler running. That specific case, the fan clutch had given up the ghost, though.
~Steven
Simi Valley, CA
Old 03-21-2019, 06:45 PM   #11
GASoline71
GASoline71's Avatar
I was thinking the same thing. I've been playing with GM trucks and cars for many years and have never had to use a return line for any reason. Not saying that some might need to use a return line for whatever reason. But in my experience, i have eliminated the return line (usually becuase I have insyalled a performance mechanical fuel pump) and have just switched to a vented gas cap, and wah-lah...
Gary
Old 03-21-2019, 11:20 PM   #12
71CHEVYSHORTBED402
Gary
What's a performance mechanical pump Gary, can you be more specific?
Tony
Old 03-22-2019, 09:45 AM   #13
gvw5400
gvw5400's Avatar
My experience was the same as GASolene71, but that was in the days before ethanol
was added to everything. It is much more difficult to drive anything carbed now.
My truck Will vapor lock if it gets in ANY town traffic,( two red lights and party over)
After finding a alcohol free fuel source it has no issues at all!
But it's a giant PIT* to have Two stations within 40 miles to fuel from.
All the Best, Dirk
gvw5400 is offline   Reply With Quote
Old 03-22-2019, 02:00 PM   #14
71CHEVYSHORTBED402
All the Best, Dirk
Don't know how accurate this site is, but..................https://www.pure-gas.org/index.jsp?stateprov=NV
Tony
Old 03-22-2019, 05:34 PM   #15
gvw5400
gvw5400's Avatar
71Chevyshortbed402
The puregas site is good and accurate for the most part in Colorado.
I'm curious about the EEC lines and routing also, My 71 350 has the carbon canister and lines but not the return line at the pump.
If I can make sense of it, some repurposing may be in order! it would be great to refuel
anywhere and have a drivable truck in traffic!
Old 03-22-2019, 08:11 PM   #16
71CHEVYSHORTBED402
71Chevyshortbed402
They didn't put in return lines until 72. Speaking for a 72 402, per the parts book they were required for TH transmissions only. I'm still on the fence.
Tony
Old 03-23-2019, 07:54 PM   #17
gvw5400
gvw5400's Avatar
I guess that's why my 71 doesn't have a return line !
That's for the info.
It's one more piece of the puzzle.
All the Best, Dirk
Old 03-23-2019, 11:30 PM   #18
71CHEVYSHORTBED402
All the Best, Dirk
I think someone mentioned some SBC had them pre-72. Not sure on that, but the parts book would verify. Edit: I just checked, and 350 didn't have one. In 72 they did for TH transmissions, same as 402.
I'd like to pass on one that's for sure. If there's something to ethanol content, I'll never drive this truck long distances anyway. But then we're at the mercy of how long low-ethanol remains available.
Tony
Old 03-24-2019, 12:08 AM   #19
GASoline71
GASoline71's Avatar
Yep... aftermarket fuel pumps that put out more GPH and a tad more pressure than stock. I have used Carter "street" (now "muscle car") and "strip" mechanical fuel pumps for ages.
Gary
Old 03-24-2019, 02:41 AM   #20
71CHEVYSHORTBED402
Gary
Thanks Gary
Tony
