10-28-2013, 01:45 AM | #1 |
66 327 fuel pump number
Does anyone know the correct AC fuel pump for a 66 with a 327? I know that is probably a four digit # stamped on the mounting flange. Plus pump is bolted together instead of crimped. Collecting up all the parts so I can put the original 327 back in some day.
10-28-2013, 10:44 AM | #2 |
Re: 66 327 fuel pump number
Here's what I've come up with searching through a 1966 GM parts book and a 1970 Chevy parts book and history book. This first one I believe is assembly line correct and was discontinued around 1968 according to my parts history book. According to the parts book description it fits "ALL 283 327 and 409 with FOUR barrel carb".
5621665 4657 http://www.ebay.com/itm/65-1965-Corv...#ht_185wt_1162 This one was the replacement after 1968. 6415616 40018 http://www.ebay.com/itm/NOS-1959-196...ht_1061wt_1162 If anyone has information to the contrary Im all ears, it would be nice to see an original.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778 The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839 WANTED : 1963-1966 6 Cylinder Fan Shroud WANTED :1964-1966 PANEL TRUCK |
10-28-2013, 12:09 PM | #3 |
Thanks, I will have to start looking for a core to rebuild. The corvette guys go nuts on Ebay on that stuff. I should know as I did a numbers matching 61 fuelie years ago.
