Closed Thread
Old 08-16-2014, 09:25 AM   #1051
88fordf150
88fordf150's Avatar
Re: What did you do to your truck today? Chapter II
Originally Posted by Red Tractors View Post
Today I gave up on my cab on the '71 Cheyenne, I went to pull it off to replace the floor supports and discovered the entire top of the A-pillar was rusted out and gooped/filled. Bondo can hide a lot of evil work.
With the entire floor gone, inner and outer rockers and all four supports shot, the cowl rusted and now a big chunk of a-pillar/window frame/drip rail trashed I am moving to plan B. I have a '70 Cab we patched up I was saving for a future project.
Sounds like my truck. I had to replace pretty much everything.
Brad handshoe
88fordf150 is offline
Old 08-16-2014, 04:36 PM   #1052
66Bob
First work I've done on the new 66 since I got it last week, changed the oil, oil filter - it was dirty! Then just popped in a new air filter to replace the one that was crushed, was going to do a differential fluid change but luckily I realized they gave me the wrong gasket before I unbolted everything. Cleaned up the engine area a bit, then just spent a few hours under the truck trying to learn more about it.
66Bob is offline
Old 08-17-2014, 08:24 PM   #1053
DaHos
DaHos's Avatar
Finished up this little gem...
1967 C10 SWB
Owner - Rustbelt Restorations
DaHos is offline
Old 08-17-2014, 08:37 PM   #1054
Econman
Econman's Avatar
I almost finished the disassembly of my TH350. But got to the low-reverse spring retainer and didn't succeed in getting it out without the proper tool.
Econman is offline
Old 08-17-2014, 10:13 PM   #1055
9teen69
9teen69's Avatar
Really nice work on the column! Need to get mine done...jealous.
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 08-17-2014, 10:51 PM   #1056
jacob822
jacob822's Avatar
Fabricated and test fit my new gauge mount setup. Should be straight and mounted tomorrow.also got my temporary stereo deck mounted.
jacob822 is offline
Old 08-18-2014, 03:28 PM   #1057
MercRising
Pulled the extra tanks out ...for now! They need some work as you can see. The bolts are rusted to the tanks and would not budge! A busted elbow and some grinding took care of that though, and out they came!
MercRising is offline
Old 08-18-2014, 05:03 PM   #1058
sixtyeightC10
Originally Posted by wreckedchevy View Post
Took her out to the weekly cruise, usually I hide in back but this time I found this big beauty to hide behind! don't know who's it is but it is one really nice truck! now if Daman would have been there he could blocked me from the other side! there was also I really nice 67/68 patina truck but he took off before I got a pic.
Don't hide it! Be proud and show it off!
1968 C10, 327 large journal crank, TH400 trans, 12 bolt 3.73 geared rear axle, and rear leaf springs. HEI, Delco 10SI, and brake booster upgrades.
Formerly known as mtndewmaniac66.
sixtyeightC10 is offline
Old 08-18-2014, 07:16 PM   #1059
elimontfort
elimontfort's Avatar
Had the rims powdercoated and put new rubber on.
elimontfort is offline
Old 08-18-2014, 08:26 PM   #1060
Econman
Econman's Avatar
I took my tranny to a local trans shop to have them take the low-reverse piston out. On a promise I'd take it back to get bushings put in when my rebuild kit comes, he didn't charge me a dime.
Went home and started cleaning... 3.5 hrs later.... :-)
Econman is offline
Old 08-19-2014, 01:42 AM   #1061
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: What did you do to your truck today? Chapter II
Took it out for lunch and ran into some other's as well.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Andy4639 is offline
Old 08-19-2014, 12:14 PM   #1062
slowcpe
slowcpe's Avatar
Changed/cleaned out my fuel filter last night. This is after maybe 100 miles. Good thing I put a filter between the tank and pump. Just trying to limp this thing along (rarely driven) until I get everything for my motor swap.
Ryan
1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840
1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628
1967/71 Blue SWB C10..SOLD
1977 SWB K10..my grandpa's.....never should have sold
slowcpe is offline
Old 08-19-2014, 12:16 PM   #1063
texasld
texasld's Avatar
Holy S#!T That's crazy!!!
