03-28-2017, 05:05 PM | #1 |
LS swap radiator, other than entropy and R&D
SO after alot of forum searching, it seems like people argue over entropy and r&d. Does any one have experience ordering an ls radiator from summit,jegs, speedway and mocking it up them selves? Other than a plastic radiator from the boneyard? I feel like we could save a few bucks doing it this way. I found a few radiators that seem like they fit, but I never had a stock radiator to get measurements from.
03-28-2017, 06:36 PM | #2 |
Re: LS swap radiator, other than entropy and R&D
I got my rad from Sparkey R&D the quality looks to be good and I have had no problems with cooling "the engine"
. I didn't do my home work and missed that on his ls swap rads the outlets are moved to the passengers side. That made for a nightmare finding hoses that fit. He was no help making suggestions on what could work. In the end 1996 jeep grand Cherokee 4.0 hoses fit great. He did tell me the transmission cooler was moved to the drivers side. That's fine. That makes running the transmission lines a little more difficult. I got over it and the problems mounting the fan shroud. I was very specific when I ordered it that I wanted to use the factory fan shroud and did not want to modify mounts to make it fit. Well it turns out if you have 3 core mounts the fan shroud will not fit. You need 4 Core mounts Here is a picture of my transmission temperature without a external cooler also look at the intake air temperature to have a Idea how hot it was out side. I ended up bypassing the rad trans cooler and went with a B&M super cooler and fan kit. I have a ton of money into my 4l80E and cant risk 220+ temperatures empty cursing the hwy.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
03-29-2017, 10:24 PM | #3 |
I used a stock radiator from 02 camaro, it fits good. I had to drill new holes to use top mounts. But the hose locations, trans fittings, and air bleed hole for heads is where you need them.
04-24-2017, 05:50 PM | #4 | |
http://www.rockauto.com/en/moreinfo....379976&jsn=454 Thinking about this aluminum version... http://www.ebay.com/itm/3ROW-CORE-AL...BY3xa4&vxp=mtr
1968 LWB C20 / AC / Wood Bed Last edited by crakarjax; 04-24-2017 at 06:27 PM. |
03-30-2017, 12:29 AM | #5 |
I'm using an aluminum unit from "speed daddy" on eBay. Comes with trans cooler hookups, bolted up to rad support using stock mounts. Even came with 2 electric fans although I'm still using the lq4 clutch fan. Seems to work fine. For $160 and free shipping it was worth a try and so far so good
03-30-2017, 09:27 AM | #6 |
stock 4 core.
cools fine with an AC condenser and a water-to-air intercooler heat exchanger in front of it. |
03-30-2017, 09:58 AM | #7 |
I used a Summit dual pass radiator with a 16" Spal fan on a couple of applications and they cool very nicely. External trans cooler.
The dual pass has the inlet and outlet on the passenger side for easy hose hook up. |
04-24-2017, 09:49 PM | #8 |
Senior Moment
Exactly what I used. Had Rad shop change upper hose diameter and add steam port. Works perfect. No need to get exotic
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2019 GMC Diesil Dually. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
04-25-2017, 07:58 AM | #9 |
Old member
I haven't had any issues with the radiator at all. All aluminum and no plastic very nice unit.
http://67-72chevytrucks.com/vboard/s...d.php?t=681842
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
04-25-2017, 10:41 AM | #10 |
agreed. everyone is in a rush to buy an aluminum radiator and i'm not sure i understand why. copper is much better at heat transfer / thermal conductivity (by almost twice) versus aluminum and OEM style radiators are normally less expensive and require zero modifications to the truck. <shrug>
04-25-2017, 10:52 AM | #11 |
meowMEOWmeowMEOW
Depending on the year of the truck being swapped, many of us never had a radiator to start, and some of our recipients never had a rad capable of supporting 2 fans or trans coolers etc.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
04-25-2017, 11:45 AM | #12 | |
Old member
My truck ran a factory radiator for years. It ran at 190*-200* all the time. I went to the aluminum radiator and it takes a lot of heat to get it up over 180*. That's running AC full blast. Try and find a full metal replacement radiator with no plastic in it. I'll just about bet you can't find one NEW! I'll also say a new aluminum one will cost less than a all copper new one also if you do find it.
