12-24-2016, 11:14 PM | #1 |
Posi rear end
I am looking to put a posi unit into my 12 bolt 1969 step side truck what be a good unit to install if anyone can help me out on this please
12-25-2016, 03:38 AM | #2 |
Re: Posi rear end
I had an Auburn posi put in a 12 Bolt rear on my '67 K/10 Suburban in '96. Also had Moser axles custom cut for that build. [The GM factory was on strike at that time, so I couldn't get OEM axles.] Three years later, the 454 on the Sub had a fire and I ''downed'' the truck. In 2010, I blew out the factory Eaton Posi in the 12-Bolt rear on my '71 GMC Jimmy, so I cannibalized the differential off the suburban for the K/1500. Still on there now. Cuts tight turns.
We could not get the '71's wider rearend to fit on the '67. It's still on jacks until I can rebuild that rear. Also, back in the '80s, I got an Eaton Posi on a 12-Bolt 3.73 rear off of a '69 GMC stepside in a junkyard. It was missing one axle so I got a new one from the Chevy dealer, and had a shop rebuild the carrier with new bearings and install it on my '68 C/10 stepside. Both rearends are still going strong.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 12-25-2016 at 03:48 AM. |
12-25-2016, 09:52 AM | #3 |
Re: Posi rear end
I'm a bigger fan of the Eaton over the Auburn, but I own both. The TruTrac is an interesting choice for a street vehicle as well.
12-25-2016, 10:40 AM | #4 |
Re: Posi rear end
do I have to change the axle to install a posi unit what is the correct size 8.875 I have seen so many posi unit till I was not sure what to buy what is a dura trac
12-25-2016, 10:57 AM | #5 |
Re: Posi rear end
you should not have to change axles , just make sure its a 8.875 for Gm truck application, but also as long as you are going in you might as well change all bearings and seals (rebuild)
12-25-2016, 12:00 PM | #6 |
Re: Posi rear end
Good info I will have the bearing and seals change I get lost on the different types of posi unit I see one on ebay for 400 used but it says it is a Dura Trac I see other that say slip trac what the best one to purchase I am new at this as you can see.
12-25-2016, 12:16 PM | #7 | |
Re: Posi rear end
Most recommended for general use is a clutch based unit. Smooth and rebuildable it is suited for street, drag racing and offroad use. Auburn cone style. Works well but not rebuildable. Like a clutch base unit it is suitable for general use. Gear type. Suitable for street and drag racing. Action is smooth and automatic. Can be designed with different amounts of torque bais. Very reliable. Not the best choice for off road as it can, at times, act like an open differential. Locker type. Most abrupt engagement. Best for offroad or drag car.
12-25-2016, 12:23 PM | #8 |
Re: Posi rear end
great good info thanks everyone for all your support with this task I have a much better idea what to look for now Merry Christmas to all
12-25-2016, 02:22 PM | #9 | |
Re: Posi rear end
On the '67 Suburban, both axles were shot. A PO had already used bearing savers once, and they were totally shot, that's why I had to get the Moser axles. 8.875 is the 1/2 ton carrier size.
12-25-2016, 02:56 PM | #10 |
Re: Posi rear end
I installed the Eaton posi in my truck ...
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-25-2016, 02:59 PM | #11 |
Re: Posi rear end
Duratrac is a brand name. I think Yukons clutch style LSD? You don't need to change axles, but you do need to order the carrier with proper offset for your truck's gear ratio. I think on trucks it's 3.73 and higher numerically for 4 series, 3.07-3.55 for 3 series and less than 3.07 for the 2 series.
12-25-2016, 04:08 PM | #12 |
Re: Posi rear end
is this one a good one as well
GM 12-Bolt TRUCK Posi Unit - 30 Spline - 8.875" Limited Slip - Rearend - NEW Eaton-Style (clutch) Posi Unit - 3.73 & UP Ratios |
12-25-2016, 04:47 PM | #13 |
Chevy guy
Re: Posi rear end
Hi,
I just had a drive line shop install an Eaton posi in my 12 bolt. The shop replaced the axles and bearings and the new posi with new bearings. The total cost was around $1500. No regrets for me. Jon
Tehachapi, Ca 57 BBW shortbed 64 C30 service bed 65 C10 long bed fleetside 70 C10 long bed fleetside 74 C30 flatbed |
12-25-2016, 08:24 PM | #14 |
Re: Posi rear end
Is that the Duratrac? What gears are in your truck now? My 69 short step with 307/TH350 was factory 3.07
12-25-2016, 08:47 PM | #15 |
Re: Posi rear end
this one was a little cheaper it is a Eaton slip
12-25-2016, 11:13 PM | #16 |
Re: Posi rear end
Eaton made the original GM ones and probably has the best clutch type LSD's made today. Good to go.
