06-30-2018, 12:16 PM | #1 |
AC Hose Connectors
I'm to the point where I'm going to need to buy the AC hoses for my updated ac system in my 83.
I need to know what size fitting is needed where it connects to the dryer pipe as shown in the picture. (Has the red cap on the pipe) I've done a google search and the sizes stated for the connectors say #6, #8, #10 & so on. The only difference from the factory setup is I'll be using a Sanden 508 compressor using R134 The evap & condenser is of an OEM replacement.
1997 GMC Sierra Ext 1965 Mustang |
06-30-2018, 12:37 PM | #2 |
Re: AC Hose Connectors
Here's a link to a PDF I use a lot.
file:///C:/Users/Jonez/AppData/Local/Temp/Fittings.pdf I started using the Eaton EZ Clip System in Afghanistan & have used them ever since http://www.eaton.com/Eaton/ProductsS...clip/index.htm The ATCO folks also have the Air O Crimp system, a little different than the Eaton but same principle. |
06-30-2018, 12:54 PM | #3 | |
06-30-2018, 01:44 PM | #4 | ||
Moderator
And I don't know what the suction fitting size is. If there's a local refrigeration outfit they may be able to tell you what the fitting type and size is by looking at the accumulator or the original 1983 hose end. No shame in cutting the old hose to liberate the connector for a comparison.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 06-30-2018 at 01:52 PM. |
06-30-2018, 02:40 PM | #5 |
Hey what do I know? I'm just an old mechanic, not a computer Wizard!
I just ride 'em, I don't know what makes 'em go! Try this link here & scroll down some until you see fitting size designation Atco products https://www.google.com/search?q=atco...firefox-b-1-ab |
06-30-2018, 07:43 PM | #6 |
Well,if you were here in south Mississippi,I could probably match it up for you!
I make hoses and have a huge supply of parts. Your best bet is to take it to your local a/c shop and they can fix you up. Mike. |
06-30-2018, 11:33 PM | #7 |
#8. You using beadlock or barbed fittings? I'm going thru this myself with my 85. I got to the point your at and realized my hose fittings don't match up to the factory components ( I got the same drier as you). Either go to a hydraulic/hose shop and have them make your " one of a kind hoses) or do like I did and bought the v/a evap kit so it's not all cobbled together.
07-01-2018, 07:32 AM | #8 |
Looks like that's what I'm going to have to do...is take it to a AC shop somewhere around where I live.....thanks for the advice though.....
07-01-2018, 09:57 AM | #9 |
https://coldhose.com/
they will custom build and crimp your hoses for you if you give then the length and info.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
07-01-2018, 09:59 AM | #10 |
I just ordered a bunch of pieces from them for a cummins swap I'm doing. I can get the sizes for you in a bit.
07-01-2018, 10:03 AM | #11 | |
..any help is appreciated
07-01-2018, 10:25 AM | #12 |
Here's another picture of the fitting in question...
07-01-2018, 01:20 PM | #13 |
07-01-2018, 01:31 PM | #14 |
Heres the list I bought. I am using a 87-88 dryer. not sure if its the same fitting as yours but it probably is. the 12-10 90 is what connects to the dryer.
07-01-2018, 01:32 PM | #15 |
not sure why its upside down.
07-01-2018, 01:39 PM | #16 |
the upper fitting
07-02-2018, 07:06 AM | #17 |
That looks like what I need.
So, is that a #12 fitting?
07-02-2018, 09:06 AM | #18 |
yes
07-02-2018, 09:07 AM | #19 |
09-19-2018, 02:33 PM | #20 | |
I'm local to you and may need some help sorting out the A/C on my LS swapped C30. Shoot me a PM when you get this if you don't mind. Thanks, Richard |
09-19-2018, 07:29 PM | #21 |
