Old 01-14-2018, 01:38 AM   #126
Pure-Juice
Re: 400/406 Builds
I have a new build I would like your thoughts on and any recommendations you have for stall speed, carb, headers, etc.
Chevrolet 400ci bored to 406
Scat 9000 cast steel Pro Comp 3.750" stroke crankshaft
Comp Cams Magnum Retro-Fit Hydraulic Roller Camshaft
280/280 duration
0.525"I/0.525"E lift
110 LSA
SRP Forged 21.00cc Dish Pistons, 4.155" bore
Eagle I-Beam forged connecting rods
Dart Iron Eagle Platinum 23 degree cylinder heads
64cc combustion chambers
215cc intake runners
1.600" exhaust valve dia.
Comp Cams 1.6 ratio Ultra Pro Magnum roller rocker arms
Edelbrock RPM Air-Gap dual plane intake manifold
Engine will be going in my 1969 SWB C10, with 4.11 gears, 20" wheels and a TH350 auto transmission. Goal of the build was for big torque numbers in the low to mid RPMs which will be used for mainly weekend cruising around.
Pure-Juice is offline   Reply With Quote
Old 01-14-2018, 01:41 AM   #127
kwmech
Re: 400/406 Builds
May be a little too much cam for the compression, but with the 4.11 gearing you may not even notice. Definitely will be a tire burner
Old 01-14-2018, 02:06 PM   #128
53chevyforever
53chevyforever's Avatar
Re: 400/406 Builds
280/280 duration
110 LSA
I think your combo will run great....I would call coan and ask what Pro Street Torque Converter they recommend. Jegs sells them and usually have in stock at a reasonable price. Tim
53chevyforever is offline   Reply With Quote
Old 01-15-2018, 12:03 AM   #129
Captainfab
60-66 Nut
Re: 400/406 Builds
I agree with a little too much cam for the static compression. Have you calculated the dynamic compression? Also the intake port of the heads is a bit too big for the rest of the combo. IMO a 180-195cc intake would be better for your power goals. I hope your tires are fairly tall with those 4.11 gears. A 650-750cfm carb would be fine.
280/280 duration
110 LSA
Old 01-16-2018, 01:43 AM   #130
68post
Re: 400/406 Builds
You won't need much stall with your cubes and 224* @ .050 duration. I'd use a 750 carb
Tim K.
84 K30 srw Silverado 454 auto
85 C20 350 C6P auto flatbed
94 K1500 lifted shortbed 350 4 bbl NV4500
68post is offline   Reply With Quote
Old 01-16-2018, 02:11 PM   #131
Pure-Juice
Re: 400/406 Builds
Thank you everyone for your advise and suggestions. This is my first engine build and I welcome any pointers that will help out.
Old 01-16-2018, 11:40 PM   #132
Captainfab
60-66 Nut
Re: 400/406 Builds
You can read back thru this thread and see what other people are using in their builds.
Old 04-26-2019, 02:04 PM   #133
SCOTI
SCOTI's Avatar
Re: 400/406 Builds
280/280 duration
110 LSA
Any updates?
What rear tire size? That combo should be fun around town & those heads will work just fine w/your intent on a 406.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-03-2020, 11:26 PM   #134
Warrens69GMC
Warrens69GMC's Avatar
Re: 400/406 Builds
Finally bought a 400! I had the option of a 817 fully assembled or a 509 that was torn down. I bought the 509!! Standard bore, told them to keep the crank rods Etc. ...
I plan on a new rotating assembly, 5.7 rods, slight dish and around 9.3 to 9.4 compression. Any suggestions on a camshaft ?
Looking at summit vortec heads or AFR "as cast" 195 aluminum heads. 65cc average CC
1978 C10 - Big10 - Th350/3.08/28.0 tires
Edit - Would you buy a unknown 400 (817-1976) complete as is? asking $250
Old 07-04-2020, 08:10 AM   #135
burnin oil
Re: 400/406 Builds
You can get 6" rods for about the same price when you buy the rotating assembly. I really liked the SCAT setup that I got but ha e the balance rechecked by the machine shop as they can be very generous. Hopefully your block is a 2 bolt main since they are stronger than the factory 400 4 bolt main. Invest in some main studs if you are going to run any rpm. Before assembly make sure all your bolt holes are drilled and tapped. My 509 core didn't have the power steering bracket or clutch ball stud drilled. I didnt notice and had to do them in the truck and that is a giant PITA!!!
