Closed Thread
Old 07-04-2015, 02:26 AM   #2426
Wildcard
Re: What did you do to your truck today? Chapter II
Originally Posted by firedemon View Post
got the leaking oil pan off clean and painted of course nobody has a new gasket in stock so hopefully tomorrow . did find a 5/16 x 1 bolt in the bottom of the pan cant find any missing anywhere it was running good other than the oil leak . all I can think is someone had the pan off before and it found its way in then but ill check for a sixth time tomorrow before I put it back together
Ya know that bolt you found could be 1 of the 3 that hold the top timing chain gear on, hope you don`t have the cam gear coming loose. something to thihnk about.
Wildcard
Wildcard is offline
Old 07-05-2015, 12:36 AM   #2427
summitflier
summitflier's Avatar
Started tearing things apart.
summitflier is offline
Old 07-05-2015, 07:19 AM   #2428
BlacklandCamper
Got my alternator off, and intake loose. Found out that the alternator bracket I got won't work with a long pump, and no accessory hole heads.
Grunt: 1971 C20 Custom Camper. Runs/Drives/Kinda stops. 350Ci, TH350. 4.10:1 D60. Eight Lug LWB is more better. Hell no its not fast!
Donkey: 93 Nissan D21, the farm truck. My 1/2 ton SWB. The Indomitable Datsun.
1st BN 3rd MAR. '00-'04
BlacklandCamper is offline
Old 07-05-2015, 11:09 AM   #2429
firedemon
Wildcard
I hadn't thought of that looks like im going to have to pull the timing cover
firedemon is offline
Old 07-05-2015, 11:20 AM   #2430
firedemon
I did get the gaskets and got the pan back on now I really need to get the engine cleaned and painted . the only problem I had was the new gaskets for the front timing cover didn't have holes for the bolts so I had to use silicone gasket maker . but it looks like im going to have to pull the timing cover I might have a gear coming loose . oh well I think it looks better when the covers are painted off the engine anyway . greased everything while I was under there everything looks good and tight .
Old 07-05-2015, 12:04 PM   #2431
hamjet
hamjet's Avatar
Theres no way the bolt can come off with the timing cover on. The PO must have dropped it in the pan. If the pan gasket was leaking in the front around the timing cover he must have pulled the cover for some reason without pulling the pan. How about a close up pic of the bolt?
Thanks, Joe..
1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB.
hamjet is offline
Old 07-05-2015, 01:08 PM   #2432
Wildcard
come to think of it your probably right, I would hate to send someone in the wrong direction, put some thought in what you mentioned and was just tryin to figure out where a bolt that size would come from but it the cam bolts were backing they would have to wear a hole in the cover before they came all the way out know they length they are, a aftermarket cam button is shorter than those bolts.
Firedemon , please post a pic of that bolt before you tear the front of the Engine apart.
Wildcard
Wildcard is offline
Old 07-05-2015, 01:42 PM   #2433
What did I do today? I'm still doing it. It's only 1:30, I came in to eat
On my '72 I have it taken down to the steering knuckles on what started as a frozen caliper/rotor replacement. I decided it was time for full drive axle serving, so spindles are off to remove, clean, spindle bearings, pack, and put new seals in. Both calipers and rotors are new. Bearings were fine. I have longer hoses (later c20) and 4" lift springs/shocks to put on while I'm at it. I've also seen guys searching for backing plates with little success, so I took those off, got them down to clean bare metal, put some rust converter on (just because), etch primed, and painted them up. Time to go pack the bearings and get brakes done. I'm glad I ate lunch first. Trying to cut out greasy food from my diet. Hopefully I'll get front springs swapped, too. Gotta paint the shocks, though.
special-K is offline
Old 07-05-2015, 01:49 PM   #2434
GRX
GRX's Avatar
GRX is offline
Old 07-05-2015, 04:43 PM   #2435
hamjet
hamjet's Avatar
Boy, that musta made some racket?
Thanks, Joe..
hamjet is offline
Old 07-05-2015, 05:02 PM   #2436
firedemon
Wildcard
I don't have the bolt anymore but it looked like any bolt you would get at home depo . no markings no shoulder just a regular grade nothing . but your right it would wear a hole or slot in the cover I think
Old 07-05-2015, 05:35 PM   #2437
GRX
GRX's Avatar
Yup.
GRX is offline
Old 07-05-2015, 08:28 PM   #2438
68 Stepper
Got myself a cup holder!
