07-12-2019, 08:40 PM | #1 |
Look what I found under the valve covers!
I am trying to find the source of a miss that just showed up on my Blazer. I cleaned & gapped the plugs, new wires, cap rotor and it's still there...
I pulled the valve covers to see if maybe a rocker arm fell off and found this! I still have the miss for the moment, but am feeling a bit better about the power plant!
'72 Chevy K20 - 383/4sp/205 - SOLD after 41 years in the family Next project - K/5 Tahoe (71 Blazer on 99 Tahoe chassis) Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=789958 |
07-12-2019, 11:31 PM | #2 |
Re: Look what I found under the valve covers!
Sweet!
Kind of makes you want to pull the intake, to look for more cool roller stuff, eh? |
07-12-2019, 11:46 PM | #3 |
Apparently a PO had more money than brains. NP
Try opening the hood with the engine running after dark to check for crossfire. |
07-13-2019, 02:51 AM | #4 |
Guest
Posts: n/a
Wow, did not expect that!
07-13-2019, 07:45 AM | #5 |
Sounds like the surprise I found in a 350 small block I found for $300. When I opened it I found a new crank/cam/pistons along with all the visible parts turned out to be a 71 /350/ 4 bolt and after a little clean up I'm happy with it .
1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
07-13-2019, 11:59 AM | #6 |
lobe on cam is bad bet ya
I BELIEVE IN JOHN 3:16 |
07-13-2019, 12:31 PM | #7 |
Those rocker arms look to be Harland Sharp brand, some of the very best roller rockers!!!
07-13-2019, 02:21 PM | #8 |
Man some folks have all the luck. I'm lucky to find $2 in change under the seat of a new rig.
Congratulations! I hope your as lucky finding your missfire.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban the WMB,1991 S(stink)-10 Blazer,1969 GTO, 1970 Javelin, 1952 F2 Ford 4X4, 29 Model A, 72 Firebird. 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
07-13-2019, 03:32 PM | #9 |
07-14-2019, 07:52 PM | #10 | |
Cool find though!
07-14-2019, 08:35 PM | #11 |
I spy my little eye ,,, High bleed lifters by the pic I see, all rockers are on the valve seat position.
07-14-2019, 09:35 PM | #12 |
Bet the cam is plumb shot and all that metal has been pumped thru the engine...........pull oil filter, cut it open n inspect it..........jmo
07-16-2019, 03:59 PM | #13 |
Found the miss!
I swapped distributors and it went away - the points were getting worn out. Gonna have to find an HEI dist eventually...
07-16-2019, 04:17 PM | #14 |
07-18-2019, 05:53 PM | #15 |
Go Pack Go!
Nice find! It's incredible that the PO spent the money for the roller rockers but not an HEI?
07-18-2019, 07:58 PM | #16 | |
Another scenario is " Let's throw together an engine out of those used race car parts"