04-25-2017, 12:00 PM | #13 |
I bought the cheap aluminum radiator off of Ebay for the SBC and then bought some coolant hose adapters from a jaguar v8 swap site that fit the hose size I needed. cut off the old and welded on the new.
Cost me like $150 or so when it was done and has worked well enough. There was also a connection I used for steam that was already in the radiator. |
05-26-2017, 12:13 PM | #14 | |
The factory four core in my truck will NOT sufficiently cool my big block with the AC on if it's a hot day. The aluminum two-tube with dual SPAL fans in my Camaro WILL sufficiently cool a big block all day long. Fans don't even come on until you're stopped at a light. That's all I know. Just experience, no theory.
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
04-02-2017, 01:12 PM | #15 |
I used a Spectra cu730 (454 radiator) in my 76. Bought the 454 bushings and a factory 454 top plate. No issues and great fitment.
72 2wd k5 blazer 86 c10 "Red",76 2wdK5 "Bertha",77 2wdK5 "48",79 c10"Buster" GONE |
04-02-2017, 06:05 PM | #16 |
I'm using a Holley frostbite in my 72. It's working great so far.
04-02-2017, 09:59 PM | #17 |
Used a Speedway generic radiator on mine and ran external coolers for the trans and oil.
Just trying to figure this out... 1970 SWB Step-Side http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=584499 1970 SWB One Owner Step Side 6.0 LY6/6L90 http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide http://67-72chevytrucks.com/vboard/s...86#post7531186 |
04-03-2017, 09:58 AM | #18 |
I used an engineered cooling products rad that was built for our trucks and the fitment was perfect. It also came with duel electric fans. So far so good haven't really driven the truck in hot weather yet so I can't really give a total review but for now its been great, no issues.
1978 SWB cheyenne A/C, power steering/brakes, 305, Tach, Gauges 1972 SWB Custom 10, gauges, cammed LQ9, M22 |
04-03-2017, 11:36 AM | #19 |
In my '62 5.3/4L60E I used a champion off eBay...make sure the spouts are welded and not pressed on..worked fine for me..
1962 C10 Longbox LS 5.3 4L60E----Sold$$ 2014 Ram 4x4 3500 Laramie Diesel..Momma's truck 2015 Ram 4x4 1500 1997 Boxster. 1972 K10 Custom Deluxe LS 6.0 1950 GMC 3100 S10 & LS swapped |
04-03-2017, 08:25 PM | #20 | |
http://www.rockauto.com/en/moreinfo....031487&jsn=577
1967 GMC Suburban, Supercharged 6.2 LS with a 6l80e , my 11 second tow vehicle! *pic in my profile* 1987 GMC CrewCab Dually 6.0 LS/6L90e, new tow pig. http://67-72chevytrucks.com/gallery/...=74049&cat=500 |
04-03-2017, 09:19 PM | #21 |
Champion and American Eagle!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
04-15-2017, 11:29 PM | #22 |
I need to order one ASAP. Any other suggestions? I'd love to run a crossflow but I don't think they will fit using the stock battery box location? This is a 400HP LS1 with Vintage Air and a 4l80E
My mother is a recent cancer survivor and this truck build is for her |
04-15-2017, 11:55 PM | #23 |
eBay http://www.ebay.com/itm/351599620760
This is the one I bought and it fits well. I haven't run it yet but I don't forsee any issue with it.
04-18-2017, 07:25 AM | #24 |
Because I'm running a 2010 vette motor I elected to get a 2010 vette radiator and fans but the radiator doesn't have a fill port on it so I looked at dimensions of the 2011 and 2012 vette and camaro radiators. The stock 2011 camaro radiator uses the same hoses as the vette so I bought all new hoses, cap, radiator, and fan assembly for a 2011 camaro and it will all work. I will have to cut up my core support but that doesn't bother me. But it saved me a lot. Entropy was around 850 shipped and rnd wasn't far off. I paid 440 shipped for all new stuff from rock auto, the other cool thing as previously stated was you can see what sizes they are before you buy them
04-18-2017, 10:13 AM | #25 |
I picked up a Northern radiator last year when I had the inline 6. It was cheap, not a direct fit for my 66 but it fit well, and is compatible with the LS swap I'm working on right now. Neat thing about their radiators is that they sell an electric fan setup for each one they make. My buddy has run Northern radiators in 3 of his last 4 projects with no issues.
It's P/N 209676 for anyone that is interested. |