1969 C10 SWB 5.3L LS, 4l60e, 2/4 drop (In Progress)
2015 GMC 2500 Duramax (Daily Driver)
1999 Jeep TJ
2010 Harley Street Glide
Check Out My Build!: http://67-72chevytrucks.com/vboard/s...d.php?t=617981
texasld is offline
Old 08-19-2014, 12:50 PM   #1064
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
I stole your pic. At least, a part" of it!!!!
Very tasty.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 08-19-2014, 01:02 PM   #1065
Motoxrrar
Dont bother cleaning just get a new tank !
Motoxrrar is offline
Old 08-19-2014, 01:22 PM   #1066
slowcpe
slowcpe's Avatar
I'm not fooling with this tank, which is why I put the filter in. Its quick and easy to clean out with its replacement filters. Didn't think it get that dirty this quick though.
I already have this
to go with this
Ryan
slowcpe is offline
Old 08-19-2014, 02:57 PM   #1067
Andy4639
Old member
Andy4639's Avatar
Cool Re: What did you do to your truck today? Chapter II
Very tasty.
That's cool!
Andy4639 is offline
Old 08-19-2014, 03:19 PM   #1068
magwakeenercew2jh
That's cool!
Well, since you don't object, I went in for a little more P-Shop. You can probably tell why. :lol
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
Old 08-20-2014, 08:22 AM   #1069
VWNate1
VWNate1's Avatar
Post Re: What did you do to your truck today? Chapter II
I came back from saying good bye to Pops , went by the paint jail where they've actually begun taking my truck apart , boy howdy is that rust bad ! . they said they'll begin bead blasting my new cab Thursday 8/28 .
Looking at those fresh cylinder heads , looks good .
Mostly what the DIY'er can do best without ruining the heads by over porting is : unshroud the valve bosses as this is the # 1 pinch point in flow both intake and exhaust .
Never polish the intake ports ! they need to be rough to maintain the fuel mix ~ polishing the intake tracts allows fuel mist to separate and cling to the tract walls .
Polishing the exhaust ports and matching them to the exhaust manifold/header size gives HUGE gains in flow .
-Nate
Geezer
'49 3100 235 W/ Muncie SM420 SOLD
'69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH
VWNate1 is offline
Old 08-23-2014, 10:10 AM   #1070
DaHos
DaHos's Avatar
Just got these back from getting PC'ed......
1967 C10 SWB
DaHos is offline
Old 08-23-2014, 10:50 AM   #1071
Gobuffalo
Gobuffalo's Avatar
It's a good news, bad news thing.
Good news.
Brought something home from vacation. It's a 6.0L and a 4L80E.
It's amazing how cheep things are once you get out of California.
Bad news.
When I got back, my Suburban was supposed to be out of the paint shop. He has not touched it any further. Then I'm told, "I need $9400.00 more or I won't finish it". I am already into it for over $5000.00 and supposed to pay $2500.00 more. So, it came home. The outside looks close to done, inside needs work.
Anybody know a good reasonable painter in the San Bernardino area?
Gobuffalo is offline
Old 08-23-2014, 02:51 PM   #1072
Andy4639
Old member
Andy4639's Avatar
I have the motor cover about done. I also have a new pan for the electric fans to install also.
Cover will go back to shop on Monday to have the front piece weld on it. Drove the truck this morning and it ran fine didn't notice any heat build up at all and temp gauge read just fine.
Andy4639 is offline
Old 08-23-2014, 02:51 PM   #1073
Elliot949
Dan Johnston
Elliot949's Avatar
Good news.
Bad news.
Painter and reasonable... those two words never go together...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline
Old 08-23-2014, 05:49 PM   #1074
texjake
texjake's Avatar
I worked on getting the interior floor cleaned out today & getting it ready to install the sound deader, new carpet and new seatbelts. The seat is at the upholstery shop getting done. It's going to look great after it's all done. I set the carpet in there temporary just to see how it's going look.
"Now all I need is a shop to go with my shop vac!"
texjake is offline
Old 08-24-2014, 05:06 PM   #1075
Saclandman
Saclandman's Avatar
Hung my cleaned up driver's side fender today.
Rich J.
1967 Chevy C20 Longbed Stepside w/283 and 4spdSOLD
2002 Chevy Tahoe 4X4 5.3L SOLD
2015 Chevy Silverado Crew 4X4 5.3L
Saclandman is offline
Closed Thread
