Old 06-14-2008, 09:45 PM   #1
1971ChevyTruck
1971ChevyTruck's Avatar
AN fuel fitting question
I need some fittings to finish off my fuel cell. I don't know if the fitting on the tank is an 8n or 10n. Does anyone on here have the outside measurement for either of these so I can check before I order the fittings...
1971ChevyTruck is offline   Reply With Quote
Old 06-14-2008, 11:33 PM   #2
Shane
Shane's Avatar
Re: AN fuel fitting question
8 AN = 1/2" metal tube O.D. with 3/4"-16 threads
10 AN = 5/8" metal tube O.D. with 7/8"-14 threads
here ya go ... AN Chart - tube & threads
Shane is offline   Reply With Quote
Old 06-14-2008, 11:35 PM   #3
1971ChevyTruck
Thanks so much...just wanted to be sure before I spent a fortune on fittings...
Old 06-14-2008, 11:51 PM   #4
sandking
.....I am working on it.....
sandking's Avatar
One way I remember to convert AN to inch is:
Example,
Take the -8 and make it 8/16, break that fraction all the way down to 1/2"
Take the -10 and do the same. 10/16 break down the fraction to the lowest which is 5/8.
It works with every AN. Just add the /16 to it, then break it down.
View my build thread HERE
sandking is offline   Reply With Quote
Old 06-14-2008, 11:54 PM   #5
sandking
sandking's Avatar
I just noticed the chart posted by Shane. Same thing, but if you dont have the chart available, you can easily figure it out with the fraction break down.
Old 06-15-2008, 09:38 AM   #6
bigsnookmaster
bigsnookmaster's Avatar
Trust me, You'll spend a fortune on fittings anyway. Braided fittings and hoses are like a drug,very addictive.I've got a braided radiator hose that I've had in use for 25 years.It's expensive,but worth it.The stuff just doesn't wear out,and looks great.
bigsnookmaster is offline   Reply With Quote
Old 06-15-2008, 11:04 AM   #7
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Shane,
The AN Chart Link you supplied is a great source of information. You should pass that along to Krue so it can be added to the FAQ's link. Thanks,
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 06-15-2008, 05:30 PM   #8
Shane
Shane's Avatar
I can't take credit for the chart. I found it on the Web some time back and posted the link.
Also remember what putting the AN number over 16 then dividing / reducing ONLY gives you the TUBING SIZE ... NOT the thread size.
Old 06-15-2008, 07:54 PM   #9
chevy72blu
chevy72blu's Avatar
Check out your local hose/pipe shop. Their fittings are much cheaper than buying them from one of the auto manufacturers. They wont be all pretty and anodized, but who cares from your cell to filter.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
