12-13-2018, 07:00 PM | #1 |
Intake headers LS 6.0 to sm 465 1970 gmc
Good evening everyone,
I've run into a clearance problem involving my exhaust headers with bolting an LS 6.0 to an SM 465 transmission. I was wondering if anyone has encountered this problem or knows of some block hugger type manifolds that they've used in the past on prior projects. The Gen 1 exhaust manifolds, like the ones from the sbc 350, would be perfect as they're a tight fit to the block. I found a pair of Hedman 68520 but they protrude out 4.5 inches out past the frame. I also tried a pair of Hedman 45660 headers but was informed after I tried installing them were for hydraulic clutches setups, not manual clutches. Any and all advice is greatly appreciated, Thank you and Merry Christmas, double |
12-13-2018, 09:01 PM | #2 |
Re: Intake headers LS 6.0 to sm 465 1970 gmc
i used highly modified headers for a LS hummer...ls3 or tbss manifolds might work
12-14-2018, 06:40 PM | #3 |
What transmission were you running with those headers?
12-14-2018, 07:11 PM | #4 |
I don’t have the manual but...I used Sanderson CSLS1 shortie headers. They work well
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 support our troops! |
12-14-2018, 07:15 PM | #5 |
nv4500
12-14-2018, 07:38 PM | #6 |
If those would work I'd install them in a heart beat lol. Unfortunately my clutch fork and linkage is getting in the way of the collector =( but thank you for your help, I appreciate it.
Those look like the Hedman ones i tried. I wish they would've worked because they are a good quality header. Downfall is the clutch fork is getting in the way of the collector =(. I appreciate your help my man, thank you! |
12-14-2018, 10:51 PM | #7 |
I also have a manual clutch...with linkage, clutch fork and all...
The hummer headers drop straight down at the back cylinder and the turn back...they'll clear all the linkage.....would I recommend you try em? Nope...had to do a good bit of modifying The headman claim they'd fit fit but they wouldn't clear the linkage..
12-16-2018, 04:48 PM | #8 | |
So how much modifying did you have to do? I've never installed exhaust headers before so in my mind they're suppose to fit like a drop in; hassle free and all that stuff. Yea I tried those hedman ones as well and scratched my head thinking I was going crazy because im pretty good at putting the square block in the square block and those headers WEREN'T fitting at all. That's when I got on the phone with someone and they said yeeha those are for manual transmissions with hydraulic clutches. |
12-16-2018, 08:24 PM | #9 |
Mine is on a 5.3 but i Used speed engineering ram horns which dropped straight down and missed all of the linkage.
12-16-2018, 08:42 PM | #10 |
No apologies needed.....had to cut the collectors off and turn them....had to notch frame...had to do some tweaking as well....I wouldn't recommend doing what I had to do...try the ls3 or tbss manis and see what you got...or go shorty headers....
12-18-2018, 01:30 PM | #11 |
I used f-body manifolds on my C10, cleared the SM465 hydro linkage.
12-20-2018, 12:07 AM | #12 | |
Restoring it $200 at a time...
Your manifolds look like this correct? Help me out with what you have for a linkage - hydraulic kit or the old GM Z-bar with a ball mounted on the LS? Loren
Charter member of the 'Put the dimmer switch back on the damn floor where it belongs' Society '68 5.3L-4 speed LWB C20; grandpa bought it for the farm in '71. Now LS 5.3, rather than 327. DD '09 Pilot Weekender '65 Skylark 300-4V-4 speed Wife's '07 Lexus ES350; 117 actuator motors and I can't see the engine. Son's '04 F250 SuperCab 6.0 |
12-20-2018, 09:59 AM | #13 |
Here's some pics of one. It might be what you need. My truck has the factory hydro setup being an 86. Occupies about the same space as the manual linkage.
https://www.ebay.com/itm/00-01-02-Ca...-/232250766098 Easy to find these used. |
12-21-2018, 06:23 PM | #14 |
Fabricate till you "puke"
I used Hooker street rod shorties on my swap, along with a set of stainless down tubes (Speed way motors, Summit,Jegs). All of the mechanical linkage will clear, but you need a bracket for the block pivot ball. My engine , is set 1 inch forward , from I-6 spot, & runs a 55-57 bell housing. On the headers, you will need aftermarket wires & sleeves. Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-05-2019, 08:04 PM | #15 | |
I didn't have to make any mods or fabs. Took me a beer to install, so I drank 5 more looking at all that hard work . Now its time for in coils, intake manifold, the software so I can blow something up ^____^ Thankyou everyone for your info and experience on from all of your projects. I greatly appreciate it! double |