I think $250 is fair on a complete engine that hasn't been produced since 1980. LS motor popularity dropped prices some.
burnin oil is online now   Reply With Quote
Old 07-04-2020, 03:31 PM   #136
SCOTI
SCOTI's Avatar
Re: 400/406 Builds
Curious about these statements. When I do the math, it calcs out to about a 9.6:1 Static/8.4:1 Dynamic compression. The In/Ex duration @ 224° seems mild given the larger displacement of the small-block (406 vs. 355). I see many, many recommendations for around 230° for a 400+ cube motor. The head port sizing does seem off but I tend to go smaller than what the typical magazine builds suggest. When I calc'd this combo out, it estimated 400hp @ 4800rpm. TQ should be more than that as it's a mild motor combo.
Just curious of what I'm not seeing/considering.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 07-05-2020, 06:06 AM   #137
Already Gone
70+ ( Old Skool Club )
Already Gone's Avatar
Re: 400/406 Builds
I have a uncut SBC 400 and I think its an 811 block, 2 bolt main anyway. All that is going to be used from the engine is the block and crankshaft. The block will be milled .30 over so I guess will be a 406 when done. The engine is going to replace the 90,000 original mile 350 in my truck as its, well got 90,000 miles and its never been opened. I just want a streetable driver engine with some get up and go as compared to the 350 which still runs strong. Here is the parts list my friend who is building it suggested to use and I bought everything in the picture from Summit Racing.
Heads are Cast Iron and made by DART for Summit with a 72CC Combustion Chamber and 2.02 intakes and 1.60 exhaust valves with a 3 angle valve job and there are more specs in the link. Saving for these as of this writing.
https://www.summitracing.com/parts/sum-152123
Pistons are Speed-Pro Hypereutectic with a 3.75 inch stroke and 5.7 inch rod length.
https://www.summitracing.com/parts/slp-h615cp30
Connecting Rods are Scat Pro I-Beam and 5.7 inches
https://www.summitracing.com/parts/sca-25700716
Cam Shaft is a Lunati Voodoo with 256/262 Duration and 454/468 Lift and is a 1-5000 RPM cam which will be good for me.
https://www.summitracing.com/parts/lun-10120701
Lifters are Chevrolet Performance # 12371044
https://www.summitracing.com/parts/n...make/chevrolet
Rocker Arms are Summit Brand G6800
https://www.summitracing.com/parts/sum-g6800
Pushrods are Summit Brand G6400
https://www.summitracing.com/parts/sum-g6400
Intake Manifold is an Edelbrock Performer # 2101
https://www.summitracing.com/parts/edl-2101
Also going with original Rams head exhaust manifolds as I have 2 1/4 inch front to back true duals with H-Pipe on the truck now. Planning on using the factory Q-Jet that's on the truck and my friend who is going to do the build for me is going to tweak the Q-Jet too. The truck has 3:73 gears with an Eaton Tru-Trac and a 700R4 transmission.
1992 K1500 GMC Suburban
" Circumsatances Do Not Change Responsibility "
" The Sky is not the Limit, Your Mind is." Marilyn Monroe ..
RIP Charlie Watts 1941 - 2021
Old 07-05-2020, 10:29 PM   #138
Captainfab
60-66 Nut
Re: 400/406 Builds
That should be a good torquey engine. Let us know how you like it once it is built and installed.
Old 07-05-2020, 11:12 PM   #139
Already Gone
Re: 400/406 Builds
Thank you and will definitely post it up when built and probably through the build. This is the engine I was asking about the timing cover on her last week as it wasn't on engine when I got it. My friend who is doing the build has done many small and big block engines over the years and I'm sure has some extras he'll do to the engine during the build.
Old 04-30-2021, 10:31 AM   #140
Markuli
Markuli's Avatar
Re: 400/406 Builds
Just came across this thread doing some window shopping for my truck on your profile Cap. Thought I'd bump the thread and drop in the info for the engine currently in my truck. '67 C10 longbed.
