Old 03-19-2009, 11:27 PM   #126
IvelDesigns
Commander Taco Bello
IvelDesigns's Avatar
Re: 1950 Chevy 3600 - Bumper Punchin'
ok, so i've been behind on pics. Well, here are some pics.
Personally, I like the last couple the best. although the ones with the plates fitting in are pretty sweet too.
ok, so this is the frame before any boxing took place. Really clean and really straight overall.
I was pretty stoked to get a bunch of steel. I've never bought steel like this before, so it was a cool experience. I wish i had half the tools they had at the place i picked it up from. I ended up with 40' of .125"x6" plate, 24' of 2"x3"x.25" tube and a 4x8 sheet of 18ga sheet metal. All cut down to manageable 4" lengths
Let the paper cutting begin!!
and the tracing...
I wish i could say this was on the first fit. I will say though that the first plate took about an hour to make(not counting the paper time), but the second one went a lot faster. btw, note how the back of the plate (under the cab) is not out to the edge... well, i tacked it in before i realized that a rivet was in the way of it coming out. So, the cutoff wheel came out and i started over.
btw, i did pick up, then modified a welder cart last weekend. Also got a gas tank too. welds so much better with gas.
So these next two shots show the only rust in the entire truck. All of the cab mounts are good, as is all of the outer sheet metal. It's just these little holes in the floor that need to be delt with. Oh, and that square one was an access hole that needed to be cut to get the MC out.
IvelDesigns is offline   Reply With Quote
Old 03-19-2009, 11:28 PM   #127
IvelDesigns
This is the only time my wife has... well, maybe not the only time, but the only time i have proof of her working on my truck. I figured she couldn't do much harm vacuuming out the dirt
As i was unpacking, i kept mumbling to myself in a cartman voice... shinny parts... i got shinny parts... My wife was worried.
and yeah, leave it to my son to stack the boxes with the lightest one on bottom. There was literally 120lbs in the top 3 and like 5lbs in the bottom one.
Old 03-19-2009, 11:30 PM   #128
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Lovin' the pics Levi!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 03-19-2009, 11:41 PM   #129
IvelDesigns
this weekend will be a dry run to see how the engine/trans fits in this thing. I know i could of gone with shorter valve covers, but like the look, and also want to leave room for future engine upgrades
i'll more than likely have to cut the firewall for them to fit.
Now if only the LMC, ***************** and Scotts Hotrods shipments would get here. Can't really do much with these parts for a while.
Old 03-20-2009, 12:02 AM   #130
GRIMSS
GRIMSS's Avatar
I've been gone a while. Come back and see you've got a great project going. Looks great.
2001 GMC SIERRA
1956 Chevy Panel Build Page with a Scott's Hotrods IFS
1953 Chevy trucks Project Dime Time
1968 Camaro
1968 Volksrod "NOBACK"
55-59 one piece window Video
55-59 one piece window template files
Jared
GRIMSS is offline   Reply With Quote
Old 03-20-2009, 12:04 AM   #131
IvelDesigns
thanks man. Are you planning to be at either of the events this year in MO? the camping thing is the weekend after memorial day, and the big show is in sept.
Old 03-20-2009, 12:09 AM   #132
GRIMSS
GRIMSS's Avatar
Should be at the show in Sept. Well let me say I have to be at the show to see your's and nate's new toys. I'm going to try to get my panel there if I can.
2001 GMC SIERRA
1968 Camaro
Jared
Old 03-20-2009, 12:22 AM   #133
IvelDesigns
right on. that panel looks badass. Are those 20" dodge steelies your filling in? i can't imagine how much time you have into those things.
Old 03-20-2009, 07:25 AM   #134
GRIMSS
GRIMSS's Avatar
I'm not sure on those yet.
2001 GMC SIERRA
1968 Camaro
Jared
Old 03-20-2009, 07:56 AM   #135
lolife99
67-72 parts collector,…
lolife99's Avatar
Levi,... what is the application for those BB headers? They look nice!
Keith
Convert to disc brakes.
