Old 12-04-2013, 10:06 PM   #1
tpimuncie
tpimuncie's Avatar
55-59 brake pedal assembly
Whats a nice brake pedal assembly to use on these trucks?
firewall mounting my booster/master assembly thanks in advance
tpimuncie is offline   Reply With Quote
Old 12-05-2013, 02:33 PM   #2
jimig1
jimig1's Avatar
Re: 55-59 brake pedal assembly
I'm using http://www.classicperform.com/Store2/Brakes/5559FMB.htm. This one speedway just came out with http://www.speedwaymotors.com/Univer...bly,73778.html.
55 2nd series Chevy Pickup
2019 Chevy Equinox(Daily driver)
2011 Chevy Malibu (Wife's car)
MSRA Member
I went to a bookstore and asked the saleswoman, "Where's the self-help section?" She said if she told me, it would defeat the purpose.
-George Carlin
jimig1 is offline   Reply With Quote
Old 12-06-2013, 12:11 AM   #3
_Ogre
_Ogre's Avatar
why would you want to do that to such a nice firewall?
shop air compressor timer
Old 12-06-2013, 01:05 AM   #4
tpimuncie
tpimuncie's Avatar
WOW! Killer!
Old 12-07-2013, 11:02 PM   #5
roger55
roger55's Avatar
I also have the CPP setup. It has a few issues that I've had to resolve. I think they should do better with these but, I would still buy it again.
See these 3 posts from my build thread:
http://www.trifive.com/forums/showpo...&postcount=242
http://www.trifive.com/forums/showpo...&postcount=248
http://www.trifive.com/forums/showpo...&postcount=279
roger55 is offline   Reply With Quote
Old 12-10-2013, 01:32 AM   #6
tpimuncie
tpimuncie's Avatar
Ahh i see, thanks for posting pics ^^
Old 12-10-2013, 02:45 PM   #7
_Ogre
_Ogre's Avatar
it's not that difficult to mount a booster in the stock mc location using the stock arm
i used a hydroboost on truk but the small vac boosters mounts under floor just as easy.
this is my bracket, but the easiest one i've seen to date used the stock mc, gutted and the back cut out.
then they stuck a rod thru the mc into the booster mounted on the frame
more pics in my thread i believe
Old 12-10-2013, 03:40 PM   #8
Coupeguy2001
Coupeguy2001's Avatar
I sawed off the reservoir part of the original master cylinder, and used the original pedal mount. I used a 3/8 plate bent to a 90, used a hole saw, mounted the hydroboost on the plate behind the original master with a little longer rod, and then ran all the hydraulic lines in the frame. works great. just needed a disc sander to clean up the saw cuts and a little black paint.
Coupeguy2001 is offline   Reply With Quote
Old 12-10-2013, 07:23 PM   #9
_Ogre
_Ogre's Avatar
coupeguy you maybe the mc mod i was referring to, post up a pic.
your thread link isn't working for me.
Old 12-10-2013, 11:46 PM   #10
1958Warrior
1958Warrior's Avatar
He has an extra http:// in it
try this one Ogre
http://67-72chevytrucks.com/vboard/s...d.php?t=489721
1958Warrior is offline   Reply With Quote
Old 12-11-2013, 11:57 PM   #11
_Ogre
_Ogre's Avatar
thanks warrior; not the one i remember but just as simple
the pics are hard to see but when you realize how simple the idea is
you get that ''duh'' moment
post 59 of coupeguy's build
