Old 09-16-2018, 12:11 AM   #1
StingRay
StingRay's Avatar
71 GMC big block parts
Heat Shield, Air Cleaner Spacer. Still available
Saskatoon, Saskatchewan
Canada
StingRay is offline   Reply With Quote
Old 09-16-2018, 12:14 AM   #2
StingRay
StingRay's Avatar
Re: 71 GMC big block parts
pics
Canada
Old 09-16-2018, 12:19 AM   #3
StingRay
StingRay's Avatar
more
Canada
Old 09-16-2018, 12:26 AM   #4
StingRay
StingRay's Avatar
Big block pulleys. The double pulley is also used on small block A/C applications. The set off of the big block, 1 single one double, has some pitting. $20.00 plus shipping for the set. The super clean double $15.00 plush shipping
Canada
Old 09-16-2018, 12:29 AM   #5
StingRay
StingRay's Avatar
more
Canada
Old 09-16-2018, 12:37 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Great prices! Wish I needed this stuff.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 09-16-2018, 12:38 AM   #7
StingRay
StingRay's Avatar
1971 gas pedal and bracket . Nice and clean. Two piece pedal bracket for kick down switch.
Will include some of the kick down switch parts. The plastic slide fell apart. Also have the wiring that was there. $30.00 US plus Shipping
Canada
Old 09-16-2018, 12:42 AM   #8
StingRay
StingRay's Avatar
Big Block exhaust heat shield. Really Nice. With bolts.
$40.00 US plus shipping.
Canada
Old 09-16-2018, 12:48 AM   #9
StingRay
StingRay's Avatar
Carb Spacer. Cleanest I've ever seen. Zinc is nice and bright. There is some minor oxidation.
$15.00 US plus Shipping.
I have the air cleaner and lid too but its dirty and has surface rust. Pics on Request.
Canada
Old 09-16-2018, 01:00 AM   #10
StingRay
StingRay's Avatar
I have a few more bits I'll post after I clean them up. I have the Brake booster connection hard and soft line with booster fitting. I have the brake booster firewall braces as well.
Canada
Old 09-16-2018, 07:48 AM   #11
southern parts
southern parts's Avatar
I`ll take the big block power steering , pulleys , and the gas pedal .
shipping to Elberton ga 30635.
thanks , Woody
southern parts is offline   Reply With Quote
Old 09-16-2018, 08:08 AM   #12
67kid
thanks , Woody
I will get in line on the pulleys
67kid is offline   Reply With Quote
Old 09-16-2018, 09:31 AM   #13
painterljp
I'll take carb spacer. Let me know shipping to 87107. Do you have stove pipe setup? Or any part of it?
painterljp is offline   Reply With Quote
Old 09-16-2018, 11:07 AM   #14
StingRay
StingRay's Avatar
No stove pipe. Need a city/state a zip code only won’t get me a shipping quote up here.
Canada
Old 09-16-2018, 11:09 AM   #15
StingRay
StingRay's Avatar
All of the pulleys? Both of the two groove?
thanks , Woody
Canada
Old 09-16-2018, 11:38 AM   #16
southern parts
All 3 pulleys. The pitted pair, and the nice double.
Old 09-16-2018, 12:12 PM   #17
StingRay
StingRay's Avatar
It’ll be tomorrow before I get to town for a shipping quote.
Canada
Old 09-16-2018, 12:14 PM   #18
painterljp
Is Albuquerque New Mexico 87107
Old 09-16-2018, 01:47 PM   #19
StingRay
StingRay's Avatar
I also have this alternator bracket. It came from the same truck. I’m not overly familiar with big block stuff. I assume it’s correct. It’s had a tab repaired or modified. I’m sure it can be restored with a little effort. 15 bucks plus shipping
Canada
Old 09-16-2018, 02:09 PM   #20
southern parts
I'll take the alternator bracket also
Old 09-16-2018, 04:14 PM   #21
southern parts
do you have the cast lower bracket for the alt ?
Old 09-16-2018, 06:23 PM   #22
StingRay
StingRay's Avatar
No I suspect that went with the alternator. Wasn’t there.
The brake vacuum line is cleaning up nice. There is also a Th400 shift bracket on the frame I might be able to get. It looks different than the small block ones I’m familiar with.
Canada
Old 09-19-2018, 02:41 PM   #23
StingRay
StingRay's Avatar
Heat shield and air cleaner spacer still available. With a pending Canada Post strike shipping could be an issue. UPS is very expensive. In general shipping to locations outside of Canada is more than most down south are going to expect. The border between us adds a lot of expense.
Canada
Old 09-19-2018, 03:12 PM   #24
painterljp
Sorry to pass but shipping is as much or more than part. Good luck with sale. Maybe they think is Mexico and two borders to cross. Lol. Good luck with sale.
Old 09-19-2018, 05:13 PM   #25
StingRay
StingRay's Avatar
No worries
Canada
