Old 08-26-2019, 07:34 PM   #1
MAGGEE
MAGGEE's Avatar
4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
Swapping 2004 lq4 with 4l80e trans into my ‘72 K10 w/ 350/TH350 and NP205 transfer case. Advance Adapters makes a kit to mate the 4l80e to the NP205 transfer case. However, AA says the 4l80e will require a tone/reluctor ring install - which sounds like a pain in the a$$. Is there any way around the tone ring installation?
MAGGEE is offline   Reply With Quote
Old 08-26-2019, 08:29 PM   #2
AussieinNC
Moderator
AussieinNC's Avatar
Re: 4l80e trans in K10 - Transfer Case Adaptor - Tone Ring ??’s
Read this:
https://www.novak-adapt.com/catalog/...e-to/kit-4l81/
The tone ring kit is available from Novak Adapt...the link has all the details...
I assume you will be using a standalone trans controller...
Family and country before all others...
2006 Chevy Silverado (Daily Driver)
2012 Chevy Equinox
AussieinNC is offline   Reply With Quote
Old 08-26-2019, 11:20 PM   #3
MAGGEE
MAGGEE's Avatar
I’m trying to avoid the tone ring install. Is it possible to use the transfer case from the donor ‘04 vehicle? And then eliminate the tone ring issue altogether?
Old 08-26-2019, 11:21 PM   #4
MAGGEE
MAGGEE's Avatar
And I hope to use the stock ECM.
Old 08-26-2019, 11:24 PM   #5
57taskforce
All about them K’s
57taskforce's Avatar
Nope the drop is on the wrong side. Unless you can find a 91 crew cab 205 that came behind a factory 80e (hens teeth) in order for it to work correctly your going to need the tone ring. I’ve seen where some guys run a manual valve body and ditch the tone ring but that isn’t ideal to say the least. The factory computer shouldn’t be a problem if you get the tone ring setup.
Tyler
'72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879
‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206
'98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's
‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue
‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0
Old 08-26-2019, 11:33 PM   #6
MAGGEE
MAGGEE's Avatar
You are correct. Wrong side. Just trying to think this through b4 I spend any more than I have to.
Old 08-27-2019, 04:08 AM   #7
mcmlxix
Collector of Projects
mcmlxix's Avatar
http://offroaddesign.com/catalog/NP205VSS.htm
Rich
1972 K5 Blazer CST Click HERE
Old 08-27-2019, 09:46 AM   #8
Bones72Super
Bones72Super's Avatar
I will be doing the same swap LQ4/4L80E in my 72K2500. Try to find a 205 from a square body that had a th400 in front of it, they are hard to find but that the ticket. I got lucky and found one and it's a direct bolt up. The 4L80E is a th400 with overdrive and the bolt pattern on the tail and spline count are the same. Somebody please correct me if I'm wrong
WTB 71-72 Original paint Medium Red hood
WTB 1972 Very nice original Parchment seat belt set
Bones72Super is offline   Reply With Quote
Old 08-27-2019, 10:00 AM   #9
mcmlxix
mcmlxix's Avatar
You are correct..32 spline... I lucked out and got a 1991 k30 crewcab that had the VSS built in the NP205.. 1 year only I believe
The ORD link above has good details on the NP205
Rich
Old 08-27-2019, 10:46 AM   #10
mcmlxix
mcmlxix's Avatar
You can get the VSS signal from the 4L80E which is fine till you engage the transfer case and change the final gear ratio...
Rich
Old 08-27-2019, 12:06 PM   #11
57taskforce
All about them K’s
This is the unicorn I spoke of earlier in this thread.
Tyler
Old 08-27-2019, 12:25 PM   #12
kwmech
If you get a stand alone controller you don't need the tone ring in the t-case. You can program it to use the rear speed sensor in the trans. If no sensor in the transmission you'll have to install one. Worst case is no tone ring internally. If that is the case, then you'll have to have a trans shop put one in
Old 08-27-2019, 12:28 PM   #13
kwmech
There is just enough difference to where it is not a direct bolt in. The centering ring or the groove where the o ring sits is a different diameter.
Old 08-27-2019, 12:59 PM   #14
57taskforce
All about them K’s
I thought I remembered that but I wasn’t sure. I knew something was different.
Tyler
Old 09-02-2019, 06:54 PM   #15
MAGGEE
MAGGEE's Avatar
Thanks for all the input.
4l80e, ls swap, np205, reluctor, transfercase
