11-01-2015, 10:06 PM | #1 |
How rare is a 6 lug Dana 60
I just purchased a 69 GMC swb 2wd roller with a Dana 60 leaf sprung rear with 6 lugs this is the first one I've seen just wondering if this is a rare option thanks Jeff
11-01-2015, 10:22 PM | #2 |
Re: How rare is a 6 lug Dana 60
I know they put these in the Jeep Pickups. It was a semi floating Dana 60 in those. Is yours a semi or full float?
1970 Short Wide 5.3 4L60E BlackBear tune 3:73 gears, Boyd's Tank 2.5 / 4 drop 5 lug disc brakes Vintage Air 18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear |
11-01-2015, 10:28 PM | #3 |
Semi floating I've seen a few Dana 44 back rears in the 2wd GMC but not 60 s
11-01-2015, 10:31 PM | #4 |
I know Ford used a few of them in the '60's.
11-02-2015, 12:45 PM | #5 |
Ford never used a 6 lug setup. Jeep used it but only on the Wagoneers if the recall working.
The 6 lug semi-float Dana 60 is pretty uncommon. If memory serves it was only in 1/2 ton 2x4 with the close ratio 4 speed? And I thought it was only '67-'68, but you never know! It was not at all common and would be awesome to swap into a 4x4 that you wanted to beef up the rear without going to 8 lug.
11-02-2015, 02:17 PM | #6 |
This is why I bought the frame to do a 4x4 conversion the Dana 60 is a big plus the frame has the manual bell housing cross member in it hoping it is 3:73 ratio as I have a 72 Dana 44 front with disc & 3:73
11-02-2015, 06:03 PM | #7 | |
11-02-2015, 07:58 PM | #8 |
I pulled the cover off today everything looks good its an open carrier with 46-13 stamped on ring gear I'm guessing 3:55 gear ratio
11-03-2015, 04:21 AM | #9 |
11-03-2015, 08:25 AM | #10 |
This is true !!
11-03-2015, 09:02 AM | #11 |
3.54 not a common Dana 44 gearset unfortunately, so looks like a re-gear in your future in one of the axles.
I wound up with a semi-float 14 bolt in my Jimmy which is near Dana 60 strength. Only drawback is the c-clip axles instead of bolt in axles like the 60 has, but still a tremendous increase in strength over the 12 bolt.
11-03-2015, 04:38 PM | #12 |
Yeah I'll most likely go 3:73s in the Dana 60 definitely a up grade from the 12 bolt