68 Stepper is offline
Old 07-05-2015, 09:49 PM   #2439
NASTY-LSX
Originally Posted by GRX View Post
DAMN
NASTY-LSX is offline
Old 07-06-2015, 12:23 AM   #2440
magwakeenercew2jh
RAT1968 '68 Cab/'71 Parts
magwakeenercew2jh's Avatar
Bought a set of black plates for RAT's '71 front clip and roll pan.
M17
Coarsegold, CA
RAT's shiny now.
But always a rat.
magwakeenercew2jh is offline
Old 07-06-2015, 01:20 AM   #2441
stepsider
stepsider's Avatar
Tranny pan trouble. Tranny pan was leaking. Bought a gasket with filter. Jack up the truck, drain the pan, removed the 11 bolts & the trouble began. The two rear bolts I could not get to. I had two V two slots on the side of the tranny mount. Then the pan would not come on the rear. I had to jack up the rear of the tranny to release the pan, Tranny bolts had to be remove to do this. I have a 71 GMC> Why do I have this problem ? Anyone else run into this. I wonder if my Rear tranny mount is collapsing.
stepsider is offline
Old 07-07-2015, 05:44 PM   #2442
firedemon
got the da out and had at the underhood a little bit got the passenger side good inner fender ,took out the battery box and did the inner rad support and the little cover for the fan . took a little primer and spray can semi gloss black to it don't know if you can see in pics but huge difference in person . I also got rid of the ugly stickers someone put on the doors and lastly I picked up a set of 15x8 rally wheels no centers or trim rings but got em real cheap
Old 07-07-2015, 08:50 PM   #2443
midniteblues
midniteblues's Avatar
over the weekend i got my tail,back up,and front turn sig/drive and plate lights finished up.
today it was sand,sand,sand.rear bumper & headlite bezels.(searched my stash for hours too find the 8 correct screws for these headlite bezels)
I wanna get all the white(526)sprayed this weekend.(i still need too blast & prime my ringed/painted gas cap too do so)busy busy busy....
but on the other hand i went too pull the truck out the other weekend and my choke cable broke...wtf.
the coated/spiral sheathing broke off the solid tube that screws too the dash/bezel.it must've been flexed too much at some point.I thought about trying too weld it together. but that could be tough.
what a pita. if its not one thing its another.
been lookin on the parts b with no luck.the cables at the auto stores dont have the threads too be able too screw a oe chrome bezel nut on too. gotta have that.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline
Old 07-08-2015, 06:21 AM   #2444
In The Ten Ring
All I did yesterday was spray Rust Treatment from NAPA onto the hood latch. I had finally derusted it to my minimal liking.
In The Ten Ring is offline
Old 07-09-2015, 11:49 AM   #2445
hamjet
hamjet's Avatar
Finally finished! almost, I still have to get the other two carbs fuel line made up, I just wanted to get the bugs out with just one carb, I took it for a 5 mile drive to see how things were. Temp stayed below 190, oil pressure was fine, I have to drive it more to get the rings seated. I'm cleaning up the underside of the hood before I put it on. I'm a happy guy!
Thanks, Joe..
hamjet is offline
Old 07-09-2015, 12:20 PM   #2446
GRX
GRX's Avatar
348 tri-power
GRX is offline
Old 07-09-2015, 12:22 PM   #2447
9teen69
9teen69's Avatar
That's sick!
72 Cheyenne SWB C10 (daily driver)
(Super fake cause I just love the glovebox emblem)
70 Camaro RS (frame-off in pieces)
70 Camaro RS (daily driver backup)
69 Custom LWB C10 (son now drives)
9teen69 is offline
Old 07-09-2015, 12:42 PM   #2448
Econman
Econman's Avatar
You won't regret it if you have those wheels blasted and powder coated in the color of your choice..
Econman is offline
Old 07-09-2015, 05:38 PM   #2449
firedemon
blasting them this weekend painting them for now im undecided on color thinking silver for now but maybe body color later on
Old 07-09-2015, 06:00 PM   #2450
Redline novdog
Redline novdog's Avatar
I feel out of place you'all are working on your trucks! WAY cool "W" Tri power Hamjet! I'm just throwin' the scrap on for a run to the scrap yard tomorrow. It actually quit raining here for now!!
It builds on my intelligence when I make a mistake, Boy am I building on it!
'67 C-10,'70 Nova SS
Redline novdog is offline
Closed Thread
