07-27-2019, 08:33 PM | #1 |
Trans cooler line fittings
I'm running a 4 L 60 2 wheel drive and I'm getting ready to hook up the transmission cooler lines. But I must have lost the clips to hook up to the stock fittings. I'm using the stock lines as well. Are they c clips or E clips holding the stock lines to the transmission? Also is there an O-rings on the stock lines at the transmission?
1967custom |
07-27-2019, 09:24 PM | #2 |
Re: Trans cooler line fittings
They take a special clip, the dealer has them pretty cheap. The o ring is in the fitting and not on the line.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
07-27-2019, 11:25 PM | #3 |
Perfect. Thank you!!! Now I just gotta wait till Monday now for them clips dangit!!
1967custom |
07-29-2019, 11:36 PM | #4 |
Its already monday so i imagine you have your clips, but for anyone looking later, its almost a certainty that any auto parts store will have them in stock.
07-31-2019, 04:34 PM | #5 |
I looked theyre in the help section like a multi pack but the pack was like 14 dollars!!!
1967custom |
07-31-2019, 06:15 PM | #6 |
Good grief, that's crazy! If you still dont have them, PM me your address and I can mail you some, I have a bunch of them in my toolbox.
08-01-2019, 02:44 PM | #7 |
cool man I appreciate that but I actually found some from a lil kit I found ion the garage that came from god knows where!. but I go the lines in and am adapting them to an external cooler today
1967custom |
08-05-2019, 03:56 AM | #8 |
If you run into the issue again or end up with a leak, Napa carries them individually and any parts store should be able to get them as they are made by Dorman. Been there done that.
70 C10 highschool truck now C20 cummins powered 72 Crew Denali, Bigger, Stronger, Faster, well you get the point..... the ole 65 continental Syclone killer AWD T56 LS Paypal please pay as Goods&Services Madkidd00000007@yahoo.com |
08-10-2019, 11:31 PM | #9 |
Speaking of cooler, Is there a cooler plate that you can use to block the ports if you dont have a transmission in that accepts cooling?
