02-05-2009, 06:31 PM | #51 |
Re: Slim's Gym truck build
you could try wire wheeling with a 4 inch grinder. that worked good on some of my panels.
There is nothing you can't fix with a BFH or a FIRE WRENCH. 1997 chevy k1500 ext cab z71 (daily driver) sold 1996 chevy k1500 reg cab 4x4(daily driver)totaled 2008jeep patriot (wife's daily driver 2008 chevy 1500 ext cab 4x4 sold 2011 chevy 1500 crew cab ltz (daily driver) 1996 chevy 1500 reg cab 4x4 project sold 2006 pontiac grand prix gxp (daily work commuter) |
02-05-2009, 06:37 PM | #52 |
Evercoat is a Filler (bondo)
The use of bondo is not bad, it's how much you use and how you lay it on. Even GM uses it on the assembly line. I don't like media blasting large panels (just my preference). you can sand the rust, use a rust converter, then seal it and fill it and it will be fine.
Bill 1970 Chevy Custom/10 LWB Fleetside 2010 Toyota Tacoma PreRunner SR5 Double Cab - DD Member of Louisiana Classic Truck Club (LCTC) Bill's Gallery Life isn't tied with a bow, but it's still a gift. Live simply. Love generously. Care deeply. Speak kindly. Leave the rest to God! Last edited by Palf70Step; 02-05-2009 at 06:41 PM. |
02-05-2009, 08:34 PM | #53 |
02-05-2009, 08:41 PM | #54 |
You can sand blast that small area with a small home blaster and not worry about warping the metal . I used a industrial blaster on mine without any damage. Plus the small blaster is nice to have around for other small parts ,bumper brackets and areas you can't sand.
02-05-2009, 09:09 PM | #55 |
Thanks. I dont know if you noticed that little red blaster in the last pic? But you say it is used only on the final body work? In my mind I was thinking lead. I want it to be as solid as possible. Would that be your other option?
I didnt want to grind it anymore in fear of making the spot weak
Long live SLIM ------------------ At least try to buy American Last edited by slimneverdies; 02-05-2009 at 09:25 PM. |
02-06-2009, 10:07 PM | #56 |
This is how I would do it. 1st use that little blaster and get some playground sand from lowes or Home depot. Blast the rust, don't worry about warping you won't create enough heat with a home air compresser. After blasting wipe on some ospho this will kill all the rust. Let it dry for 24 hrs, then use a DA sander and 80 grit to take off excess ospho. This will prep the metal for epoxy primer. I use PPG shop line epoxy primer this is a good inexpensive primer. then skim coat your rough areas with evercoat filler, then block sand with a long board and 80 grit to start. Be careful not to take too much off. Then prime with a high build primer, shop line carries this too. 3 coats should fill any sanding scraches. Then lightly spray (fog) some black spray paint I use a black spray can primer . This is guide coating. Then wet sand with a block trying to sand away all the black without sanding thru to bare metal. If you start seeing bare spots before the black is gone then those those spots are LOW, you will either need to skim coat again of use a shrinking disk to bring down the high spots. You tube has many videos on doing body work I hope this helps. And as for lead work not many people do it anymore because it's a PITA.
06-10-2009, 01:04 AM | #57 |
Well Ive been out of commission for a few months cause me and the old girl are splitting up So now that I will be alone I can get back on my build. Ive been practicing up on my tig welding and am ready to build. While I havent been working on my truck a friend of mine said he had a truck he wanted to get rid of?
So I go take a look and what do I see?
Long live SLIM ------------------ At least try to buy American Last edited by slimneverdies; 06-10-2009 at 01:07 AM. |
06-10-2009, 01:10 AM | #58 |
He said I can have it for free Of course there's always a catch. There is a 30yr old tree growing thru the bed. Lamo Belive it or not the truck is actually in good shape to be sitting in the same spot for lord knows how long.
Long live SLIM ------------------ At least try to buy American |
06-10-2009, 01:46 AM | #59 |
the pollock
OMG!!!!!!! what a great score!
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
06-10-2009, 02:41 AM | #60 |
Registered Chevy Owner
Nice!
Love is fleeting, but Chevy trucks are forever!!!! 1970 Chevy CST C10 long box 350/400 2008 Chevy Silverado short box 4x4 Had; 1951 Chevy short box 307/T5 1988 Chevy shot box 4x4 350/350 1971 Chevy C10 long box 4x4 350/350 1971 Chevy C20 long box 350/350 1971 Chevy C10 long box 350/350 |
06-10-2009, 09:56 AM | #61 |
LUCKY!!!! I know how you feel about the trees man... Seems every truck I find is in the woods and I have to cut down trees. Good luck with your build!
