07-08-2019, 07:17 PM | #51 | |
Proprietor of Dale's Corner
Re: Most/Least Favorite Modifications/Upgrades
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
07-09-2019, 04:09 AM | #52 |
ttt
07-09-2019, 09:39 AM | #53 | |
I am moving to an older (~2008) wideband setup from a project car that has been sitting. These are designed to be very accurate from 10.0:1 - 20.0:1. With this setup, it will display the exact Air / Fuel ratio. The controller I have can data log when connected to a laptop. I plan to use an 80's GM MAP sensor to detect manifold vacuum, have it measure RPM from the coil, and the AFR from the wideband sensor. This way I can look at logs to determine my AFR at different RPM and throttle positions. The narrowband air/fuel gauge can be assembled for about $65 - $5 bung, $20 sensor, and a $40 gauge. Wideband is more like $200 for a basic setup. The relayed headlights are as the other threads have shown. I didn't use a kit. I used some relays from the junkyard. I've done this with at least 2 different vehicles.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
07-09-2019, 03:22 PM | #54 |
Most Favorite:
1. Front Sway Bar 2. 5/6 drop 3. Craftec bed cover 4. Replaced rear step bumper with stock chrome bumper. Least Favorite: 1. Front Disc Brakes - Spent hours bleeding, bleeding, bleeding... Turned out to be a tiny bit of air trapped in master which had been bench bled twice already. 2. 5" round side mirrors. Broke a 5x7 mirror so switched to round, will go back soon. |
07-17-2019, 10:34 PM | #55 |
to the top
07-18-2019, 12:57 PM | #56 |
My favorite mod was when I got rid of the old rear end with 5. something gears in my 68' C-20 and went with a 14 bolt with 3.73 gears. Totally different truck!
68' with no bells or whistles unless I add'em. |
01-12-2021, 02:05 AM | #57 |
Favorites:
1. Redhead steering box 2. Front sway bar 3. Meatier tires on rallyes, 255 70 15 4. Moog coil springs, front and rear 5. 3.08 to 3.42 rear diff Least: 1. Smaller tires, rode like crap with less meat on them 2. Peep side mirrors, couldn't see squat, and when I did, everything was shaking, looked cool though 3. Body work, I should of left it patina |
01-12-2021, 08:02 AM | #58 |
I’ve tried to keep my truck mostly stock,but most of the upgrades have been with Factory option parts (Tach, Tilt column, headliner, Bucket seats/console, and front sway bar, just to name a few).
That being said: Favorite upgrades: Coil over shocks on all four corners Electronic Conversion Module to replace the Points, and keeping the Factory appearance. Installing a factory Cargo light on the back of the cab, but made it a Third Brake light, by using two bright Red LED bulbs, and wired into the brake light system. Future favorite: Putting an EFI system on to replace the Carburetor. Least Favorite: Not having enough room for a couple more trucks. |
01-12-2021, 10:20 AM | #59 |
Old member
Most favorite:
Buying a 71 C 10 and building it like I want it! Least favorite: Having people tell me that's not how they would do it!
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-12-2021, 10:22 AM | #60 |
Favorite upgrades (or additions).
1.) 72 steel bed to wood conversion with bedside and tail gate inner wood panels. 2.) Custom DIY bedside edge protectors 3.) Wooden interior components. 4.) Under bed spare tire hanger. Least Favorite upgrades to perform... 1.) Drive shaft mods to accommodate the Pontiac 400. Most due tothe fact that there is not a decent shaft builder near me and the logistics are a pain to get them to KC and back along with the needed info to get them right...it was a cluster. 2.) Stainless brake and fuel lines. This takes alot of practice and the expensive line working tools.
He who is without oil shall throw the first rod. Compressions 8.7:1 1972 C10 1976 C10 (parts truck) 1985 K20 |
01-12-2021, 10:39 AM | #61 |
My current truck is a result of my past mistakes.
Favorite upgrades: - Cummins Turbo diesel w/5spd manual in 72 C20 Least Favorite upgrade: - 4/5 drop on my 70 CST/10 It took me years of truck ownership and many hours in the garage to realize I didn't like lowered half ton truck!! Turns out I like HD stuff. News to me.
1972 Cheyenne Super 20 Custom Camper 12 Valve Cummins/5spd manual 1972 Cheyenne Super Short Bed 557 Med Olive DK olive 1970 K5 Blazer Dark Gold 1966 Coronet 440 35k mile survivor 1991 Suburban 2500 454/4L80E 2wd 1985 Monte Carlo SS 383 Sbc, t-56 magnum 6spd and Ford 9" |
08-10-2023, 11:42 PM | #62 |
This was a great thread years ago, now that changes have been made to my truck, my favorite mods have changed.