12-25-2016, 11:30 PM | #17 |
Re: Posi rear end
Not a bad price today, considering I spent about a Grand 20 years ago.
12-26-2016, 10:06 AM | #18 |
Re: Posi rear end
so you thank this Eaton would be a good choice and appears to be the correct fit for my truck I don't thank nothing has every been change in the rear all factory.
12-26-2016, 10:47 AM | #19 |
Re: Posi rear end
Unless I missed it, you haven't said what gears are in your truck. You must buy the right carrier offset for your gear ratio you have, or the one you plan to run. And the two most common gear sets, 3.07 and 3.73, use different carrier offset.
Google is your friend by the way. Google best limited slip and read for days rather than one short question at a time here.
12-26-2016, 11:31 AM | #20 |
Location: Falls City, Nebraska "100 Miles From Nowhere"
Re: Posi rear end
+1 on the Eaton Posi, they were OE on our trucks and muscle cars of the 60's & 70's and still going strong today. The units available today are new and improved with stronger alloys and space age clutch materials making them in my opinion unsurpassed and worth every penny at $400. http://www.drivetrainamerica.com/195...FRCQaQodHAYICQ https://www.ringpinion.com/Technical...sitraction.inc Can you copy and paste the link for the unit you showed? Have to be careful because the $350 dollar units are Asian and are not Eaton units, "Eaton style" is not an Eaton. The unit price I posted above is the lowest price going for the Eaton 12T units. If thats the factory 12-bolt axle under that 69 it will be a series 3 carrier, (3:73, 3:42, 3:08) If we knew what gear ratio you have we can verify what series carrier you'll need. Also, do you plan on reusing your existing gears, or new gears?
And Mike is correct, your existing axles WILL work. ~Ghostrider~
Michael of the clan Hill, "Two Seventy Two's" 71 1-ton Dually 350 4-Speed 71 C/50 Grain Truck, 350 Split-Axle 4-Speed 02 3/4 ton Express 14 Indian Chief Vintage 1952 Ford 8N, "Only Ford Allowed On The Property" "Be American, Buy American" Last edited by Ironangel; 12-26-2016 at 11:49 AM. |
12-26-2016, 11:48 AM | #21 |
Re: Posi rear end
I am not trying to hijack the thread. Just a question. My 67 C10 has 3.73 gears in it. Can I just put the posi unit on? Without pulling the ring and pinon. And if I have to pull the ring and pinion. Can I reuse my ring and pinion?
12-26-2016, 12:57 PM | #22 |
Re: Posi rear end
Google....
But you can remove your existing case with the ring gear, put the new ring gear on the limited slip and re-install. The most difficult aspect of gears is setting pinion depth. This is not touched with just a case swap. You must match backlash and preload on the bearings to what is there now, but that is not hard. But entire books are written on this subject. You either need new bearings on the posi unit or pull and reuse yours. Once again, some special tools involved. Google and read how to do this. Better yet, buy the book. https://www.amazon.com/Chevy-Differe...al+repair+book SO MUCH easier than when I had to figure it out in the late 80's.
12-26-2016, 12:58 PM | #23 |
Re: Posi rear end
Toms67
i believe you will need to remove the carrier unit from the rearend {includes removing both axles} which houses the "posi" or "non-posi" in it. Along with this is the ring gear. then you remove the ring gear from the non-posi unit and install the ring gear into the new posi unit. At that time i believe you will need to remove the pinon gear also only because you will need to reset all the tolerances, ie. backlash and such. i may be incorrect, so if i am wrong please someone chime in here. I did mine, i had 307 non-posi. i bought an Eaton disc style posi, all new bearings and shims, then i removed all the parts from the rearend, cleaned it up and then took it to a guy who does rearends locally and for $250 he put it all back together. I did go with 3:42 gears, little more low end but still some upper end also. |
12-26-2016, 01:29 PM | #24 |
Re: Posi rear end
Thank you very much for the insight. I think I will probably have someone do it for me. Thank you.
12-26-2016, 02:21 PM | #25 | |
Re: Posi rear end
No reason to mess with the pinion.
