06-26-2016, 02:14 PM | #1 |
Door handle fit
Does anyone know if this is normal? Just looks like to big of a gap. Driver side is perfect.
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=706924 |
06-26-2016, 02:22 PM | #2 |
Re: Door handle fit
door handle gap
06-26-2016, 03:21 PM | #3 |
Re: Door handle fit
that is not right mine fit tight as a glove
06-26-2016, 08:20 PM | #4 |
Re: Door handle fit
Are you reinstalling a handle that was already on or is it a different one?
Is the plunger rod too long holding it out? Sometimes on the rh side the rod need shortened a bit because it is a shared part with a Suburban rear door. Just guessing. Would need to see a picture.
Jeff. '72 Blazer K5 "Camshaft opinions are like belly buttons; everyone has one and no two are alike" My Blazer Build: http://67-72chevytrucks.com/vboard/s...d.php?t=626752 My Engine Build: http://67-72chevytrucks.com/vboard/s...d.php?t=637336 |
06-27-2016, 07:27 AM | #5 |
Re: Door handle fit
It's touching on the right side so I would think it's not the rod. These did come off another truck. I'm trying to figure out if maybe this door isn't original or had some work done to it.
06-27-2016, 01:21 PM | #6 |
Re: Door handle fit
is it a '67 handle? I know they're different. but I don't know how/if they fit in a newer door....
if I was home I could post a pic of each.
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
06-27-2016, 01:24 PM | #7 |
Re: Door handle fit
They are both the same so if they didn't fit then the driver side shouldn't have I would think.
06-27-2016, 03:47 PM | #8 |
Re: Door handle fit
Looks to me like the opening in the door is bent in.
1972 Dark blue, Cst, Highlander |
06-27-2016, 07:35 PM | #9 |
Re: Door handle fit
06-27-2016, 07:57 PM | #10 |
Re: Door handle fit
Thanks guys. I don't know what I need to do about that. May just have to roll with it.
06-27-2016, 09:34 PM | #11 |
Re: Door handle fit
dont just roll with it water will get in and mess sh!t up rust etc
i would pull it of and go at it from inside of the door with a wooden end of a hammer and tap the hammer lightly and slow till it levels out don't do it in one shot super light taps even if it take a hundred and it should bend out without damaging your paint (the end of a broom handle cut off would work too) |
06-27-2016, 10:01 PM | #12 |
Re: Door handle fit
Ok. I was worried about the paint chipping if I started hitting on it.
06-27-2016, 10:04 PM | #13 |
Re: Door handle fit
How did the original handle fit or was it missing ?
06-27-2016, 10:42 PM | #14 |
Re: Door handle fit
Original handle was gone.
06-28-2016, 12:40 AM | #15 |
Re: Door handle fit
Get behind it and try to push it out. Avoid hitting the very edge and you shouldn't chip.