Keep in mind that my dad had this engine built 10+ years ago for his Nova, so parts are a little dated.
- 1976 GM 400 block from a caprice, 2 bolt main, bored to 406, align honed and studded with ARP hardware
- 3.75" cast steel Scat crank
- Forged Scat 6" H beam rods
- Mahle D- Dish forged and coated pistons
- AFR Comp- ported 195 heads
- Cam Motion Solid Roller custom ground 262/269 at .050 duration, .630" lift
- Comp SS roller rockers
- Morel Hi PPO solid roller lifters
The engine has an ebay copy PP Hurricane intake on it, and is currently neutered via a Holley 650 and 1 5/8" headers leading into a 3" X- pipe. Still gets up and goes though, and it lets out a mean rasp when I let off and push in the clutch. Mated to a Muncie M20.
Markuli is offline   Reply With Quote
Old 04-30-2021, 10:22 PM   #141
Captainfab
60-66 Nut
Re: 400/406 Builds
That's a pretty sizeable cam, but I imagine it runs pretty hard in the mid range and top end
Old 05-01-2021, 07:24 AM   #142
Markuli
Markuli's Avatar
Re: 400/406 Builds
You're absolutely right. It was purpose built to be a 1/4 mile engine but it behaves decently on the street so long as I cruise around /above~2200rpm.
Old 05-03-2021, 01:44 AM   #143
Wellmerling
Wellmerling's Avatar
Question Re: 400/406 Builds
I found this post on a Honda forum but he refers to the sbc 400. Are these safe assumptions when making cam decisions?
https://www.d-series.org/threads/cam...7/post-2178630
"There are quite a few variables which make the same cam have different power bands in different engines.
Most of my experience with the same cam in different engines is with Small Block Chevies.
On a 400 SBC I would expect.
For an idle of 600 rpm and maximum torque at about 2500 rpm and maximum power by 4500 rpm and nosed over by 5000 rpm you would need about 225 deg duration at 0.050 lift.
For an idle of 700 rpm and maximum torque at about 3000 rpm and maximum power by 5000 rpm and nosed over by 5500 rpm you would need about 235 deg duration at 0.050 lift.
For an idle of 750 rpm and maximum torque at about 3500 rpm and maximum power by 5500 rpm and nosed over by 6000 rpm you would need about 245 deg duration at 0.050 lift.
If you want it to rev to 8000 rpm you need about 285 deg.
For an idle of 700 rpm,
The trends are:-
The longer the rods, the higher the power band.
The longer the stroke the lower the power band.
The smaller the ports the lower the power band.
With the same heads and cam, a 400CI SBC will develop it's power about 700 to 800 rpm lower than a 350. If you use a long rod 400, it changes the peak power to 500 rpm less.
A 350 is 4" bore, 3.48" stroke with a 5.7" rod.
A std 400 is 4.125" bore, 3.75 stroke and 5.565" rods
Long rods are 6" long
If you use after market high port heads on a long rod 400 you can bring the rpm for maximum power back to the same as the 350 with the same cam.
Alternatively with the long rod 400 and the original heads, you need about an extra 25 or 30 deg of duration for 400 to make maximum power at the same speed as an otherwise identical 350."
1972 K5 BLAZER CST
1972 K10 SWB
Wellmerling is offline   Reply With Quote
Old 09-27-2022, 04:09 AM   #144
Already Gone
Re: 400/406 Builds
Been well over a year since the last post in this thread so time for a bump and update on my 400 now 406.. The engine parts list that was used is in Post # 137 and engine is now together and been run on an engine stand to break in cam. It will be installed over the coming Winter. I have videos of it running but cant post on here.. 3 year build from when I bought the block till the engine fired up. Biggest delay was the engine machining took 7 months to get done and little snags on the assembly. " Be patient Grasshopper "
Old 09-27-2022, 06:17 AM   #145
jjzepplin
jjzepplin's Avatar
Re: 400/406 Builds
Wow! That looks like a mighty Small block! Nice work!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 09-27-2022, 11:06 AM   #146
Markuli
Markuli's Avatar
Re: 400/406 Builds
Looks awesome!
