Old 09-05-2014, 06:58 PM   #1
kw4kw
1965 C10 Fleetside Project
I purchased this truck about a year ago. I plan to give it a modernization upgrade. It will be getting a 5.3LS and a 4L60e transmission. Power steering and power disk brakes.
kw4kw is offline   Reply With Quote
Old 09-05-2014, 07:03 PM   #2
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 1965 C10 Fleetside Project
Whoa!
looks pretty clean!
Bring it on!
Modges'66 is offline   Reply With Quote
Old 09-05-2014, 07:15 PM   #3
kw4kw
Some more pictures before I started.
Old 09-05-2014, 07:17 PM   #4
kw4kw
Can't get more than one picture at a time so here you go.
Old 09-05-2014, 07:24 PM   #5
kw4kw
Removing the cab from the frame.
Old 09-05-2014, 07:37 PM   #6
kw4kw
Carrying the cab away
Old 09-05-2014, 07:43 PM   #7
79azc10
Looks like a nice truck , should be a nice ride when done
79azc10 is offline   Reply With Quote
Old 09-05-2014, 09:45 PM   #8
kw4kw
Got it on the rotisserie, I built the rotisserie from a couple harbor freight engine stands.
Old 09-05-2014, 09:47 PM   #9
kw4kw
Frame on rotisserie.
Old 09-05-2014, 09:53 PM   #10
kw4kw
CaptainFabs template for power steering conversion. I used a light behind the frame rail to locate holes.
Old 09-05-2014, 09:55 PM   #11
kw4kw
Welded up old steering box holes.
Old 09-05-2014, 09:56 PM   #12
kw4kw
Welded the spacer plate in.
Old 09-05-2014, 09:58 PM   #13
kw4kw
Located the idler arm from the 79 suspension.
Old 09-05-2014, 10:00 PM   #14
kw4kw
Rear disk brake conversion. I used CaptainFabs plates.
Old 09-05-2014, 10:02 PM   #15
kw4kw
I upgraded the lug studs to 14mm.
Old 09-05-2014, 10:04 PM   #16
kw4kw
Turned down the center hubs to fit the K1500 rotors
Old 09-06-2014, 02:54 AM   #17
Chris Coufal
nice job!
Chris Coufal is offline   Reply With Quote
Old 09-07-2014, 10:11 PM   #18
kw4kw
Worked on my gas tank this weekend. Got the brackets mocked up.
Old 09-08-2014, 08:45 AM   #19
1963c-10
1963c-10's Avatar
Nice work. Coming along pretty quick!!!
1964 Short bed trailer
Old 09-08-2014, 11:32 AM   #20
donthekawguy
donthekawguy's Avatar
NICE! What are your plans for the body? Looks good enough to leave it alone.
66 shorty
donthekawguy is offline   Reply With Quote
Old 09-08-2014, 05:14 PM   #21
TJ's Chevy
TJ's Chevy's Avatar
Making some good progress! I must admit I envy that frame stand! lol!
Old 09-08-2014, 07:51 PM   #22
kw4kw
I am going to leave the body like it is for a while. My goal is to get the mechanical things all ironed out then drive it for a while before I start painting.
Old 09-08-2014, 07:55 PM   #23
kw4kw
I have been working on truck for a couple months now, I would like to have the wheels back on before winter. The frame stand is just thrown together, picked up a couple engine stands from HF and wheels off EBay. Bought the 2inch tubing new from my local supply house. I have around $250.00 in frame stand.
Old 09-08-2014, 08:01 PM   #24
kw4kw
Thanks, I was a all about cars and truck when I was much younger but kinda got away from them when my kids were still home. I now have a couple of son in laws that like to work on cars so they got me started again. I saw this truck on the roadside on my way to work, it sat there for a week until I couldn't stand it any longer. I stopped and checked it out, so here we go!
Old 09-11-2014, 12:17 AM   #25
Captainfab
60-66 Nut
Nice work
Did you fab up that gas tank? Is it stainless?
