09-27-2015, 02:24 AM | #1 |
meowMEOWmeowMEOW
Whats the biggest problem with most fiberglass parts?
So I'm curious, whats the biggest problem people chase with fiberglass parts? Is it something on the user-end; hard to mount, tough to work with, changes in use/functionality? OR Is it things from the production end; poor quality bucks/molds leading to sloppy fit, extreme variation in panel gap, bad quality materials user or hugely varying quality etc?
I ask for a few reasons, among them being general curiosity and frustration. When I first did my body and then started to lighten the truck, I wanted a fiberglass hood and even moreso, I wanted a fiberglass tilt frontend. However it seems like almost no one makes high quality fiberglass for most trucks, let alone at a fair price. For the 60-66's, US Body and whatever that other company was were the only options, and both only sold a few panels....and both were really freaking expensive...and both had terrible garbage quality. I was shooting the sh!t with my old man in the shop the other day, and he rambled on about how he used to make fiberglass hoods and panels in shop class in the 70's (no doubt, he also walked uphill both ways in the snow with no shoes...) Anyway, he got on a boredom kick as many early retiree's do, and started poking back into the subject with a more fiscal interest. So, back to the original question....what is the biggest problem with fiberglass race (and street I guess) parts for our trucks?
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
09-27-2015, 07:59 PM | #2 |
Re: Whats the biggest problem with most fiberglass parts?
Most are poor quality, poor fit and poor finish!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
09-27-2015, 08:39 PM | #3 |
And poor durability.
K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
09-28-2015, 04:46 AM | #4 |
Your probably thinking of Harwood, they are way over priced but the stuff from Unlimited has always been high quality for my use. They have both Street and Race parts and fitment issues can't be any worse than the aftermarket steel parts are. The street parts are tough and the race stuff is flimsy because they are lighter.
Linky: http://up22.com/
Custom Painter/Restoration Specialist 1965 GMC 3/4 Ton LB SOLD? 1964 Chevy El Camino in full restoration 1991 Chevy S10 288K+ miles 2nd Owner SOLD 2020 RAM 1500 Warlock |
09-28-2015, 12:15 PM | #5 |
i will be buying the fenders, hood , bumper for my truck from unlimited, my dads camaro was basically all fiberglass from unlimited and the stuff was strong
LWB 82 c10 building a street/strip truck. has a 468 with stock 12 bolt. |
09-28-2015, 07:49 PM | #6 |
It's Better With Nitro
In my experience, a lot of the issues have to do with the production drift and variances, and the lack of maintenance of the molds. This ends up as a crap shoot for parts that don't fit well and/or require a lot of body work. For our trucks, it's doubly tough since there are only a couple of suppliers that provide truck parts in fiberglass. If you go into the process thinking that a fiberglass part should fit without any work, you might be in for some disappointment. The parts that I didn't have to spend as many hours (on average) fitting were from VFN Fiberglass and Glasstek. I actually went through two hoods for my '63 Chevy II - the first one from Unlimited was too bowed in the middle to fix, so I ended up with one from VFN.
I just went through this with fitting and tinning a funny car body to my chassis, and now I'm up to my ears fitting and tinning a '32 Bantam Outlaw Fuel Altered body (to switch back and forth between AA/FA and AA/FC)...and let me tell you, everything is off by more than an inch side to side - it's frustrating.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
09-30-2015, 09:00 AM | #7 |
I had Vfn glass on my 67 camaro and it was pretty decent but we had allot to do to the doors to be able to mount the lexan windows. The flange stuck straight up instead following the windshield post!
09-30-2015, 09:54 AM | #8 | ||
I always wanted to build one but have had so much fun with my (sleeper) door car that I never followed through. K
09-30-2015, 10:55 AM | #9 |
One thing I have seen with most companies that offer parts is that there is no customer service whatsoever and it is never a problem with their part, it must be something the customer is doing wrong. If I were in business for myself I think I would use issues in the field to try and make my product as good as it could be. With that being said back in the late 90s I purchased and waited for 2 months on a cowl hood for a 65 c10 from usbodysource. When I got it the finish looked pretty good but when I tried to install it it was an inch too narrow and high on the pass side. I thought they may have stood it up on its side when it came out of the mold however they were the biggest jerks about it when I called them. I made the mistake of cutting out the parking light plug before I test fitted( lesson learned) I was out $700. Ended up getting one from unlimited for around $850. It fit the truck pretty well but it took a good bit of finish work to get it in paint. Really discouraging but that is life. I'm not in to bashing business but I told myself when I went through that I would try to help other people before they spend their hard earned money
check out SANFORD build thread http://67-72chevytrucks.com/vboard/s...d.php?t=522019 |
10-02-2015, 03:07 AM | #10 |
Look up Autofab in Santee, Ca. They build there stuff, and it is very strong, and damn near ready for paint when you get it.
Project Roxy... Shes Bad, Low, and Blown... http://67-72chevytrucks.com/vboard/s...d.php?t=673333 |
10-02-2015, 06:34 PM | #11 | |
meowMEOWmeowMEOW
I've seen the Up22 site a few times, but they only do hoods, sadly not entire front ends. I need someone to make a good quality, more-or-less bolt on, fiberglass front end for my truck, for under $1k.
10-07-2015, 11:03 AM | #12 | ||
Sounds like this is another project Ill be tackling. Cab and chassis will be in the shop just after SEMA. and with some connections to Unlimited and having some connections with all the SOCAL offroad glass guys maybe I can pull a rabbit out of the hat. I have all good panels for molds. I would like something durable but not offroad durable. BR3W I just popped on to search glass. I figured you had already done all the research. haha |
10-07-2015, 02:41 PM | #13 | |
meowMEOWmeowMEOW
Hmmm, I do know someone who can cure carbon fiber in a 10*10 autoclave....
10-07-2015, 06:53 PM | #14 |
Joe Vanoverbeek Race cars, can make any part out of glass or carbon fibre,but you will pay for the quality
