07-01-2014, 11:46 PM | #1 |
86 k10 motor mounts with tranny braces
I pulled my motor out a few weeks back and attempted to install to night but with much difficulty. here is what I have 86 k10 with 350. The motor did not have the tranny braces when removed and I had a set off my parts truck. When installing the motor it just will not fit. ?????? Is there a different in the motor mounts that attach to the block???? I used the original one that was on my truck. Can anyone tell me if there is a difference ?
07-02-2014, 12:36 AM | #2 |
Re: 86 k10 motor mounts with tranny braces
What part will not fit?. Did you install the plates under the clams? Were they there before?
07-02-2014, 06:48 AM | #3 |
the plates were not there before can not get the engine to sit down in correct area. are the clams different ?
07-02-2014, 07:31 AM | #4 |
hard to see
07-02-2014, 11:28 AM | #5 |
If you used the old engine mounts, they are more than likely sagged down. Another thing when you installed the rod plates you moved the cups out 3/16s of an inch each side. You could loosen the mounts on each side and get a big screw driver to get the engine past the notches so they will set down. If the mounts are questionable I would replace and leave then loose until the engine is sitting down
07-05-2014, 09:12 PM | #6 |
the 4x4 mounts with braces are different
07-05-2014, 09:13 PM | #7 |
2wd 4wd
