11-17-2019, 02:37 PM | #1 |
Ideals on c10
What would you do with this truck got from guy started putting it together. Any ideals are pictures
11-17-2019, 02:47 PM | #2 |
Re: Ideals on c10
Pic
11-17-2019, 04:20 PM | #3 |
Re: Ideals on c10
Nice truck. At this point you already have the patina theme going. I would attempt to get it road worthy, check brakes and running gear. From there I would drive it, a lot! I love the wide wheels!
Keagan 68 SWB C-10 original 350 A/C 503 Mean Green |
11-17-2019, 04:36 PM | #4 |
Where's my beer?
Re: Ideals on c10
I like the truck just the way it looks, and agree with above, get it running and drive it!
70 C10, shortstep, .30 over 250,Hurst shifted 3 spd parts hauler. Holley 390, Clifford Intake, Header, ported cylinder head, unknown bigger cam. 79 Corvette L82, 4 spd, black, red interior, headers, flowmasters, and unkown bigger cam. '03 Grand Cherokee Laredo, 4.0 4x4 daily driver. 165K miles, and runs great '08 Tahoe LTZ 4x4 155K |
11-17-2019, 05:01 PM | #5 |
Re: Ideals on c10
I'd spray it down with ATF, let it set overnight, then wash the rust off with soap and water. Follow that up with a good buffing and about 4 coats of good wax.
I'd also hose out the cab corners, rocker panels and inner fenders. get ALL the dirt mud N crud out of there, and let it dry. I would steam clean the under side, and engine compartment, paying extra attention to nooks and crannies (what the hell are crannies?) After that, I'd do gear oil, brakes, u joints, grease the chassis, get it running, evaluate what is necessary to make it safe and dependable. Also, I would start looking for a grill and bumper. Looks like a fun project, good luck, have fun, keep us posted. ...You're gonna need a lot of beer. -Russ |
11-17-2019, 06:28 PM | #6 |
Re: Ideals on c10
^^^What Russ said X2^^^
I think crannies are the parts where the sun don't shine... perhaps even in between those parts... You may need some lube to get to the deeper cranny regions.
Brian 1972 C10, "Loyd", LWB to SWB, 5.3, L83/6L80e, 4:11 Tru Trac, Air Ride, VA, DD, 20" Coys, 4 wheel disc, A quick LS swap turned into a 6 year frame off resto-mod. |
11-17-2019, 09:47 PM | #7 |
Re: Ideals on c10
Thanks for the input on the truck
11-17-2019, 10:08 PM | #8 |
Re: Ideals on c10
I think you should give it to me , Im not that far away . It looks great just like it is . Make it safe and drive it .
11-18-2019, 08:07 AM | #9 |
Re: Ideals on c10
I would paint it. It looks like it could be a nice looking truck with a paint job
11-18-2019, 07:39 PM | #10 | |
Re: Ideals on c10
What does this do, and how much of a mess is it to clean off? |
11-18-2019, 08:39 PM | #11 | |||
"I ain't nobody, dork."
Re: Ideals on c10
Gary
11-19-2019, 01:47 PM | #12 |
Go Pack Go!
Re: Ideals on c10
11-19-2019, 06:07 PM | #13 |
Re: Ideals on c10
I've got two good fender and door I'm going to. Change out this week end if it dont rain
11-19-2019, 06:09 PM | #14 |
Re: Ideals on c10
I've got two good fender and door I'm going to. Change out this week end if it dont rain then putting a stock 350 in 400 trans I have to get drive made
11-21-2019, 11:25 PM | #15 |
Re: Ideals on c10
Just helps remove surface rust, without harming what's left of the paint. you'll still have to scrub, but it will take a little less elbow grease, ATF is a great rust remover and has a lot of detergent in it.Spray it on with a spray bottle or pressure pump, let it set, wash it off with Dawn soap and warm water. a little messy, but works pretty good and is cheap.
11-22-2019, 07:13 PM | #16 |
Re: Ideals on c10
^ People wash with CLR to do the same thing right - to remove the rust? Would CLR be a little better for the environment than ATF?
