08-08-2023, 10:55 PM | #1 |
Re: Airbag options for 71 C20
HD leafs. It's a Custom Camper.
Curry in a Hurry: SB rebuild for my 71 C20 |
08-09-2023, 10:01 AM | #2 |
You could remove some leafs or source a lighter duty C10 sring pack & utilize an Air Over Leaf set-up for height adjustment. That would be the easiest way w/the current set-up. Beyond that, a HD 4-bar would get things done but be more work.
Front is the basic cup/plate/bag set-up as there's no significant difference between the set-up of a C20 vs a C10 as far as swapping to air-ride.
08-09-2023, 10:27 AM | #3 |
Thank you! The 4 link isn't in the cards right now, just beyond my capabilities at the moment.
Do you have suggestions on some companies that provide quality products, but importantly, good customer service? I've seen quite a few out there, but as with other hobbies I have, there are some that are better than others when it comes down to it.
08-09-2023, 11:54 AM | #4 | |
https://switchsuspension.com/ https://ridetech.com/
08-10-2023, 11:02 AM | #5 |
Thanks man, appreciate the links. I came across SwitchSuspension in my searches, but I'll have to look closer at the others.
Seems to be a lot of these types of companies in AZ.
