06-22-2016, 08:10 AM | #1 |
Jimmy is home
I am very happy with my new ride, got it running last night after sitting 14 years in a garage,,,,
starting on the brakes tonight, there a mess, here is a few pics. |
06-22-2016, 09:12 AM | #2 |
Re: Jimmy is home
Looks great!!!
06-22-2016, 09:47 AM | #3 |
Re: Jimmy is home
What am I missing? Pics?
06-22-2016, 10:33 AM | #4 |
Re: Jimmy is home
Sweet ride
06-23-2016, 06:50 AM | #5 |
Re: Jimmy is home
not sure why i can't post pic's.....sorry i will try later.
06-23-2016, 06:53 AM | #6 |
Re: Jimmy is home
06-23-2016, 06:55 AM | #7 |
Re: Jimmy is home
72
06-23-2016, 07:03 AM | #8 |
Re: Jimmy is home
72
06-23-2016, 07:07 AM | #9 |
Re: Jimmy is home
gmc
06-23-2016, 07:13 AM | #10 |
Re: Jimmy is home
need to work on the brake,,,,for there is none...
can't seam to find and front rotors ,,,,any help .i checked local store's none available.. |
06-23-2016, 09:44 AM | #11 |
Re: Jimmy is home
Beautiful rig. Great work! Doesn't look like it has been sitting long.
06-23-2016, 09:46 AM | #12 |
Re: Jimmy is home
Looks great!
06-23-2016, 10:05 AM | #13 |
Re: Jimmy is home
06-23-2016, 10:06 AM | #14 |
Re: Jimmy is home
06-23-2016, 11:31 AM | #15 |
Re: Jimmy is home
I found mine at Summit. Drilled and slotted for about $50 each.
06-23-2016, 11:52 AM | #16 |
Re: Jimmy is home
really i will look again,,,
are they just a regular rotor,,,,,because i need the rotor with the hub neck.. unless i just need to beat it off there, seamed like it was one piece |
06-23-2016, 11:57 AM | #17 |
Re: Jimmy is home
Two piece......knock the studs out..it'll come apart...
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. |
06-23-2016, 11:58 AM | #18 |
Re: Jimmy is home
cool i found them.......thanks......
06-23-2016, 12:55 PM | #19 |
Re: Jimmy is home
From the picture it looks like you have a lot of meat left on them you sure you can't just get them turned. Any shop that can turn them should know the spec.
06-23-2016, 04:23 PM | #20 |
Re: Jimmy is home
Technically the lugs a pressed/swedged in through the hub. I know 1000's are knocked out and back it and it rarely causes a problem. CHeck for run out/ wobble before you finish assembling the unit
06-23-2016, 09:27 PM | #21 | |
Re: Jimmy is home
When I replace the disc...I put new studs in and press each one a little at a time.........that centers the disc and hub.....
06-28-2016, 06:45 AM | #22 |
Re: Jimmy is home
brakes are done....just waiting on one rear rotor, then bleed them ,,,,
can't wait to drive it. taking it to the Good Guys show this weekend.... |
06-28-2016, 08:00 AM | #23 |
Re: Jimmy is home
Looking good!
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