Old 03-20-2009, 08:29 AM   #136
IvelDesigns
what do you mean by application?
I went back and forth between ordering ceramic coated or thermal coated, and finally settled on the thermal coated. It was litterally a coin flip to make the final call. I think the ceramic coated look better, but was having a hard time justifying $440 for a pair. The thermal coated were about $130 cheaper.
If i remember correctly, these headers are listed as chevelle headers.
Also, after bolting them onto the block last night, they are quite different from one side to the other. the P side is long, i assume to clear the starter, and the D side is short, dumping out just before the oil filter.
based on the first fit, it looks like they will leave plenty of room to change spark plugs, and just about all plugs could use straight boots. only cyl #1 will "need" a 90 boot. however, the msd wires i got all have 90 boots. :/
Old 03-20-2009, 03:52 PM   #137
Bob 68327
72 Chevelle Club
Bob 68327's Avatar
He meant what car or truck were they made for . You sure do have a pile of shiney stuff there !! Bob
I Have The Right To Remain Silent,But Lack The Ability
1972 Chevelle ... Mine
2006 Trailblazer... Hers
2002 Buick century ... Kids
2002 K1500 Z-71 EXT CAB ... Daily Driver
2005 Rockwood Roo ... For Camping
1974 Harley-Davidson XLH Sportster 84'' stroker
Bob 68327 is offline   Reply With Quote
Old 03-20-2009, 04:19 PM   #138
IvelDesigns
a couple boxes from LMC showed up today. can't wait to get home
Old 03-20-2009, 09:38 PM   #139
lolife99
lolife99's Avatar
[QUOTE=IvelDesigns;3208236]what do you mean by application?
I just meant,... what part # or what year car do they fit? 67-69 Camaro? Nova? Chevelle?
I guess the part number would be the best.
Thanks.
Keith
Old 03-20-2009, 10:29 PM   #140
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Dang LEVI! Did it feel like Christmas for levi? LOL Can't wait to see how it all looks in the truck. I am guessing the engine will set in the frame higher than most trucks of this era with BB's in them due to the bumper punchin goal? I know I wouldn't want my expensive headers draggin the pavement. LOL
Ryan
1969 Chevy milk truck
Old 03-20-2009, 11:33 PM   #141
tcb-1
Nothing to see here.....
tcb-1's Avatar
lovin' the updates! keep them coming, Levi!
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 03-21-2009, 12:47 AM   #142
IvelDesigns
So i made a mistake tonight...
I made a list of everything that has to be done yet. Then the mistake was thinking about the $$ it's still gonna take to get those things done.
If i don't make my goal of memorial day weekend, it will be due to budget, not effort.
And on the effort note, i got the front frame all boxed in. Just need to grind it down. We got the front and rear glass out, and i started in on one of the patches for the floor.
Tomorrow is going to be a busy day...
Old 03-21-2009, 01:12 AM   #143
shawn57nomad
shawn57nomad's Avatar
WOWZERS! Super shiny...I think I need my shades! Way cool Levi...Way COOL!!!! Great progress on the Fitty. Can't wait to see it in person. Bob said you are gonna keep the patina? Couldn't ask for a better scheme: Straight, Low, kinda rusty, and then you lift the lid on the jewelry box and...BAM!...shiny goodness with all the decibels and CuIn your heart desires! Ha! Gonna stop now startin' to sound a little like Grandma's dirty novel that fell off the shelf, in a good way though. Looks Great! Keep it up.
FAST cars don't make power to the front wheels, THEY LIFT 'EM!
shawn57nomad is offline   Reply With Quote
Old 03-21-2009, 03:43 AM   #144
lurch115
lurch115's Avatar
nice pile of shiney stuff, suprized the wife didn't chew ya out for having them out in the house...hey i see you got a comp cams timing set....hope not the gear drive... looking good though, keep it up
"Horsepower is how fast you hit the wall, torque is how far you carry the wall with you."
