07-03-2020, 11:39 PM | #1 |
fusible links
Working on a different vehicle where all the fusible links coming off the starter are shot. I want to replace with bladed fuses so I'm thinking of taking the battery cable to the firewall and there add a junction block and fuse block.
What I'm not sure of is how to achieve this. The battery cable has a ring terminal mid length so this is probably where I can pull power to the junction block. Also the fuse block has the terminals that are all connected. I'm assuming it's going to be a common power coming from battery? |
07-03-2020, 11:44 PM | #2 |
Re: fusible links
Had to convert pictures.
07-04-2020, 01:51 AM | #3 |
Re: fusible links
Replacing fusible links with conventional fuses is not a good idea.. Replace those old fusible links with new ones..
07-04-2020, 11:03 AM | #4 |
Re: fusible links
I seen some harness makers are using max atm fuses in there harness instead of fuseable links
You would need to size them accordingly to the fuseable link ampacity |
