05-24-2019, 06:43 PM | #1 |
Brake Booster and Master Cylinder ID
This master and booster was in my 68 C10 when I bought it that was hacked together. I know it's not original and I'm have a hard time figuring it out what it came from. Can any of you ID it for me?
Thanks in advance for your help!
68 C10 SWB 454/TH400 |
05-25-2019, 10:35 AM | #2 |
Re: Brake Booster and Master Cylinder ID
I'm guessing, but the booster MAY be a 3/4 or 1 ton unit, not sure though. MC looks correct for C10 in 68. Does it function? Doesn't look hacked together to me (especially if it works). Someone may have just added a larger booster, or a booster period. Does your SPID show a power brake option? If not, then the whole booster was added.
Depending on what your plans are, you can run what you have if it works. Probably not a bad ideal to at least replace the crusty MC with a new stocker, very inexpensive - I'd imagine the brake fluid could use a purge too if the inside of the MC looks like the outside. If booster NOT working, you could replace it with a stock C10 booster. On the other hand, if you're considering a disk conversion, you can pitch the whole thing and start with new MC/Booster/prop valve combo (current setup is a stock correct distrib block that serves as a means of providing the signal to the Brake light on the dash - if there was a pigtail connected to it, that is.. ). |
05-25-2019, 11:13 AM | #3 |
Any numbers, stamping or codes on either of the pieces?
The master looks like the one on my 74 Chevelle. K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
05-25-2019, 11:50 AM | #4 |
I concur.
Mid seventies booster. Not a stock master. Looks like a disc/drum. Distribution block and not a prop valve. Stock booster might not fit with the bbc. |
05-25-2019, 12:14 PM | #5 |
Booster looks like a c30, looks like they bolted it directly to the firewall and didn’t use a bracket. Master cylinder looks like front disc duralast or something. Seen them at autozone
05-26-2019, 03:33 PM | #6 |
They drilled out the firewall to mount the booster and shorted the rod by welding it hence the hack. The master is leaking like crazy with no stampings that I can find for part number. I purchased a new booster and wilwood master since I posted this. I just need a proportioning valve that fits the current lines until I can get it move to the new garage to pull the motor and cleanup everything.
