05-18-2015, 05:52 PM | #26 |
Re: my twin turbo sleeper nova
thanks
thank you..
Twin Turbo 64 nova project http://67-72chevytrucks.com/vboard/s...d.php?t=669163 68 camaro LS2/T56 vs. 06 GTO build http://67-72chevytrucks.com/vboard/s...d.php?t=516310 project incredible hulk build http://67-72chevytrucks.com/vboard/s...d.php?t=269754 project big red build http://67-72chevytrucks.com/vboard/s...d.php?t=342165 project "blue ray" build http://67-72chevytrucks.com/vboard/s...d.php?t=405465 |
05-18-2015, 05:55 PM | #27 |
welp, with the hot side off getting coated, I turned my attention to the cold side. first thing was to mount the intercooler.
because im going for that sleeper look, I definitely want to hide it behind the grille and keep it looking "stockish"... so off comes the front grille assy, again, and then I placed the IC in the location I wanted...so the hood latch assy. was the determining factor on how high I could mount the IC (I don't want to do hood pins), so I had to modify the latch assy..first thing I did was remove the center grille bracket (drilled out a couple of rivets), then I cut the 'pull' to open the hood off, shortened it, did a slight rebending, and welded it to the latch assy. effectively just moving my hood pull up about 6"...and finally painted it again.
05-18-2015, 05:55 PM | #28 |
here is a couple of pics of the IC. its a 12"x30"x3".. in these pics its just sitting on the front subframe cross bar, so I could verify my modified latch assy, would clear it...
05-19-2015, 06:16 PM | #29 |
ok, got the intercooler mounted, the front cross member of the subframe was in the perfect spot for mounting the IC. so I drilled a couple of 1" holes from the bottom, then mounted some studs in the IC, and bolted it down.
once it was bolted down, I trimmed my lower filler panel to fit around the IC, I'm sure it'll get trimmed on more, once I run the cold side piping, but here is how it is now. then finally, I had to remove the lower 1" aluminum lip of the grille to give me clearance from the IC.
05-20-2015, 02:52 PM | #30 |
6>8 Plugless........
Nice work! I'm sure it'll be getting real filled up in there once you get the piping built!
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
05-22-2015, 01:24 PM | #31 |
Now a "really cool" "Ol grandma car" .
"I feel the need for speed!"... as soon as I am done with my nap. |
05-22-2015, 06:06 PM | #32 |
thank you
05-23-2015, 08:48 AM | #33 |
awesome build..im in
Eric 1967 C10 Small Window - LWB http://67-72chevytrucks.com/vboard/s...d.php?t=657509 2004 Silverado 2500HD - Turbo Diesel 603 rwhp / 1090 rwtq 2016 Camaro SS - Satin Pearl Nero wrap My 2010 Camaro SS Magazine feature (SOLD) http://www.superchevy.com/features/g...of-perfection/ |
05-23-2015, 10:46 AM | #34 |
PROJECT 7DEUCE
Nice build so far bud
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
05-30-2015, 11:56 AM | #35 |
so with that center piece removed from the grille assy., it tied my hood latch assy., grille, and lower filler piece together, and since I no longer have that, I needed to add rigidity back to all them again, and tie my IC into the mix too. so my simple solution was to make a cross bar on the IC, and have a stand off connecting to my hood latch assy. (my hood latch assy. also attaches to the grille, so it stiffens everything up more so then the factory center bracket that I had to do away with)
05-30-2015, 11:57 AM | #36 |
05-31-2015, 12:22 AM | #37 |
Exhaust looks great, nice and shiny
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
05-31-2015, 09:30 AM | #38 |
Does look good. Who did the coating?
06-02-2015, 07:26 PM | #39 |
Thompson metal coating, in Owasso ok. really nice job he did..
06-02-2015, 08:55 PM | #40 |
Those hot side pieces look great!
06-07-2015, 08:10 PM | #41 |
thank you, they did turn out real nice...and here are a few reassembly pics of the turbos getting put back together
06-07-2015, 08:11 PM | #42 |
also got the headers, turbos, and downpipes installed. before I installed the down pipes, I had to transfer over my O2 sensors and install my wideband..
06-08-2015, 07:24 PM | #43 |
Very nice! Those oil drains are sweet!
06-09-2015, 10:32 AM | #44 |
Nicely packaged! Looks really good. Curious, do you do this fab work as a day job too? You are really talented on this.
06-09-2015, 05:53 PM | #45 |
ya, those oil drains are pretty cool I thought too...
no, im a aircraft mechanic as my day job... car builder by night
06-12-2015, 08:55 PM | #46 |
for the oil feed, I tapped off the rear, top, of block (same location as stock oil sending unit).... I bent up some 1/4" stainless steel hardline, then ' T ' it off, to feed both turbos...for the drain, I used -10 AN fittings and braided SS hose. I drilled and tapped the oil pan to accept the fittings..
06-12-2015, 08:55 PM | #47 |
while I had the intake manifold off, routing my oil feed line under it. I changed out my stock 85mm TB to a 102mm TB (see pic below for comparison, the 102is a big'un) . to do this required some porting of the intake manifold, but once I had manifold ported, it worked out nicely.....then I painted the TB,and re-assembled everything...
06-13-2015, 11:39 PM | #48 |
Looking good! I'm still following
06-14-2015, 07:48 AM | #49 |
Very impressive!
06-15-2015, 10:04 PM | #50 |
Great work! The SS line looks like it bent nicely too!