'84 chevy half ton short box 2wd, 67,000 actual miles
'03 chevy 1500 HD crew cab 4x4 standard box, 6.0L
lurch115 is offline   Reply With Quote
Old 03-21-2009, 09:26 AM   #145
IvelDesigns
hey shawn, yeah, that's the exact look i'm going for.
One thing i'm considering now is to run blackwall wheels instead of wide whites. We'll see how things progress though.
yeah, she let me have my fun for a while. Everything is boxed up again and in the storage room now, so it's out of sight. Yeah, it's a double chain set, not a gear drive. It'll be hard enough to keep thing thing soundin' like a sleeper with the planned exhaust. figured i didn't need the gear drive whinnin' too.
absolutely! yeah, we'll see how high up they sit today. everything needs to be higher than the bottom of the frame, but i think it should be fairly reasonable.
thanks man!
Old 03-21-2009, 09:33 AM   #146
IvelDesigns
part # HED-68618
http://store.summitracing.com/partde...part=HED-68618
Old 03-21-2009, 09:39 AM   #147
IvelDesigns
i also wanted to say that i delt with a new vendor this week for some parts that my usual place was out of. Mark @ http://www.stylinsolutions.com/ came to the rescue when i needed my SMC valves and 10 switch box. I will say i was a little nervous ordering from them due to a past experience i had with another "google searched" vendor, but these guys rocked. I talked to Mark to confirm the stuff i needed was in stock, and get an idea of how they work. I placed the order on tuesday, had the parts on friday.
I will say there was a quirk with their website within FireFox, but IE was fine and got my order in right away. Prices were also cheaper than my normal place for air stuff.
So again, don't hesitate to order parts from Mark @ http://www.stylinsolutions.com/ make sure to tell them to "send levi some swag!"
Old 03-22-2009, 08:40 AM   #148
LockDoc
The Older Generation
LockDoc's Avatar
Looks like you are making some good progress. I don't get over to this forum so I haven't seen the progress you have made. I used to follow some of the builds before they split them into their own forum. I guess I need to get around more...
LockDoc
Leon
Old 03-23-2009, 12:39 AM   #149
IvelDesigns
LockDoc
Thx Leon. You'll have to swing over some time and check it out.
Old 03-23-2009, 12:42 AM   #150
IvelDesigns
Here are the pics. I'll add comments shortly.
I started in on the floor work this weekend. Spent saturday morning making a patch for the drivers side floor. Turned out pretty well (i'm missing the shots of it done. i'll get them later) if i do say so myself. I'm not worry about the looks. Just want to keep my feet dry.
Friday night we got the front and rear glass out. Then on Saturday, after searching all over Des Moines for the right sized clutch drive for two hours, we finally found one at Napa. Yeah, the one we drove by and I said "hey, we should stop there first". That's right Matt. I'm calling you out on that one We did end up getting all of the glass out of the cab though. Unfortunately, it doesn't look like i will be able to get the door glass trim off the glass due to rusted and stripped tiny ass screws. So may need to give LMC a call for those. I may look at drilling them out and just welding them back together. not sure yet.
Ok, so Saturday was the big day for engine trial fitment. Overall, very anti-climatic. headers looked to be a concern at first, but once we got it slid back, all was good. These two pics show the engine about where it will end up. in these shots it's about 2" forward of where it will end up. my motor mounts from Scotts didn't get here in time, but it does seem to be sitting awful high. but at this height, we have good oil pan and trans clearance at the sacrifice of the floor. Fortunately it won't be anything to crazy and will still allow for the factory bench seat.
So, with the test fit done, we started in on the trans X member. My goal was to have it mount 1" above the frame. I have an energy suspension trans mount that i plan to use, so we did some measuring and start in on the fab work. the tube is 1/4", and should make for a pretty beefy X member. because i'm not 100% on where the final mounting location will be, i made the plate on the bottom long (that will bolt to the bottom of the frame rail) and will shim the side plates with 1/8" or 1/4" steel if needed. But, for now, the X member is pretty much out of the way. Just need to do some more welding and grinding.
1950, 3600, air, bagged, chevy