---Ben Jammin's 1955 Chevy/GMC Project --- ---The shop's live video feed--- <<< See what I'm up to! |
06-10-2009, 10:11 AM | #62 |
Thanks 'til you're better paid
Funny how a tree never seems to grow very fast, until you find a truck you want to buy with a big old tree growing threw it! Nice score man!
-Luke 1950 Chevy AD 3100 pickup 2000 GMC Sierra 1970 Jeepster Commando |
06-10-2009, 12:44 PM | #63 |
It actualy looks like the tree grew under the frame and helped keep it from sinking into the mud, might be a pretty solid rig. I'd have it free in 20 minutes with my chain saw, most trucks need the bed replaced anyway. Grab it.....
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
06-10-2009, 12:48 PM | #64 |
Yeah its a good score. I'll end up spending around $200 on finding someone to chop all the trees down cause its like two trees merging into a few others . The main one is about 50' tall and has a million branches speaded out. Have to find someone to cut it down without damaging the truck cause I sure aint gonna
06-10-2009, 12:51 PM | #65 |
I dont know if its the trees or what but the sheetmetal is in very good condition. Its like a Rambo trick, the leaves keep all the salt so now its fresh water sprinkles LMAO
Long live SLIM ------------------ At least try to buy American Last edited by slimneverdies; 06-10-2009 at 12:53 PM. |
06-10-2009, 02:36 PM | #66 |
If I was any where near ya I would cut'em out in a flash! Good luck on the logging expedition
06-10-2009, 04:41 PM | #67 |
I just noticed that it's a '47. LUCKYYYYYYY!
06-11-2009, 12:42 PM | #68 |
PROJECT 7DEUCE
Nice score on the free truck looks like your project will move quickly....
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
06-24-2009, 04:34 PM | #69 |
hey slim did u ever find a lumber jack to get that truck out of the trees? do u ever make it to tower on fridays? Im just starting my first truck and have found the guys there extremely helpful
55 1st Series 5 window, getting an s10 frame and 350 sbc Keeping it LOUD and ROUGH - just like BOONEMAN |
06-24-2009, 07:07 PM | #70 |
IL boy, I can only say that im so frustrated with the Slim's Gym project that I havent even thought about going to pull the other one. I have a 83 el Camino that's in the works and my 86 C10 daily to worry about too. The 53 is my first priority though.
Where is this notorious Tower that I've been hearing about for the last 3years? Is it that spot in Pemboke Pines or the one in Davie? I've been to the one in Davie off of University and 595.
Long live SLIM ------------------ At least try to buy American Last edited by slimneverdies; 06-24-2009 at 07:08 PM. |
06-24-2009, 08:19 PM | #71 |
its one in davie. there is a guy with a 54 with a 57 belair dash. a guy with a 55 1st that is pretty well done. i've seen a few 51's and there are always a couple of apache guys there too. i never heard of a cruise in pembroke pines but i've only been down here two years.
06-24-2009, 08:39 PM | #72 |
hey slim you were looking for an 8.8 rear end?
http://miami.craigslist.org/pbc/pts/1236403682.html idk if it will work, just thought you'd be interested in checking it out
06-24-2009, 09:58 PM | #73 |
Thanks dude. I called and left a message for some measurements on the rear end. Yeah, theres this little show they do next to Maroone Cheverolet once a month. Ive been there a few times but when I usually get up on Saturdays its almost over.
06-26-2009, 05:40 PM | #74 |
Hey IL Boy, thanks for the link. The guy actually drove down from Loxahatchee to deliver the rear end for me. He was a really nice dude. I wish I could find some people here in Miami and Ft. Lauderdale that nice.
06-26-2009, 06:08 PM | #75 |
i am glad the info helped. i completely understand where you are coming from, people in S. FL are a breed unto their own. it seems the nice ones are from somewhere else, but i wouldn't want to live anywhere else. one of these fridays we will have to meet up at tower or something. i'm the guy walking around the pre 74 section wearing a cubs hat and long goatee. names Trent by the way.
this is my hubgarge link with pics of my trucks. www.hubgarage.com/mygarage/enrohtnotnert
55 1st Series 5 window, getting an s10 frame and 350 sbc Keeping it LOUD and ROUGH - just like BOONEMAN Last edited by IL boy; 06-26-2009 at 06:10 PM. Reason: forgot info |