Have yours? Current most favorite modifications: Ls swap T56 Magnum 6 speed Least favorite thing is not really a modification, it’s the rust I’ve replaced the inner and outer rockers, and passenger side fender cup (typical) I may need to do a roof skin, the seam sealer has been cracked and mostly missing for years
72 C10, Was a 350,M20, Brodix heads,Comp cam, Edelbrock intake&carb, Hedman hedders LWB. Project is now a 5.3(L33) w/PRC stage 2.5 CNC ported 243heads, BTR RedHot cam,Holley Terminator X, T56 magnum. SWB, Boyd tank. 4.5/4 Drop http://67-72chevytrucks.com/vboard/s...My72c10project |
08-11-2023, 11:59 AM | #63 |
Not an upgrade, I just restored the A/C, thermostatic air cleaner and choke warm-up, and hub caps, and love it. It's very cool to see the air cleaner damper in operation.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring it from ground up. With assys, the guide accts for 1000s of OEM identifications and part numbers, all written in short order. 700+ images include assm, illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
08-11-2023, 12:33 PM | #64 |
My '71 Custom Deluxe.
Likes: not cut up, mostly original emission controls still work (for me a sign of being well cared for) Factory A/C 350/350 PS/PB wood floor tinted glass Stuff I did:: HEI internally regulated alternator replaced Quadrajet with Holley 4360 Economaster Not favorable: Replacing the Quadrajet with the Holley. That carb works very well but I prefer original where possible. Fuel consumption |
08-11-2023, 06:09 PM | #65 | |
The QA1 and LS are easy enough to undo, but I think I screwed the pooch with the rear.
1970 2WD K5 1968 Camaro Conv 1967 Chevy SWB 1964 Malibu SS 1957 Corvette Pics www.picturetrail.com/wesmigletz |
08-12-2023, 04:23 PM | #66 |
Most:
L83 engine & 6 speed auto trans A/C Full power leather bucket seats Least: Crappy Flaming River tilt column No-Limit Engineering front end that keeps eating bushings |
08-12-2023, 04:48 PM | #67 |
Active Member
1) favorite: converting to power steering and power disk brakes,
2) least favorite: going through hood hinges trying to get the hood to fit and sit like it should. |
08-12-2023, 11:18 PM | #68 |
Junior Member
Favorites:
LS Swap Tru-trac posi Altman Door Latches Least: Fighting to remove the 3rd u-joint from power rack and pinion steering |
08-12-2023, 11:32 PM | #69 |
Best Mods No Particular Order:
1976 1-Ton 14 Bolt Cab and Chassis 4:10 Rear Differential 1976 HD 1-Ton Front Disc Brake Set Up GearVendors Overdrive Tachs 1950 @ 55 Gooseneck Hitch Converting to 175 Amp Internally Regulated PowerMaster Alternator, And Losing about Another 5 Pounds Of Wire In The Process Of An Almost Complete Rewire From the Firewall Forward. Champion Aluminum Radiator With Dual Electric Fan System That Performs Flawlessly Without A Hint Of Over Heating Even On 110 Deg. Days, Windows Up, A/C On. I Have No Worst Mods, They Are All Good. |
08-13-2023, 01:07 AM | #70 |
70 gmc came with drum brakes. changed to 72 discs and 1.25 sway bar. huge!!!!! difference. now I do like the remote spare tire lift. chuck
08-13-2023, 03:40 PM | #71 |
70+ ( Old Skool Club )
Looking over my list I've done 35 changes/upgrades to my truck since I bought it in 2014. There is not one change I do not like but one I wish I hadn't for practicality purposes. I pulled the bench and installed buckets and console and although love the buckets and console as I said for practicality I should have kept the bench seat.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
08-13-2023, 04:08 PM | #72 | |
Right now me, the wife and Molly Dawg ride just fine on the factory bench seat. If I went to bucket seats the wife would have to stay home! |
08-14-2023, 02:06 PM | #73 |
Other then restore, I think my favorite is for 30 years EVERYONE short my painter and his wife said DONT PAINT IT OCHRE. Those left say glad it was, whatever. My mom said it was proof im colored blind. She'd ask me, what color do you see..... ha. My least favorite of the project was a write up on the subject. More time on that and researh than building it. That and little wires flying off dremmel brushes.
08-14-2023, 03:45 PM | #74 |
Active Member
Most :
-Progression Ignition Distributor upgrade -3.07 to 3.73 gear swap (around town) Swapping from Thumpr cam that was in the truck when I bought it to the xe268 -Sound deadener -my ‘temporary’ rattlecan paint job- I actually kind of like it and I get a lot of compliments on it : ). Least: -Adding AC - I should’ve just spent the $$ on 700r4 upgrade instead . I don’t even use the ac that often even when it’s hot and really like the 3.73s everywhere except over 60mph Posted via Mobile Device |
08-16-2023, 02:39 PM | #75 |
Most favorite:
Lizard Skin sound and thermal coatings Unity spotlight 65 El Camino steering wheel Under dash A/C unit Easy Latch upgrade Moved gas tank to under the bed Hydraulic Clutch Muncie M20 Least favorite: Having to remove the dash for rust repair No others at the moment, but I am still working on my build. |
